What happened to HEAL & REPAIR with the new dongle & 5.3.2?
I upgraded to 5.3.2 and had to replace my 300 series Zwave dongle with the 500 series to work with the new firmware and now I can't find the HEAL and REPAIR options in the zwave drop down at the top of my console options.
I can find an option to REPAIR LINKS for each Zwave device, but not a n option to fix the whole mesh.
What am I doing wrong?
Nothing. The universal heal had been removed and replaced with update neighbors for individual devices as this is the best method for updating zwave devices
Thanks... I see two options:  UPDATE NEIGHBORS and REPAIR LINKS.  When should either be used?
I just upgraded my firmware to 5.3.3 and as you mentioned the universal heal has been replaced with UPDATE NEIGHBORS and REPAIR LINKS.
Could you please give me a description as to when I should use either of those options.
After upgrading my firmware to 5.3.3 I no longer have the "universal heal" or "update neighbors" and "repair links". I only have synchronize nodes. Is there something I need to do to fix this.
Update neighbors and synchronize nodes is all you should have for the update zwave dongle and the current firmware. Use update neighbors after adding zwave devices and synchronize nodes if you are having problems.
Clear your Java cache. You should still have update neighbors
Same with my 5.3.3. I see only "Synchronize Nodes" -> "New & Deleted" or "All".
Same, with 5.3.3. I only have Synchronize and now when I add a device to Smartthings using the ISY as the secondary controller I can't get the device to show up in the ISY like it would before using repair links.  Synchronize New and Deleted and All do not add them either.  Any ideas on how to get new zwave devices from Smartthings into the ISY now?
