Get Started (v1.3)
16 minutes ago, DennisC said:
If you are trying to access the admin console of ISY on Polisy, using your example from above, try: https://172.16.1.226:8443 in the ISY Launcher (but I think your missing a block of number(s) - should be https://xxx.xxx.x.xxx:8443).
If it doesn't work the first time, power cycle the Polisy and give it a chance to come fully on line before trying again.
Thats my IP range.  The URL you gave me brings up the Pg2 interface.  Change port to 3000 and you get Pg3 interface.  My issue is getting ISY on Polisy.  The Launcher wont find it.  on 8443 or 8080
OS is at 13 rev p6.
I dont think the ISY is running even though it says it is or if it is something is wrong.
OS is at 13 rev p6.
Did you try power cycling Polisy?
The way mine is working, is just the https://ipaddress in a browser brings up pg2 Polyglot. When port 3000 is added in browser it brings up pg3 Polyglot.
Using https://ipaddress:8443 in ISY Launcher let's you click on Polisy to open admin console of IoP.
If it doesn't work like that for you after a power reboot, open a ticket with UD.
15 hours ago, macjeff said:
I am trying this for first time.  I have ISY running but the status command does not seem to work
 sudo service status isy
Password:
status does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d), or is not executable
You have the parameters in the wrong order for this command.  Should be:
sudo service isy status
Thanks. Have it working and everything seemed. fine.  But now the portal can suddenly not see it after restoring from backup.  I want to reset it again but no idea how to reset ISY on Polisy to default
See post (answer there) I just put in the main directory of ISY on Polisy forum
