ISY on Polisy v5.0.2 Is Now Available
43 minutes ago, Michel Kohanim said:
Fixes:
Sunrise/sunset issue
Adds py38-sqlite3 for Wemo
Small releases are awesome!  (much better than waiting months between)
Sunrise/Sunset are much closer... I hope that adding Custom Location back is on the list!
In my case, it's only off by 2 seconds from my coordinates-based location.
mines not far off.. a few minutes... but I love the concept of it being calculated for the exact location.. after all, if we are here to begin with we're geeks...
Another reason is because I have to use the hue bridge timer to start an animation every morning, after that point the ISY takes over management, the ISY994 and the hue bridge currently are only about 2 seconds apart in the calculated times.  The author of app running on the hue bridge has told me point blank that not using the hue bridge and his app as the center of automation is the wrong approach... guess what, I don't agree.. hue is a very small part of my total automation package.
So true!
3 hours ago, Michel Kohanim said:
Keeping it short!
Fixes:
Instructions:
sudo pkg update
sudo pkg upgrade isy (-> 5.0.2_2)
sudo service udx restart
sudo service isy restart
Up and running here with a little help to get to OS 13 (the only info that was missing).
Question, you show Policy access using localhost, do I have to hook up a monitor to access?
I have a USB PLM, is there anyway to see if the Polisy sees it?
Thanks and good work!
You can see if it's connected here:
Mine:
Mine:
Mine says not connected.  Did you have to do anything special to find it?
interesting question....
I initially hooked up a USB PLM (it was old but working last time I knew, way back in the Vera days)  it said not connected although it responded to the reset button.  I re-capped it today and it still appears functional, but not seen by ISY
...Barry
...Barry
Gave the Reset button a try but no luck.
Oh well thanks!
I couldn't get my old USB PLM to be found either. I'm using a extra serial PLM with DB9 cable.
Am getting message that "isy is not installed..."
[admin@polisy ~]$ sudo pkg upgrade isy
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
pkg: isy is not installed, therefore upgrade is impossible
is did follow the steps outlined here first.
what am I missing?
56 minutes ago, johnnyt said:
what am I missing?
the steps outlined in the linked post state:
Quote
To get started:
- sudo pkg update
- sudo pkg upgrade (this should upgrade your ISY to 5.0.1)
_ sudo service udx restart
- sudo service isy restart
you typed
I'm talking about the steps at the top of *this* post:
sudo pkg update
I was just saying I did the steps from linked post BEFORE in case it was key to being able to do these steps
so to be clear I've done the following:
- sudo pkg update
sudo pkg update
and posted the messages related to the last command above
the problem started before the upgrade command. I wasn't able to restart ISY but was focusing on the commands given for this post.
below a more complete sequence of errors, and attached is the stuff before that, which seemed to work ok other than issue with /dev/speaker.
isy does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d), or is not executable
[admin@polisy ~]$ sudo service isy restart
[admin@polisy ~]$
Checking integrity... done (0 conflicting)
Your packages are up to date.
ISY-update.txt
What is it about new toys that I simply can't resist!
So I took the plunge and added ISY to my Polisy. The upgrade / Update went smoothly without any issues. The ISY was immediately available in the launcher (once I typed in the addr) and I was good to go.
I was not able to launch the Polisy ISY using LAN, only CLOUD, but it was fast and promises good things in the future. I don't have a USB PLM or a serial cable so I went into the Polyglot config and changed the ISY settings back to my existing ISY994i.
It works mostly, but I do have this error that won't go away.
Also the NodeServers only partially work. LifX works, but I can't query devices. Ring is dead. Harmony kinda works, etc. I believe this is just another symptom what ever is causing the password error.
Anyone else have an experience like this?
what am I missing?
Confirm with uname -a you are on v13?  My guess is you aren't and all the steps updated your polisy to the current v12 version.  See my response above about the CAT command to update to v13.
Jeff
Try re-starting polyglot after setting/saving the ISY info.   I've seen this type of issue before and it seems to be related to polyglot getting confused over which ISY it should be using.
@bpwwer Thank you, I have tried restarting Polyglot, rebooting the Polisy multiple times without any change.
@Michel Kohanim Via the launcher I used http://10.0.0.55:8080 as my addr and it shows up in the Launcher and is accessible via CLOUD, not LAN. Using LAN just hangs Java and I have to kill the Java process to get things going again. Using CLOUD works perfectly.
Is there a way to remove easily ISY from the Polisy? If so I can do that until I have a 2413U to play with. Thanks guys! Appreciate the fast (as always) help!
Edited by kzboray
Did you try: sudo service isy stop
Not sure if that remains through a reboot.
Possibly: sudo service isy disable
