ISY on Polisy v5.0.3 Is Now Available
Hello everyone,
Thanks so very much for your patience while we worked on v5.0.3 which is not available.
Fixes:
1. USB driver for ISTEON PLMs (including the RF only dongle)
2. The ability to download Admin Console directly from Polisy
3. Trigger Device substitution variable for Network Resources
Instructions:
Many packages, including the Kernel, have changed. So, the safest approach would be:
sudo pkg update && sudo pkg upgrade (about 145 packages will be upgraded)
sudo shutdown -r now
Seeing the following (after above steps & reboot):
[admin@polisy ~]$ uname -a
FreeBSD polisy 13.0-RELEASE-p3 FreeBSD 13.0-RELEASE-p3 #11 releng/13.0-n244752-b368bb75bad: Tue Jul 13 23:39:11 UTC 2021     ec2-user@bsdev.isy.io:/usr/obj/usr/src/amd64.amd64/sys/POLISY  amd64
[admin@polisy ~]$ sudo pkg update
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
[admin@polisy ~]$ sudo pkg upgrade
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[admin@polisy ~]$ sudo service isy status
isy is not running.
[admin@polisy ~]$ sudo service isy start
loading uftdi.ko
kldload: can't load uftdi.ko: No such file or directory
/usr/local/etc/rc.d/isy: WARNING: failed precmd routine for isy
isy is not running.
loading uftdi.ko
I'm seeing the same thing.
Thanks Michel, fyi my output below....
[admin@polisy ~]$  sudo service udx restart
Password:
Stopping udx.
Waiting for PIDS: 1192.
eval: cannot create /dev/speaker: Device busy
CURRENT OS 13.0.3
No need to upgrade the OS
libwebsockets already removed
flashrom already removed
net/avahi already removed
dns/nss_mdns already removed
pkg already installed
dbus already installed
ca_root_nss already installed
dual-dhclient already installed
bash already installed
mongodb36 already installed
libnghttp2 already installed
git already installed
polyglot already installed
mosquitto already installed
powerdxx already installed
e2fsprogs-libuuid already installed
c-ares already installed
rapidjson already installed
mongo-c-driver already installed
npm already installed
isy already installed
tpm2-tools already installed
tpm2-abrmd already installed
py38-sqlite3 already installed
Starting TPM security services
Starting udx.
[admin@polisy ~]$  sudo service isy restart
isy not running? (check /var/isy/isy_daemon.pid).
loading uftdi.ko
[admin@polisy ~]$
All,
Found the issue: those who had already updated the kernel packages before, didn't get the new kernel. So, please do this:
sudo pkg update -f
sudo pkg install -f FreeBSD-kernel-polisy
- after reboot
We are fixing a few bugs including the aforementioned.
Hmmm No Joy here.
still get
loading uftdi.ko
[admin@polisy ~]$
....Barry
[admin@polisy ~]$ sudo pkg update -f
Password:
Fetching meta.conf: 100%    163 B   0.2kB/s    00:01
Fetching packagesite.txz: 100%   10 KiB  10.0kB/s    00:01
Processing entries: 100%
FreeBSD-base repository update completed. 113 packages processed.
Fetching packagesite.txz: 100%  108 KiB 110.3kB/s    00:01
udi repository update completed. 398 packages processed.
[admin@polisy ~]$ sudo pkg install FreeBSD-kernel-polisy
The most recent versions of packages are already installed
=====After reboot=====
Password:
Stopping udx.
Waiting for PIDS: 1119.
CURRENT OS 13.0.3
Starting udx.
loading uftdi.ko
[admin@polisy ~]$
Interesting observation that the system log (Sat 1951/07/28 05:33:07 PM    System    Log) and the error log (Sat 1951/07/28 05:31:25 PM    System) show the year as 1951 and UTC time even though it appears correct in the AC.
Edited by DaveStLou
Performed the update, rebooted the Polisy and bounced UDX & ISY.
I am still unable to get Polyglot to fully communicate with my original ISY. I am using LifX as an example, but I have similar problems with Harmony, Ring etc.
Although all the devices and programs work, i.e. tapping a light switch turns on the LifX bulbs, they do not show correctly in ISY.
And when I do a query I get an error in ISY, but Polyglot logs show the query.
2021-07-27 10:58:18,191 Controller polyinterface      INFO     polyinterface:reportDriver: Updating Driver d073d5349cb2 - GV0: -36, uom: 56
2021-07-27 10:58:18,194 Controller polyinterface      INFO     polyinterface:reportDrivers: Updating All Drivers to ISY for LIFX LIFX 349cb2(d073d5349cb2)
Any suggestions about getting my original ISY talking to the updated Polisy?
      378.2k
