ISY on Polisy v5.0.3 Is Now Available
12 minutes ago, kzboray said:
I am still unable to get Polyglot to fully communicate with my original ISY
@kzboray,
Polyglot v2 can only communicate with one ISY at a time. PG3 can communicate with multiple. So, are you certain that Polisy is configured to connect to your original ISY?
2 hours ago, Michel Kohanim said:
All,
Found the issue: those who had already updated the kernel packages before, didn't get the new kernel. So, please do this:
sudo pkg update -f
sudo pkg install -f FreeBSD-kernel-polisy
sudo shutdown -r now
- after reboot
sudo service udx restart
sudo service isy restart
We are fixing a few bugs including the aforementioned.
Hi Michel, I'm up and running but my PLM still says disconnected.
Have I missed a step?
mike
@mmb,
Please make sure Insteon Support is checked in the Admin Console.
Update: I tried several Polisy reboots but it didn't help.
I just unplugged/plugged in the PLM and a ISY reboot which got it going.
I was also able to add a switch and a lamplinc then crated a scene with no problems.
mike
Edited by mmb
That's what I ended up doing to get it to see my serial PLM again too.
Having trouble with upgrade. After upgrade and reboot restarting udx is fine but when restarting ISY I see:
[admin@polisy ~]$ sudo service isy restart
Stopping isy.
15    1 0xffffffff81d63000     8320 uftdi.ko
uftdi.ko is already loaded
Starting isy.
[admin@polisy ~]$
Admin console opens great on lan and cloud. But I have lost the portal tab. Gui and ISY both report v5.0.3
Any help would be appreciated.
-Tim
Edited by TJF1960
i had a similar issue after switching serial PLM to USB
A sudo service isy restart with USB plugged in fixed it
It appears it's USB but not plug and play  Needs PLM installed when ISY starts
...Barry
Never mind, Restore Modem is what I needed.
Does anyone know how to factory reset the 2448A7?  Or at least delete all of the links in it through the ISY interface (I have 2 links from some previous usage I don't remember).
File - Delete Modem says it removes the PLM (in addition to the links) from the ISY which is not what I want to do (unless adding it back is not an issue).
Edited by gzahar
@bgrubb1,
Yes, definitely 700 series with external USB dongle (off the shelf) one of which will be our preferred dongle. Thankfully, there is more than one supplier. And, if they do an INSTEON on us, we can always manufacture it ourselves.
On 7/27/2021 at 11:24 AM, Michel Kohanim said:
@kzboray,
As always you where right @Michel Kohanim. I found that I hadn't changed the IP addr for the ISY :oops:. My bad. Nothing to see here...move along.
All,
We have been tracking down a few issues with UD Mobile and it seems that we have a missed a few places where case insensitivity in ISY is now causing problems in Polisy. So, the question for you all:
If you have node servers installed, would you mind losing them (we'll have to wipe out the directory)?
I support 5 different Polisy / ISY installs. That's a lot of work, but if it needs to happen, sooner is always better and honestly...happy to take one for the team.
If you're referring to PG3 and/or the ISY on Polisy, then no issues at all.  Nothing in production on that platform here.
1 hour ago, Michel Kohanim said:
@kzboray,
Thank you. But, this is only about ISY running on Polisy and not ISY itself. Is this still the case?
I just deleted all my node servers running on my ISY/PG3 so now would be the perfect time :)
What is the specific issue with case?
      378.3k
