Led buttons and Alexa.
I’m not sure this hasn’t been addressed. If you use Alexa to turn a device on or off or a scene on and off. How does one make a sign button that activates that scene or that device light up when it’s on and turn off when it’s off. I’m sure there’s several ways of doing it I’m sure there’s a way of doing it within the Alexa app but not sure. I’m aware that there’s a way of doing it in the programming of the I SY but again I’m not sure. I like to hear others ideas of how they made this work.
If you're using a scene you should turn the scene on/off with alexa... If the scene is set up correctly all the KPL buttons should operate properly.   If you turn the device on or off without the scene the button indicator will not change.
