Linking taking a long time then fails?
When I start linking from the admin console, the "linking" progress bar takes a long time to get to 100% (3 minutes?).  When it's done, trying to link my devices doesn't register on the console.  I started on 5.3.0, trying 5.3.4 now same issue.  There's nothing in the event viewer other than "start insteon device linking mode"
What's your UI? What device are you trying to link and steps taken
UI is also 5.3.4.
No green/grey icons
I have lots of devices, most are dual band
I tried moving a 2635-222 right next to the switch to help with range
The new device is a 2477S
I set level 3 in event viewer - not seeing anything after the "start linking" entry.
I'm suspicious it's not a device issue but an ISY issue.  It used to be when I hit "start linking" it would start right away - this 3 minute wait for the start linking % to get to 100 is a new thing.
I've tried holding the link button down on the switch to start linking after the "start linking" bar went away
I've tried to pull out the switch air gap to power off the switch, then tried again
I moved the 2635-222 next to it, then tried #1 again
Power cycled the ISY
That's not step by step for your process. First you hit the start linking button. What's your next step after that? Then after that step what do you do next?
1) start linking
2) Hold down the little button on the switch until it beeps
3) Usually this is where the new switch appears on the ISY console
4) Go check the level 3 event log
I’ve had this happen a couple times. In my case the ISY appeared to be stuck in linking mode. I rebooted and then power cycled it but I think in the end the ISY just timed out of linking mode.
I pulled air gap on new switch so not sure what finally fixed it. I then starting link mode again after I factory reset the switch.
      38k
      379.1k
