Trigger device substitution on Network Rules
Just came across this gem (I don't know how I missed it!)
This is now going to keep me up a bit - and likely save me over a hundred network rules!
No joy :(
I get this received:
with this RAW payload:
{"device_type": "device_status", "device": "${sys.node.#.name}", "id": "#", "property": "ST", "value": ${sys.node.#.ST.raw}, "status": "${sys.node.#.ST}"}
This is the program triggering the NR:
5 hours ago, MWareman said:
No joy :(
Some show d.quotations around them and one doesn't.
I don't know how I missed that Michel misspelled Insteon in fix #1.  I guess the love affair is truly over.
-Tom
Correct.
In JSON - for strings you put the value in quotes. For numbers, you omit the quotes. If the substitutions operated then the quotes (or lack of) would make far more sense!
7 hours ago, Michel Kohanim said:
@MWareman,
Looking into it.
Thank you Sir!
Michael.
I get this most times when I first login. The next logins work fine after inserting my ISY creds. Later the same thing happens again. I will recheck this later and tomorrow to see if it forgets again.
1752167502_polisyloginISYpassworderror.thumb.jpg.5929984f733522bc8b68b3336ae8cb13.jpg
8 minutes ago, Michel Kohanim said:
@MWareman,
Can you please temporarily add ${alert.event} to your resource string just to see if the event that caused the program to run is what you expected?
I get this when I test with that:
I know it's invalid JSON (for testing only) - but this is the resource string:
{"device_type": "device_status", "device": "${sys.node.#.name}", "id": "#", "property": "ST", "value": ${sys.node.#.ST.raw}, "status": "${sys.node.#.ST}"} ${alert.event}
In case it matters - here is the resource config:
Could be one of a few possibilities .. it looks like there is no event occuring that is causing the program to run (i.e. manually doing a 'Run Then'), or, for some reason we are not properly storing the event with the program, or, the event gets cleared from the program prior to the NR being used.
We'll take a look at it, and hopefully reproduce the problem here.
I could understand that (manually being triggered - though I would hope it would put a 'default' value in based on the use of 'runThen', 'runElse' etc).
In my case - it's a program triggering from the change in status of an Insteon device. The NR is called from the 'Then' clause of the program. The Insteon device involved is exposed to Google Assistant - and I am using Google Assistant to turn the Insteon device on and off - triggering the program and then the NR.
