Windows 7 & Active x
Good morning
I have taken the step forward to Windows 7. I have a problem getting into your program with the system stating it needs to run Java 2+. I downloaded Java and thought this would solve the problem but windows is not letting me install active x. Do you have a solution?
Do you know if you are running 64-bit Windows? If so, consider downloading both the 32-bit and 64-bit version of Java and try again.
