Tag 1 and 2 seem to be reversed
Just a thought. The waiting seems to be on the tag mac addresses through the tag manager. The manager can only run at 10mb half duplex. Just wondering if it may be getting overwhelmed during install.
Thanks Gary
No, it's not waiting on the tag manager, it's trying to throttle adding nodes to the ISY so it doesn't overwhelm it.  But the udi_interface (the module between the NS and PG3) is multithreaded and not all python list functions are thread safe, so the code gets confused.  I need to figure out how to make the code thread safe, or use a Python mutex.
Hi, This is the procedure I used to get the tags loaded and working.
Thanks Gary
-Install
-Authorize
           Added TM node
           Halted with 'Discover thread is done'
-Set monitor tags true
           Added one tag with incomplete data.
           Waiting for add to complete.
           Six minutes later added second tag with incomplete data.
           Waiting again for add to complete.
           Continued with next step at this point.
-Restart
          The two tags got correct data.
-Did discover on tag manager node page.
           All tags loaded but with some incorrect data.
Restart
           All tags have correct date and working.
@garybixler
Hi
I am trying to get my tags running also and was asked to "set the monitor tags true in admin console"also.
I can't seem to find it anywhere.
Would you let me know where I find it.
Thanks Gary
-Install
-Authorize
           Added TM node
-Restart
Restart
Please PM me the log or email jimboca3@gmail.com
Thank you so much.
Some NSs where deleted in PG2 but not uninstalled which are now. I don't think that made any difference however.
Gary
Edited by garybixler
@Jimbo GREAT NEWS! I installed version 13 and clicked "Monitor Tags True" and everything loaded right away with all correct date.
Thanks so much for all your hard work.
Gary
