Not All Tag Parameters Fit in ISY Admin Console panel
vbPhil
Posted (edited)
Not sure if this is an ISY Admin Console phenomena or Node Server. On some of the tags like type 21 or 26 not all of the parameters fit on the screen even when maximized and lowest Font setting (12). I can see there are more parameters at the bottom but they're getting cut off and there's no vertical scroll bar. Is there some adjustment I can do to make the type smaller, so it fits?
Edited by vbphil
Added words Admin Console
@vbphil what's the "Scale and Layout" size on your Windows settings?
Windows 10 -> Settings -> System -> Display -> Scale and Layout
Make sure this is 100%. If still bad then not sure what to say.
They're set to 100%
If this is on IoP, UD is aware of it. I reported it last week and was told they would look at it.
Yes IoP. The font size for the nodes list in the left panel is fine but the right panel containing the device info has always had a mix of large and small sizes. It always looked clunky to me.
Here's what I see in IoP on my screen for the WirelessTag Node Server. You can see parameters cut off at the bottom and no way to scroll. If you ask me the font type for values is way too large. The field labels look appropriate. Not sure what determined what is used here, the Node Server, IoP or JAVA defaults.
UD is aware of this, it is a known bug in admin console. They haven't had a chance to correct it yet.
When I really need to access wild buttons in my admin console, I minimize my admin console and right click on my desktop to set my Windows 10 screen magnification back down to 100%.
When I am done squinting, I reverse the adjustment back to 150% so I can read other screen things. This has only been a problem since about 2006 and should be fixed any time. :):)
  • Like 1
That's been a problem as you indicate, but that's not what this is.
Some Nodeservers have so much information on a single page that even at @100% the information doesn't fit on one screen with admin console maximized. Weatherflow Node server for Tempest comes to mind.
On the 994 admin console there is a scroll bar to move down the page. The scroll bar is missing in the IoP admin console for Nodeservers making it impossible to all nodes.
      38.1k
      380.3k
