3 way switch
Insteon used to have the 2383 which had a yellow traveler wire. Found one but it is dead. I have a 4way setup that i would love to add 1 switch rather than replace all 3.
Sent from my SM-G960U using Tapatalk
I hope you find one.
You are talking a discontinued many years ago item and X10 transmit and receive only module.
Yes sux that they never replaced it. Its dead which is why i buried it in the garage the first time lol.
Posted (edited)
You can always swap to zwave devices. Some such as the Zooz zen71 allows you to use a standard switch with it.
Edited by lilyoyo1
You can always swapntonzwave devices. Some such as the Zooz zen71 allows you to use a standard switch with it.
Ill look into it. Easier than switching out 4 switches.
53 minutes ago, slimypizza said:
What is your configuration now?  What switches are you using?
Read the first post of the thread.   He was previously using a deprecated product Insteon 2383 which has a yellow travellor wire, there are 4 switches in the circuit so he prefers 2383 (which is long ago discontinued) instead of replacing all 4 with switches (that are not available anyway).
  • Like 1
Regular switches. I have a 4way setup
Just installed a ZEN 76 in a 3-way configuration replacing the one switch which had the power and load. Ordered three more to install in additional  4 way and  3 way configurations. They work great with the iop and can easily be added to a scene. Also parameters can be set up for use with smart bulbs etc. I am replacing all the Insteon 2443-222 micro modules. They were very susceptible to power line noise causing lights to turn on and off randomly.
  • Like 1
Been looking for the micr module as everything else out of stock
Just found my micro switch. In the instructions it says yellow wire is a sense for single momentary. Can i use this in addition to the 3 3way switches by using the sense wire on the traveler leg of my 14/3 going to the next switch
Posted (edited)
That is what I had done so I wouldn't need to replace any switches. I used latching as the 3-way switches are either on or off. Also I believe I used the common on the last 3-way. Will need to verify however. The only issue as mentioned above is that they are very sensitive to power line fluctuations. Also the length of one of my 4-way setups caused me to add a tie down resistor on the sense wire to prevent erratic behavior.
Edited by garybixler
Does every 3way switch in this 1 setup require a micro switch
Got it to work. I had to put it at the last switch going to light. Luckily i had a hot for a different light in the 1900 box. Grabbed line from another light. Load from micro to light then sense yellow to black screw on switch.
  • Like 1
Pm sent
