Does anybody know what circuitry is in this thing?
My brother had a really bad flicker problem with one overhead LED light which is controlled by an Insteon dimmer.
As a last resort he bought a dimming stabilizer from AArtech in Canada. - bought the "yellow" but there's a "blue" available as well.
He wasn't hopeful and if it didn't work he was going to give up and replace the dimmer with a regular switch.
This little device works amazingly well, flicker is gone and the dimming is very smooth as well.
Unfortunately it's pretty expensive so I was wondering if I could hack one together.
https://www.amazon.com/PCS-LDS-120V-Dimming-Stabilizer-120V/dp/B07B1LY2J9
Edited by mmb
Mostly a capacitor but possibly a series or parallel resistor also. Resistors take power to make them work and that produces heat and shows on energy and power meters. Capacitors draw current at 90 degrees ahead of the applied voltage which consumes volt-amperes, but very little power / heat / losses, while still drawing current to make the dimmer function properly.
The rating shows 1.4 watts so there is mostly only a capacitor inside.
The folks on the X10 Forums.
Also have had good results with the Dimming Stabilizer. With their two wire dimmers.
