New Install; Polisy Unable to communicate with PLM
pjjameso
Just received my Polisy and having an issue setting up using previous 2413s PLM.  I have insured that insteon and zwave are enabled and have rebooted ISY on Polisy.  Restored my 994 backup, but keep receiving comm errors, with PLM 0.0.0.0 unconnected.
Have factory reset Polisy, repeated the procedure to no avail. Reconnected my plm to the 994 and all works fine.  Just cant get the Polisy to connect to the PLM. Have tried both db9 ports far left and middle with same results.  Using same db9 cable that I was using with the 994
What am i doing wrong?
If you had the PLM plugged into Polisy- and powered prior to peeing up Polisy, there may be something wrong with your polisy. You'll want to submit a ticket
Edited by lilyoyo1
Does the PLM need to be plugged into the Polisy prior to the Polisy boot up? If thats the case I plugged in after the boot up.
Will give that a try...
Didnt make a difference booting up with PLM plugged into Polisy DB9.  Are the lights on the db9 port suppose to indicate any activity on PLM, if so then Polisy must be the issue.
Just to confirm, you're using the DB9 port and not the Ethernet port correct? I ask because the 994 doesn't have a DB9 port nor does polisy have 2 DB9 ports
Edited by lilyoyo1
  • Thanks 2
you're onto it.... he can't use the same cable he was using with the 994... and he doesn't know what a db9 port is...
Sorry wrong nomenclature.... not db9 but rj-45.
Have factory reset with PLM powered up and plugged into the Polisy. Triple checked that insteon and z wave are enabled after boot up.  Still no communication with PLM; not connected 0.0.0.0. PLM connected to middle rj-45 jack.
Edited by pjjameso
Elapsed 00:00:05.368 : Loading Variables
Elapsed 00:00:05.710 : Loading Node Definitions
Elapsed 00:00:06.441 : Loading Nodes
Elapsed 00:00:06.540 : Creating Widgets
Elapsed 00:00:07.717 : Creating Widgets Complete
Mon 04/07/1952 04:17:55 PM : Starting Subscription
Mon 04/07/1952 04:17:55 PM : Completing initialization
Mon 04/07/1952 04:17:55 PM : Refreshing Status
Mon 04/07/1952 04:17:55 PM : Refreshing Views
Mon 04/07/1952 04:18:00 PM : [ZWAVE-SERIAL    ] Using serial port [/dev/ttyU0]
Mon 04/07/1952 04:18:01 PM : [ZW-SOFT-REBOOT] START  - zwaveSoftReboot 0x7fffffffb950
Mon 04/07/1952 04:18:06 PM : Restarting the Z-Wave dongle
Mon 04/07/1952 04:18:13 PM : [ZW-SOFT-REBOOT] FINISH - zwaveSoftReboot 0x7fffffffb950
Mon 04/07/1952 04:18:14 PM : [ZWAVE-FW        ] Unrecognized Z-Wave firmware version/library [7.15]
Mon 04/07/1952 04:18:15 PM : Z-Wave Node ID    : 0x01 (1)
Mon 04/07/1952 04:18:15 PM : Primary           : true
Mon 04/07/1952 04:18:16 PM : [PLM         ] PLM not initialized, command not sent
See directions under insteon support in the wiki instruction manual.
https://wiki.universal-devices.com/index.php?title=Polisy:User_Guide
@pjjameso As @lilyoyo1 and @MrBill point out you cannot use the same cable you were using with the ISY994. You need the db9 plug to plug into the Polisy. If you have a serial PLM there was an additional wire in the box it came in.
This is the cord you need: https://smartenit.com/shop/plm-serial-cable/
Additionally, you can buy an adaptor from Amazon like this one - https://www.amazon.com/StarTech-com-Serial-adapter-DB-9-RJ-45/dp/B00006IRQA/
Dang, missed that point... was using rj-45 port as done with 994.  Now issue is it wont boot, just the right most light is lit.
Next steps?
Try doing a factory reset on the Polisy. Make sure you PLM is not plugged in and that your ethernet cable is plugged into the RJ45 port closest to the DB9 connector with the other end plugged into your router. Using the end of a paperclip push it into the hole on the right front of the Polisy and follow the directions below.
You'll need a DB9 to ethernet cable in order to interface the PLM with the Polisy. One came with you PLM, if you don't have it then you can buy one on Amazon
Factory Reset
Press and hold the button till all LEDs start blinking then release. This action resets the credentials, removes all configurations from Polyglot/Polisy, and resets networking.
1 hour ago, pjjameso said:
Next steps?
1) order a cable if you no longer have the one that came in the 2413s box
2) open a ticket support@universal-devices.com if you can’t boot your Polisy.
Thanks everyone, Polisy is dead, Michael is sending boot chip. Must admit I should have been more careful instead of just just assuming rj45 from 994 would plug into ports on Polisy.  Would have thought db9 ports long ago unused/deprecated and followed 994 mode. Dumb me…
Appreciate the help on my journey form insteon to…. Well at least i have two spares of PLM’s and keypads!
      380.1k
