Upgraded IoP to 5.4.3 and now cannot find Polisy.
I upgraded from 5.4.2 to 5.4.3 and ISY finder can not find polisy. I pinged the IP address and it pinged with out errors.
What is next??
Edited by tlightne
@tlightne You might try entering the Polisy Address manually in Launcher.
Click Add then enter the following. Using your local IP address for the Polisy
http://ip_addr:8080
Tryed the add from launcher also and get error "NOT FOUND"
It does show in Portal..
Edited by tlightne
Can you reach it in a web browser with:
http://ip_addr:8080/rest/nodes
Also try to open a terminal and ssh to it.
http://ip_addr:8080
I think you need to add the /desc when manually adding.....
http://ip_addr:8080/desc
also make certain you're replacing ip_addr with the actual IP address of Polisy.
Tried that with add getting not found. Tried with rest nodes and get site can't be reached. I can SSH into it using the ip address but it looks like the password has defaulted to admin. Tried to SSH with admin@polisy and get error could not resolve host name.
Edited by tlightne
ssh in and see if isy is running....
sudo service isy status
If its not start it
sudo service isy start
if it is, try restarting it
sudo service isy restart
ISY is running and it also restarts..
You've got the IP correct because you used it for ssh.
We've exhausted all standard troubleshooting.  You should open a ticket support@universal-devices.com
@mrbill I opened a ticket with support last night thank you for your help..
I needed to clear Java and reload start.jnlp.
Please be sure and circle back and let us know the outcome.?
Also when using the @ tagging/notify feature of the forum after you type the @ you see a popup list as you type @tlightne, example:
either click or use the down arrow to turn the text into a tag.  The automatic notification feature will only work if the plain text has been converted to a tag.
