bpwwer Posted September 5, 2022 Share Posted September 5, 2022 Try version 1.0.12 That should fix the errors. For the cases where the admin console isn't displaying correctly, has the admin console been restarted since installing the latest versions? It looks like it hasn't read the latest profile files which have been changing a bit with each version. 1 Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 I just tried 1.0.12 and pretty much the same results VueTest_9-5-2022_123733_PM.zipVueTest_9-5-2022_123733_PM.zip It wont let me up load the log email me at kevin@kevin-graff.com and I will send it to you Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 I take that back the first time I restarted it it did not do an up date Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 2022-09-05 12:46:13,892 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-09-05 12:46:16,133 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.47 Starting... 2022-09-05 12:46:16,883 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.0.63 [ISY: 5.4.4, Slot: 6] 2022-09-05 12:46:16,885 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.12.167', 'netmask': '255.255.255.0', 'broadcast': '192.168.12.255'} 2022-09-05 12:46:16,887 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:1888 2022-09-05 12:46:16,895 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'config': {'version': '1.0.12'}} 2022-09-05 12:46:16,945 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2022-09-05 12:46:16,947 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6 - MID: 1 Result: 0 2022-09-05 12:46:16,959 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-09-05 12:46:17,042 MQTT udi_interface.interface INFO interface:_message: Successfully set 136723 :: ST to 1 UOM 25 2022-09-05 12:46:19,907 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2022-09-05 12:46:20,136 Thread-2 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2022-09-05 12:46:20,140 Thread-2 udi_interface INFO vue:parameterHandler: Logging in to Emporia Cloud 2022-09-05 12:46:20,296 MQTT udi_interface.interface INFO interface:_message: custom data response {'customparamsdoc': '<h2>Configuration</h2>\n\n<p>The VUE node server has the following user configuration parameters:</p>\n\n<ul>\n<li>Username : Your emporia account username</li>\n<li>Password : Your emporia account password</li>\n</ul>\n'} 2022-09-05 12:46:20,315 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc 2022-09-05 12:46:20,364 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2022-09-05 12:46:20,651 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2022-09-05 12:46:51,999 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8072 UOM 30 2022-09-05 12:46:52,118 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0495 UOM 30 2022-09-05 12:46:52,202 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0353 UOM 30 2022-09-05 12:46:52,244 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1843 UOM 30 2022-09-05 12:46:52,373 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.4915 UOM 30 2022-09-05 12:46:53,741 Thread-50 udi_interface INFO vue:query: 1,2,3 -- 0.00022421790652804905 2022-09-05 12:46:53,742 Thread-50 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:46:53,742 Thread-50 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 12:46:53,743 Thread-50 udi_interface INFO vue:query: 4 -- 1.3759083218044706e-05 2022-09-05 12:46:53,744 Thread-50 udi_interface INFO vue:query: 5 -- 9.805979198879667e-06 2022-09-05 12:46:53,745 Thread-50 udi_interface INFO vue:query: 6 -- 5.120329115125868e-05 2022-09-05 12:46:53,746 Thread-50 udi_interface INFO vue:query: 7 -- 0.0001365352291531033 2022-09-05 12:46:53,746 Thread-50 udi_interface INFO vue:query: Balance -- 1.29143238067627e-05 2022-09-05 12:46:53,747 Thread-50 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:46:53,748 Thread-50 udi_interface ERROR udi_interface:write: Thread-50 2022-09-05 12:46:53,749 Thread-50 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:53,749 Thread-50 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:46:53,750 Thread-50 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:46:53,754 Thread-50 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:46:53,755 Thread-50 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:46:53,759 Thread-50 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:46:53,760 Thread-50 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:46:53,761 Thread-50 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:46:53,762 Thread-50 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:46:53,763 Thread-50 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:46:53,764 Thread-50 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:46:53,765 Thread-50 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:53,765 Thread-50 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:46:55,804 Thread-51 udi_interface INFO vue:query: 1,2,3 -- 0.00021972517649332683 2022-09-05 12:46:55,807 Thread-51 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:46:55,808 Thread-51 udi_interface INFO vue:query: 2 -- 1.7110508018069797e-06 2022-09-05 12:46:55,810 Thread-51 udi_interface INFO vue:query: 4 -- 1.3630153867933485e-05 2022-09-05 12:46:55,812 Thread-51 udi_interface INFO vue:query: 5 -- 8.88356261783176e-06 2022-09-05 12:46:55,814 Thread-51 udi_interface INFO vue:query: 6 -- 4.631779564751519e-05 2022-09-05 12:46:55,815 Thread-51 udi_interface INFO vue:query: 7 -- 0.00013817181057400175 2022-09-05 12:46:55,817 Thread-51 udi_interface INFO vue:query: Balance -- 1.101080298423766e-05 2022-09-05 12:46:55,818 Thread-51 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:46:55,819 Thread-51 udi_interface ERROR udi_interface:write: Thread-51 2022-09-05 12:46:55,820 Thread-51 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:55,820 Thread-51 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:46:55,821 Thread-51 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:46:55,825 Thread-51 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:46:55,826 Thread-51 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:46:55,830 Thread-51 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:46:55,831 Thread-51 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:46:55,832 Thread-51 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:46:55,833 Thread-51 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:46:55,834 Thread-51 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:46:55,835 Thread-51 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:46:55,836 Thread-51 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:55,837 Thread-51 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:46:56,038 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.791 UOM 30 2022-09-05 12:46:56,109 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0062 UOM 30 2022-09-05 12:46:56,196 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0491 UOM 30 2022-09-05 12:46:56,238 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.032 UOM 30 2022-09-05 12:46:56,352 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1667 UOM 30 2022-09-05 12:46:56,454 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.4974 UOM 30 2022-09-05 12:46:57,802 Thread-52 udi_interface INFO vue:query: 1,2,3 -- 0.0002193541505601671 2022-09-05 12:46:57,805 Thread-52 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:46:57,806 Thread-52 udi_interface INFO vue:query: 2 -- 1.8255102634429931e-06 2022-09-05 12:46:57,808 Thread-52 udi_interface INFO vue:query: 4 -- 1.4230773713853624e-05 2022-09-05 12:46:57,810 Thread-52 udi_interface INFO vue:query: 5 -- 9.402180777655707e-06 2022-09-05 12:46:57,812 Thread-52 udi_interface INFO vue:query: 6 -- 4.561585320366754e-05 2022-09-05 12:46:57,814 Thread-52 udi_interface INFO vue:query: 7 -- 0.0001396981472439236 2022-09-05 12:46:57,815 Thread-52 udi_interface INFO vue:query: Balance -- 8.581685357623617e-06 2022-09-05 12:46:57,816 Thread-52 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:46:57,817 Thread-52 udi_interface ERROR udi_interface:write: Thread-52 2022-09-05 12:46:57,818 Thread-52 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:57,818 Thread-52 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:46:57,819 Thread-52 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:46:57,823 Thread-52 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:46:57,824 Thread-52 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:46:57,828 Thread-52 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:46:57,829 Thread-52 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:46:57,830 Thread-52 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:46:57,831 Thread-52 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:46:57,832 Thread-52 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:46:57,833 Thread-52 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:46:57,834 Thread-52 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:57,834 Thread-52 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:46:57,990 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7897 UOM 30 2022-09-05 12:46:58,065 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0066 UOM 30 2022-09-05 12:46:58,147 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0512 UOM 30 2022-09-05 12:46:58,236 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0338 UOM 30 2022-09-05 12:46:58,324 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1642 UOM 30 2022-09-05 12:46:58,434 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5029 UOM 30 2022-09-05 12:46:59,876 Thread-53 udi_interface INFO vue:query: 1,2,3 -- 0.00022002950032552084 2022-09-05 12:46:59,879 Thread-53 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:46:59,880 Thread-53 udi_interface INFO vue:query: 2 -- 1.5603140989939373e-06 2022-09-05 12:46:59,882 Thread-53 udi_interface INFO vue:query: 4 -- 1.361304071214464e-05 2022-09-05 12:46:59,884 Thread-53 udi_interface INFO vue:query: 5 -- 9.806564119127061e-06 2022-09-05 12:46:59,886 Thread-53 udi_interface INFO vue:query: 6 -- 4.490939670138889e-05 2022-09-05 12:46:59,888 Thread-53 udi_interface INFO vue:query: 7 -- 0.00013913089328342014 2022-09-05 12:46:59,890 Thread-53 udi_interface INFO vue:query: Balance -- 1.1009291410446178e-05 2022-09-05 12:46:59,891 Thread-53 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:46:59,891 Thread-53 udi_interface ERROR udi_interface:write: Thread-53 2022-09-05 12:46:59,892 Thread-53 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:59,893 Thread-53 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:46:59,894 Thread-53 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:46:59,898 Thread-53 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:46:59,899 Thread-53 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:46:59,903 Thread-53 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:46:59,904 Thread-53 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:46:59,906 Thread-53 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:46:59,906 Thread-53 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:46:59,908 Thread-53 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:46:59,909 Thread-53 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:46:59,909 Thread-53 udi_interface ERROR udi_interface:write: : 2022-09-05 12:46:59,910 Thread-53 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:00,056 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7921 UOM 30 2022-09-05 12:47:00,166 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0056 UOM 30 2022-09-05 12:47:00,208 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.049 UOM 30 2022-09-05 12:47:00,304 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0353 UOM 30 2022-09-05 12:47:00,404 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1617 UOM 30 2022-09-05 12:47:00,500 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5009 UOM 30 2022-09-05 12:47:01,890 Thread-54 udi_interface INFO vue:query: 1,2,3 -- 0.00021963940090603297 2022-09-05 12:47:01,893 Thread-54 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:01,894 Thread-54 udi_interface INFO vue:query: 2 -- 1.4915472931332058e-06 2022-09-05 12:47:01,896 Thread-54 udi_interface INFO vue:query: 4 -- 1.4149997499254015e-05 2022-09-05 12:47:01,898 Thread-54 udi_interface INFO vue:query: 5 -- 8.706749280293783e-06 2022-09-05 12:47:01,900 Thread-54 udi_interface INFO vue:query: 6 -- 4.614149729410808e-05 2022-09-05 12:47:01,902 Thread-54 udi_interface INFO vue:query: 7 -- 0.00013888375176323783 2022-09-05 12:47:01,904 Thread-54 udi_interface INFO vue:query: Balance -- 1.0265857776006038e-05 2022-09-05 12:47:01,905 Thread-54 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:01,905 Thread-54 udi_interface ERROR udi_interface:write: Thread-54 2022-09-05 12:47:01,906 Thread-54 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:01,907 Thread-54 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:01,908 Thread-54 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:01,912 Thread-54 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:01,913 Thread-54 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:01,917 Thread-54 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:01,918 Thread-54 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:01,920 Thread-54 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:01,921 Thread-54 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:01,922 Thread-54 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:01,923 Thread-54 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:01,924 Thread-54 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:01,924 Thread-54 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:02,101 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7907 UOM 30 2022-09-05 12:47:02,205 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0054 UOM 30 2022-09-05 12:47:02,290 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0509 UOM 30 2022-09-05 12:47:02,332 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0313 UOM 30 2022-09-05 12:47:02,423 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1661 UOM 30 2022-09-05 12:47:02,527 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5 UOM 30 2022-09-05 12:47:03,820 Thread-55 udi_interface INFO vue:query: 1,2,3 -- 0.00021963940090603297 2022-09-05 12:47:03,821 Thread-55 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:03,822 Thread-55 udi_interface INFO vue:query: 2 -- 1.4915472931332058e-06 2022-09-05 12:47:03,823 Thread-55 udi_interface INFO vue:query: 4 -- 1.4149997499254015e-05 2022-09-05 12:47:03,824 Thread-55 udi_interface INFO vue:query: 5 -- 8.706749280293783e-06 2022-09-05 12:47:03,824 Thread-55 udi_interface INFO vue:query: 6 -- 4.614149729410808e-05 2022-09-05 12:47:03,825 Thread-55 udi_interface INFO vue:query: 7 -- 0.00013888375176323783 2022-09-05 12:47:03,826 Thread-55 udi_interface INFO vue:query: Balance -- 1.0265857776006038e-05 2022-09-05 12:47:03,827 Thread-55 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:03,828 Thread-55 udi_interface ERROR udi_interface:write: Thread-55 2022-09-05 12:47:03,828 Thread-55 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:03,829 Thread-55 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:03,830 Thread-55 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:03,834 Thread-55 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:03,835 Thread-55 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:03,838 Thread-55 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:03,839 Thread-55 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:03,841 Thread-55 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:03,841 Thread-55 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:03,843 Thread-55 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:03,844 Thread-55 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:03,844 Thread-55 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:03,845 Thread-55 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:05,883 Thread-56 udi_interface INFO vue:query: 1,2,3 -- 0.00022286105261908637 2022-09-05 12:47:05,886 Thread-56 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:05,887 Thread-56 udi_interface INFO vue:query: 2 -- 1.6412556171417235e-06 2022-09-05 12:47:05,889 Thread-56 udi_interface INFO vue:query: 4 -- 1.4209472868177626e-05 2022-09-05 12:47:05,891 Thread-56 udi_interface INFO vue:query: 5 -- 1.1398273044162326e-05 2022-09-05 12:47:05,892 Thread-56 udi_interface INFO vue:query: 6 -- 4.472217135959201e-05 2022-09-05 12:47:05,894 Thread-56 udi_interface INFO vue:query: 7 -- 0.00014036916097005212 2022-09-05 12:47:05,896 Thread-56 udi_interface INFO vue:query: Balance -- 1.0520718759960567e-05 2022-09-05 12:47:05,897 Thread-56 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:05,898 Thread-56 udi_interface ERROR udi_interface:write: Thread-56 2022-09-05 12:47:05,899 Thread-56 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:05,899 Thread-56 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:05,900 Thread-56 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:05,904 Thread-56 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:05,905 Thread-56 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:05,909 Thread-56 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:05,910 Thread-56 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:05,912 Thread-56 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:05,913 Thread-56 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:05,914 Thread-56 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:05,915 Thread-56 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:05,916 Thread-56 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:05,916 Thread-56 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:06,268 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8023 UOM 30 2022-09-05 12:47:06,354 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0059 UOM 30 2022-09-05 12:47:06,445 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0512 UOM 30 2022-09-05 12:47:06,544 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.041 UOM 30 2022-09-05 12:47:06,646 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.161 UOM 30 2022-09-05 12:47:06,747 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5053 UOM 30 2022-09-05 12:47:07,875 Thread-57 udi_interface INFO vue:query: 1,2,3 -- 0.0002174339803059896 2022-09-05 12:47:07,878 Thread-57 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:07,878 Thread-57 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 12:47:07,879 Thread-57 udi_interface INFO vue:query: 4 -- 1.3554931216769749e-05 2022-09-05 12:47:07,881 Thread-57 udi_interface INFO vue:query: 5 -- 9.549439748128255e-06 2022-09-05 12:47:07,883 Thread-57 udi_interface INFO vue:query: 6 -- 4.1340679592556425e-05 2022-09-05 12:47:07,885 Thread-57 udi_interface INFO vue:query: 7 -- 0.00013995942857530382 2022-09-05 12:47:07,887 Thread-57 udi_interface INFO vue:query: Balance -- 1.3029501173231347e-05 2022-09-05 12:47:07,888 Thread-57 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:07,889 Thread-57 udi_interface ERROR udi_interface:write: Thread-57 2022-09-05 12:47:07,889 Thread-57 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:07,890 Thread-57 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:07,891 Thread-57 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:07,895 Thread-57 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:07,896 Thread-57 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:07,899 Thread-57 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:07,900 Thread-57 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:07,902 Thread-57 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:07,903 Thread-57 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:07,905 Thread-57 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:07,906 Thread-57 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:07,906 Thread-57 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:07,907 Thread-57 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:08,034 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7828 UOM 30 2022-09-05 12:47:08,130 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0488 UOM 30 2022-09-05 12:47:08,212 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0344 UOM 30 2022-09-05 12:47:08,304 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1488 UOM 30 2022-09-05 12:47:08,402 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5039 UOM 30 2022-09-05 12:47:09,925 Thread-58 udi_interface INFO vue:query: 1,2,3 -- 0.00021209102206759984 2022-09-05 12:47:09,927 Thread-58 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:09,928 Thread-58 udi_interface INFO vue:query: 2 -- 1.8087021509806315e-06 2022-09-05 12:47:09,930 Thread-58 udi_interface INFO vue:query: 4 -- 1.3718508614434137e-05 2022-09-05 12:47:09,933 Thread-58 udi_interface INFO vue:query: 5 -- 8.97761132982042e-06 2022-09-05 12:47:09,934 Thread-58 udi_interface INFO vue:query: 6 -- 3.6356268988715276e-05 2022-09-05 12:47:09,936 Thread-58 udi_interface INFO vue:query: 7 -- 0.0001402501000298394 2022-09-05 12:47:09,938 Thread-58 udi_interface INFO vue:query: Balance -- 1.0979830953809956e-05 2022-09-05 12:47:09,939 Thread-58 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:09,940 Thread-58 udi_interface ERROR udi_interface:write: Thread-58 2022-09-05 12:47:09,940 Thread-58 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:09,941 Thread-58 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:09,942 Thread-58 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:09,946 Thread-58 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:09,947 Thread-58 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:09,951 Thread-58 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:09,952 Thread-58 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:09,954 Thread-58 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:09,954 Thread-58 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:09,956 Thread-58 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:09,957 Thread-58 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:09,957 Thread-58 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:09,958 Thread-58 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:10,102 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7635 UOM 30 2022-09-05 12:47:10,193 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0065 UOM 30 2022-09-05 12:47:10,274 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0494 UOM 30 2022-09-05 12:47:10,360 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0323 UOM 30 2022-09-05 12:47:10,448 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1309 UOM 30 2022-09-05 12:47:10,548 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5049 UOM 30 2022-09-05 12:47:11,858 Thread-59 udi_interface INFO vue:query: 1,2,3 -- 0.0002142180379231771 2022-09-05 12:47:11,861 Thread-59 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:11,862 Thread-59 udi_interface INFO vue:query: 2 -- 1.5809538629319932e-06 2022-09-05 12:47:11,864 Thread-59 udi_interface INFO vue:query: 4 -- 1.357675340440538e-05 2022-09-05 12:47:11,866 Thread-59 udi_interface INFO vue:query: 5 -- 9.500838385687934e-06 2022-09-05 12:47:11,868 Thread-59 udi_interface INFO vue:query: 6 -- 3.7045309278700085e-05 2022-09-05 12:47:11,869 Thread-59 udi_interface INFO vue:query: 7 -- 0.00014167283799913194 2022-09-05 12:47:11,871 Thread-59 udi_interface INFO vue:query: Balance -- 1.0841344992319773e-05 2022-09-05 12:47:11,872 Thread-59 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:11,873 Thread-59 udi_interface ERROR udi_interface:write: Thread-59 2022-09-05 12:47:11,874 Thread-59 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:11,874 Thread-59 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:11,875 Thread-59 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:11,879 Thread-59 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:11,880 Thread-59 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:11,884 Thread-59 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:11,885 Thread-59 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:11,887 Thread-59 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:11,887 Thread-59 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:11,889 Thread-59 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:11,889 Thread-59 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:11,890 Thread-59 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:11,891 Thread-59 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:12,037 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7712 UOM 30 2022-09-05 12:47:12,153 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0057 UOM 30 2022-09-05 12:47:12,242 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0489 UOM 30 2022-09-05 12:47:12,323 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0342 UOM 30 2022-09-05 12:47:12,366 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1334 UOM 30 2022-09-05 12:47:12,486 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.51 UOM 30 2022-09-05 12:47:13,910 Thread-60 udi_interface INFO vue:query: 1,2,3 -- 0.0002115064451429579 2022-09-05 12:47:13,913 Thread-60 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 12:47:13,914 Thread-60 udi_interface INFO vue:query: 2 -- 1.6172479258643256e-06 2022-09-05 12:47:13,916 Thread-60 udi_interface INFO vue:query: 4 -- 1.4004463619656033e-05 2022-09-05 12:47:13,918 Thread-60 udi_interface INFO vue:query: 5 -- 9.21553717719184e-06 2022-09-05 12:47:13,920 Thread-60 udi_interface INFO vue:query: 6 -- 3.7114473978678386e-05 2022-09-05 12:47:13,921 Thread-60 udi_interface INFO vue:query: 7 -- 0.00013833665635850693 2022-09-05 12:47:13,923 Thread-60 udi_interface INFO vue:query: Balance -- 1.121806608306037e-05 2022-09-05 12:47:13,924 Thread-60 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 12:47:13,925 Thread-60 udi_interface ERROR udi_interface:write: Thread-60 2022-09-05 12:47:13,926 Thread-60 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:13,926 Thread-60 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 12:47:13,927 Thread-60 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 12:47:13,931 Thread-60 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 12:47:13,932 Thread-60 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 12:47:13,936 Thread-60 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 12:47:13,937 Thread-60 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 12:47:13,939 Thread-60 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 12:47:13,940 Thread-60 udi_interface ERROR udi_interface:write: File "./vue.py", line 54, in query 2022-09-05 12:47:13,941 Thread-60 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 12:47:13,942 Thread-60 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 12:47:13,943 Thread-60 udi_interface ERROR udi_interface:write: : 2022-09-05 12:47:13,943 Thread-60 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 12:47:14,087 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.7614 UOM 30 2022-09-05 12:47:14,163 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0058 UOM 30 2022-09-05 12:47:14,245 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0504 UOM 30 2022-09-05 12:47:14,330 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0332 UOM 30 2022-09-05 12:47:14,438 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1336 UOM 30 2022-09-05 12:47:14,538 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.498 UOM 30 I did restart the admin Link to comment
tazman Posted September 5, 2022 Share Posted September 5, 2022 @bpwwerI still only get 13 ct's and the car charger with no main emporia VUE node. I wish I could upload the log file for you but it will not work for me. Ihave no values on the nodes that are created also. 2022-09-05 09:27:25,413 Thread-29 udi_interface INFO vue:discover: GID: 31548 2022-09-05 09:27:25,414 Thread-29 udi_interface INFO vue:discover: Manufacturer: SXA2040A04B48CAAB5BA76FC 2022-09-05 09:27:25,415 Thread-29 udi_interface INFO vue:discover: Model: WAT001 2022-09-05 09:27:25,415 Thread-29 udi_interface INFO vue:discover: Firmware: None 2022-09-05 09:27:25,416 Thread-29 udi_interface INFO vue:discover: Name: Home 2022-09-05 09:27:25,417 Thread-29 udi_interface INFO vue:discover: Found channel: 1 - Solar 2022-09-05 09:27:25,418 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_1 not found in database. 2022-09-05 09:27:25,419 Thread-29 udi_interface.interface INFO interface:addNode: Adding node Solar(31548_1) [None] 2022-09-05 09:27:25,420 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_1', 'name': 'Solar', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,422 Thread-29 udi_interface INFO vue:discover: Found channel: 2 - Solar 2022-09-05 09:27:25,424 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_2 not found in database. 2022-09-05 09:27:25,424 Thread-29 udi_interface.interface INFO interface:addNode: Adding node Solar(31548_2) [None] 2022-09-05 09:27:25,425 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_2', 'name': 'Solar', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,427 Thread-29 udi_interface INFO vue:discover: Found channel: 3 - C OS Rec & Bathroom Rec 2022-09-05 09:27:25,429 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_3 not found in database. 2022-09-05 09:27:25,430 Thread-29 udi_interface.interface INFO interface:addNode: Adding node C OS Rec & Bathroom Rec(31548_3) [None] 2022-09-05 09:27:25,431 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_3', 'name': 'C OS Rec & Bathroom Rec', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,433 Thread-29 udi_interface INFO vue:discover: Found channel: 4 - C Furnace 2022-09-05 09:27:25,434 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_4 not found in database. 2022-09-05 09:27:25,435 Thread-29 udi_interface.interface INFO interface:addNode: Adding node C Furnace(31548_4) [None] 2022-09-05 09:27:25,436 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_4', 'name': 'C Furnace', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,438 Thread-29 udi_interface INFO vue:discover: Found channel: 5 - C Refrigerator 2022-09-05 09:27:25,440 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_5 not found in database. 2022-09-05 09:27:25,440 Thread-29 udi_interface.interface INFO interface:addNode: Adding node C Refrigerator(31548_5) [None] 2022-09-05 09:27:25,441 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_5', 'name': 'C Refrigerator', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,443 Thread-29 udi_interface INFO vue:discover: Found channel: 6 - C Closet Equipment 2022-09-05 09:27:25,445 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_6 not found in database. 2022-09-05 09:27:25,446 Thread-29 udi_interface.interface INFO interface:addNode: Adding node C Closet Equipment(31548_6) [None] 2022-09-05 09:27:25,447 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_6', 'name': 'C Closet Equipment', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,448 Thread-29 udi_interface INFO vue:discover: Found channel: 7 - Kitchen Receptacles 2022-09-05 09:27:25,450 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_7 not found in database. 2022-09-05 09:27:25,451 Thread-29 udi_interface.interface INFO interface:addNode: Adding node Kitchen Receptacles(31548_7) [None] 2022-09-05 09:27:25,452 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_7', 'name': 'Kitchen Receptacles', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,453 Thread-29 udi_interface INFO vue:discover: Found channel: 8 - B MW Land Rec & Lt 2022-09-05 09:27:25,455 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_8 not found in database. 2022-09-05 09:27:25,456 Thread-29 udi_interface.interface INFO interface:addNode: Adding node B MW Land Rec & Lt(31548_8) [None] 2022-09-05 09:27:25,457 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_8', 'name': 'B MW Land Rec & Lt', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,459 Thread-29 udi_interface INFO vue:discover: Found channel: 9 - C Clothes Washer/Dryer 2022-09-05 09:27:25,460 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_9 not found in database. 2022-09-05 09:27:25,461 Thread-29 udi_interface.interface INFO interface:addNode: Adding node C Clothes Washer/Dryer(31548_9) [None] 2022-09-05 09:27:25,462 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_9', 'name': 'C Clothes Washer/Dryer', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,464 Thread-29 udi_interface INFO vue:discover: Found channel: 10 - C Kitchen Receptacles 2022-09-05 09:27:25,465 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_10 not found in database. 2022-09-05 09:27:25,466 Thread-29 udi_interface.interface INFO interface:addNode: Adding node C Kitchen Receptacles(31548_10) [None] 2022-09-05 09:27:25,467 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_10', 'name': 'C Kitchen Receptacles', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,468 Thread-29 udi_interface INFO vue:discover: Found channel: 11 - B Living Room 2022-09-05 09:27:25,470 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_11 not found in database. 2022-09-05 09:27:25,471 Thread-29 udi_interface.interface INFO interface:addNode: Adding node B Living Room(31548_11) [None] 2022-09-05 09:27:25,471 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_11', 'name': 'B Living Room', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,473 Thread-29 udi_interface INFO vue:discover: Found channel: 12 - B Master and Bedroom 2 2022-09-05 09:27:25,475 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_12 not found in database. 2022-09-05 09:27:25,475 Thread-29 udi_interface.interface INFO interface:addNode: Adding node B Master and Bedroom 2(31548_12) [None] 2022-09-05 09:27:25,476 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_12', 'name': 'B Master and Bedroom 2', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,478 Thread-29 udi_interface INFO vue:discover: Found channel: 13 - B Kitchen and Outside Lt 2022-09-05 09:27:25,479 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_13 not found in database. 2022-09-05 09:27:25,480 Thread-29 udi_interface.interface INFO interface:addNode: Adding node B Kitchen and Outside Lt(31548_13) [None] 2022-09-05 09:27:25,481 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_13', 'name': 'B Kitchen and Outside Lt', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,482 Thread-29 udi_interface INFO vue:discover: Found channel: 14 - B Office and Bathroom Lt 2022-09-05 09:27:25,484 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_14 not found in database. 2022-09-05 09:27:25,485 Thread-29 udi_interface.interface INFO interface:addNode: Adding node B Office and Bathroom Lt(31548_14) [None] 2022-09-05 09:27:25,485 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_14', 'name': 'B Office and Bathroom Lt', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,487 Thread-29 udi_interface INFO vue:discover: Found channel: 15 - Range 2022-09-05 09:27:25,488 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_15 not found in database. 2022-09-05 09:27:25,489 Thread-29 udi_interface.interface INFO interface:addNode: Adding node Range(31548_15) [None] 2022-09-05 09:27:25,490 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_15', 'name': 'Range', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,491 Thread-29 udi_interface INFO vue:discover: Found channel: 16 - Air Conditioner 2022-09-05 09:27:25,493 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 31548_16 not found in database. 2022-09-05 09:27:25,494 Thread-29 udi_interface.interface INFO interface:addNode: Adding node Air Conditioner(31548_16) [None] 2022-09-05 09:27:25,494 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '31548_16', 'name': 'Air Conditioner', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,756 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-09-05 09:27:25,762 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-09-05 09:27:25,873 Thread-29 udi_interface INFO vue:discover: GID: 81882 2022-09-05 09:27:25,874 Thread-29 udi_interface INFO vue:discover: Manufacturer: D2135A090198CDACB02678 2022-09-05 09:27:25,875 Thread-29 udi_interface INFO vue:discover: Model: VVDN01 2022-09-05 09:27:25,876 Thread-29 udi_interface INFO vue:discover: Firmware: EVCharger-145 2022-09-05 09:27:25,877 Thread-29 udi_interface INFO vue:discover: Name: Tesla 2022-09-05 09:27:25,878 Thread-29 udi_interface INFO vue:discover: Charge rate: 14 2022-09-05 09:27:25,878 Thread-29 udi_interface INFO vue:discover: Max charge rate: 24 2022-09-05 09:27:25,879 Thread-29 udi_interface INFO vue:discover: Creating device node for Tesla (81882) 2022-09-05 09:27:25,881 Thread-29 udi_interface.interface WARNING interface:db_getNodeDrivers: 81882 not found in database. 2022-09-05 09:27:25,882 Thread-29 udi_interface.interface INFO interface:addNode: Adding node Tesla(81882) [None] 2022-09-05 09:27:25,883 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'addnode': [{'address': '81882', 'name': 'Tesla', 'nodeDefId': 'charger', 'primaryNode': '81882', 'drivers': [{'driver': 'ST', 'value': 1, 'uom': 25}, {'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}, {'driver': 'GV4', 'value': 0, 'uom': 30}, {'driver': 'GV5', 'value': 0, 'uom': 30}], 'hint': [0, 0, 0, 0], 'private': None}]} 2022-09-05 09:27:25,886 Thread-29 udi_interface INFO vue:discover: Found channel: 1,2,3 - None 2022-09-05 09:27:26,276 Thread-29 udi_interface INFO vue:query: 1,2,3 -- -0.755813819220331 2022-09-05 09:27:26,278 Thread-29 udi_interface.node DEBUG node:setDriver: 31548:Home Reporting set GV1 to -0.7558 to Polyglot 2022-09-05 09:27:26,279 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to -0.7558 2022-09-05 09:27:26,279 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548', 'driver': 'GV1', 'value': '-0.7558', 'uom': 33}]} 2022-09-05 09:27:26,281 Thread-29 udi_interface INFO vue:query: 1 -- -0.6419989378526476 2022-09-05 09:27:26,282 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_1:Solar Reporting set GV1 to -0.642 to Polyglot 2022-09-05 09:27:26,283 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to -0.642 2022-09-05 09:27:26,284 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_1', 'driver': 'GV1', 'value': '-0.642', 'uom': 33}]} 2022-09-05 09:27:26,285 Thread-29 udi_interface INFO vue:query: 2 -- -0.6437809900241428 2022-09-05 09:27:26,286 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_2:Solar Reporting set GV1 to -0.6438 to Polyglot 2022-09-05 09:27:26,287 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to -0.6438 2022-09-05 09:27:26,288 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_2', 'driver': 'GV1', 'value': '-0.6438', 'uom': 33}]} 2022-09-05 09:27:26,289 Thread-29 udi_interface INFO vue:query: 3 -- 0.01052480316956838 2022-09-05 09:27:26,290 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_3:C OS Rec & Bathroom Rec Reporting set GV1 to 0.0105 to Polyglot 2022-09-05 09:27:26,291 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0105 2022-09-05 09:27:26,292 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_3', 'driver': 'GV1', 'value': '0.0105', 'uom': 33}]} 2022-09-05 09:27:26,293 Thread-29 udi_interface INFO vue:query: 4 -- 0.0582486540140046 2022-09-05 09:27:26,294 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_4:C Furnace Reporting set GV1 to 0.0582 to Polyglot 2022-09-05 09:27:26,296 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0582 2022-09-05 09:27:26,297 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2022-09-05 09:27:26,298 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_4', 'driver': 'GV1', 'value': '0.0582', 'uom': 33}]} 2022-09-05 09:27:26,300 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode 2022-09-05 09:27:26,302 Thread-29 udi_interface INFO vue:query: 5 -- 0.04111560547298855 2022-09-05 09:27:26,304 Command udi_interface.interface DEBUG interface:_handleResult: add node response: {'id': '13e398d5-3fa8-473c-aa53-6caf29f35b92', 'uuid': '00:0d:b9:53:d3:9c', 'profileNum': 9, 'address': '31548', 'name': 'Home', 'nodeDefId': 'controller', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '31548', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1662395245647, 'timeModified': 1662395245647, 'dbVersion': 1} 2022-09-05 09:27:26,306 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_5:C Refrigerator Reporting set GV1 to 0.0411 to Polyglot 2022-09-05 09:27:26,308 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0411 2022-09-05 09:27:26,309 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_5', 'driver': 'GV1', 'value': '0.0411', 'uom': 33}]} 2022-09-05 09:27:26,311 Thread-29 udi_interface INFO vue:query: 6 -- 0.006787530011865828 2022-09-05 09:27:26,312 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_6:C Closet Equipment Reporting set GV1 to 0.0068 to Polyglot 2022-09-05 09:27:26,313 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0068 2022-09-05 09:27:26,313 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_6', 'driver': 'GV1', 'value': '0.0068', 'uom': 33}]} 2022-09-05 09:27:26,315 Thread-29 udi_interface INFO vue:query: 7 -- 0.0 2022-09-05 09:27:26,316 Thread-29 udi_interface INFO vue:query: 8 -- 0.00036376967986424764 2022-09-05 09:27:26,317 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_8:B MW Land Rec & Lt Reporting set GV1 to 0.0004 to Polyglot 2022-09-05 09:27:26,318 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0004 2022-09-05 09:27:26,319 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_8', 'driver': 'GV1', 'value': '0.0004', 'uom': 33}]} 2022-09-05 09:27:26,320 Thread-29 udi_interface INFO vue:query: 9 -- 0.0 2022-09-05 09:27:26,321 Thread-29 udi_interface INFO vue:query: 10 -- 0.00011335965408219232 2022-09-05 09:27:26,322 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_10:C Kitchen Receptacles Reporting set GV1 to 0.0001 to Polyglot 2022-09-05 09:27:26,323 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0001 2022-09-05 09:27:26,324 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_10', 'driver': 'GV1', 'value': '0.0001', 'uom': 33}]} 2022-09-05 09:27:26,325 Thread-29 udi_interface INFO vue:query: 11 -- 0.14081833318922254 2022-09-05 09:27:26,327 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_11:B Living Room Reporting set GV1 to 0.1408 to Polyglot 2022-09-05 09:27:26,328 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.1408 2022-09-05 09:27:26,329 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_11', 'driver': 'GV1', 'value': '0.1408', 'uom': 33}]} 2022-09-05 09:27:26,330 Thread-29 udi_interface INFO vue:query: 12 -- 0.00638071743965149 2022-09-05 09:27:26,331 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_12:B Master and Bedroom 2 Reporting set GV1 to 0.0064 to Polyglot 2022-09-05 09:27:26,332 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0064 2022-09-05 09:27:26,333 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_12', 'driver': 'GV1', 'value': '0.0064', 'uom': 33}]} 2022-09-05 09:27:26,334 Thread-29 udi_interface INFO vue:query: 13 -- 0.0014531943519910176 2022-09-05 09:27:26,336 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_13:B Kitchen and Outside Lt Reporting set GV1 to 0.0015 to Polyglot 2022-09-05 09:27:26,337 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0015 2022-09-05 09:27:26,338 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_13', 'driver': 'GV1', 'value': '0.0015', 'uom': 33}]} 2022-09-05 09:27:26,340 Thread-29 udi_interface INFO vue:query: 14 -- 0.0038485709830125172 2022-09-05 09:27:26,341 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_14:B Office and Bathroom Lt Reporting set GV1 to 0.0038 to Polyglot 2022-09-05 09:27:26,342 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0038 2022-09-05 09:27:26,343 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_14', 'driver': 'GV1', 'value': '0.0038', 'uom': 33}]} 2022-09-05 09:27:26,345 Thread-29 udi_interface INFO vue:query: 15 -- 0.0 2022-09-05 09:27:26,345 Thread-29 udi_interface INFO vue:query: 16 -- 0.24140942640516497 2022-09-05 09:27:26,346 Thread-29 udi_interface.node DEBUG node:setDriver: 31548_16:Air Conditioner Reporting set GV1 to 0.2414 to Polyglot 2022-09-05 09:27:26,347 Thread-29 udi_interface.node DEBUG node:reportDriver: Updating value to 0.2414 2022-09-05 09:27:26,348 Thread-29 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_16', 'driver': 'GV1', 'value': '0.2414', 'uom': 33}]} 2022-09-05 09:27:26,350 Thread-29 udi_interface INFO vue:query: TotalUsage -- 0.5299661086564593 2022-09-05 09:27:26,351 Thread-29 udi_interface ERROR vue:parameterHandler: Discovery failed: 'NoneType' object has no attribute 'update_hour' 2022-09-05 09:27:27,868 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-09-05 09:27:27,870 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-09-05 09:27:28,277 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2022-09-05 09:27:28,278 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode 2022-09-05 09:27:28,280 Command udi_interface.interface DEBUG interface:_handleResult: add node response: {'id': '6732a70f-1717-4050-9018-07ede9aa6315', 'uuid': '00:0d:b9:53:d3:9c', 'profileNum': 9, 'address': '31548_1', 'name': 'Solar', 'nodeDefId': 'channel', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '31548', 'private': None, 'isPrimary': 0, 'enabled': 1, 'timeAdded': 1662395246898, 'timeModified': 1662395246898, 'dbVersion': 1} 2022-09-05 09:27:28,303 Thread-36 udi_interface INFO vue:query: 1,2,3 -- -9.288475884331598e-05 2022-09-05 09:27:28,304 Thread-36 udi_interface.node DEBUG node:setDriver: 31548:Home Reporting set CPW to -0.3344 to Polyglot 2022-09-05 09:27:28,305 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to -0.3344 2022-09-05 09:27:28,306 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548', 'driver': 'CPW', 'value': '-0.3344', 'uom': 30}]} 2022-09-05 09:27:28,307 Thread-36 udi_interface INFO vue:query: 1 -- -0.0004592398410373264 2022-09-05 09:27:28,308 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_1:Solar Reporting set CPW to -1.6533 to Polyglot 2022-09-05 09:27:28,309 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to -1.6533 2022-09-05 09:27:28,310 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_1', 'driver': 'CPW', 'value': '-1.6533', 'uom': 30}]} 2022-09-05 09:27:28,311 Thread-36 udi_interface INFO vue:query: 2 -- -0.0004605852593315972 2022-09-05 09:27:28,312 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_2:Solar Reporting set CPW to -1.6581 to Polyglot 2022-09-05 09:27:28,313 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to -1.6581 2022-09-05 09:27:28,314 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_2', 'driver': 'CPW', 'value': '-1.6581', 'uom': 30}]} 2022-09-05 09:27:28,315 Thread-36 udi_interface INFO vue:query: 3 -- 6.9147258334689675e-06 2022-09-05 09:27:28,316 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_3:C OS Rec & Bathroom Rec Reporting set CPW to 0.0249 to Polyglot 2022-09-05 09:27:28,316 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0249 2022-09-05 09:27:28,317 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_3', 'driver': 'CPW', 'value': '0.0249', 'uom': 30}]} 2022-09-05 09:27:28,318 Thread-36 udi_interface INFO vue:query: 4 -- 0.00011556772867838541 2022-09-05 09:27:28,319 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_4:C Furnace Reporting set CPW to 0.416 to Polyglot 2022-09-05 09:27:28,320 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.416 2022-09-05 09:27:28,321 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_4', 'driver': 'CPW', 'value': '0.416', 'uom': 30}]} 2022-09-05 09:27:28,322 Thread-36 udi_interface INFO vue:query: 5 -- 2.8380781809488933e-05 2022-09-05 09:27:28,323 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_5:C Refrigerator Reporting set CPW to 0.1022 to Polyglot 2022-09-05 09:27:28,324 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.1022 2022-09-05 09:27:28,325 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_5', 'driver': 'CPW', 'value': '0.1022', 'uom': 30}]} 2022-09-05 09:27:28,326 Thread-36 udi_interface INFO vue:query: 6 -- 4.568396674262153e-06 2022-09-05 09:27:28,327 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_6:C Closet Equipment Reporting set CPW to 0.0164 to Polyglot 2022-09-05 09:27:28,328 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0164 2022-09-05 09:27:28,329 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_6', 'driver': 'CPW', 'value': '0.0164', 'uom': 30}]} 2022-09-05 09:27:28,330 Thread-36 udi_interface INFO vue:query: 7 -- 0.0 2022-09-05 09:27:28,331 Thread-36 udi_interface INFO vue:query: 8 -- 0.0 2022-09-05 09:27:28,331 Thread-36 udi_interface INFO vue:query: 9 -- 0.0 2022-09-05 09:27:28,332 Thread-36 udi_interface INFO vue:query: 10 -- 0.0 2022-09-05 09:27:28,333 Thread-36 udi_interface INFO vue:query: 11 -- 9.995530022515191e-05 2022-09-05 09:27:28,333 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_11:B Living Room Reporting set CPW to 0.3598 to Polyglot 2022-09-05 09:27:28,334 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.3598 2022-09-05 09:27:28,335 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_11', 'driver': 'CPW', 'value': '0.3598', 'uom': 30}]} 2022-09-05 09:27:28,336 Thread-36 udi_interface INFO vue:query: 12 -- 4.109030564626058e-06 2022-09-05 09:27:28,337 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_12:B Master and Bedroom 2 Reporting set CPW to 0.0148 to Polyglot 2022-09-05 09:27:28,338 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0148 2022-09-05 09:27:28,339 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_12', 'driver': 'CPW', 'value': '0.0148', 'uom': 30}]} 2022-09-05 09:27:28,340 Thread-36 udi_interface INFO vue:query: 13 -- 1.609829929139879e-06 2022-09-05 09:27:28,341 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_13:B Kitchen and Outside Lt Reporting set CPW to 0.0058 to Polyglot 2022-09-05 09:27:28,341 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.0058 2022-09-05 09:27:28,342 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_13', 'driver': 'CPW', 'value': '0.0058', 'uom': 30}]} 2022-09-05 09:27:28,343 Thread-36 udi_interface INFO vue:query: 14 -- 1.9463562965393067e-06 2022-09-05 09:27:28,344 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_14:B Office and Bathroom Lt Reporting set CPW to 0.007 to Polyglot 2022-09-05 09:27:28,344 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 0.007 2022-09-05 09:27:28,345 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_14', 'driver': 'CPW', 'value': '0.007', 'uom': 30}]} 2022-09-05 09:27:28,346 Thread-36 udi_interface INFO vue:query: 15 -- 0.0 2022-09-05 09:27:28,347 Thread-36 udi_interface INFO vue:query: 16 -- 0.0005483100382486979 2022-09-05 09:27:28,347 Thread-36 udi_interface.node DEBUG node:setDriver: 31548_16:Air Conditioner Reporting set CPW to 1.9739 to Polyglot 2022-09-05 09:27:28,348 Thread-36 udi_interface.node DEBUG node:reportDriver: Updating value to 1.9739 2022-09-05 09:27:28,349 Thread-36 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_16', 'driver': 'CPW', 'value': '1.9739', 'uom': 30}]} 2022-09-05 09:27:28,350 Thread-36 udi_interface INFO vue:query: TotalUsage -- 0.0008269403415256077 2022-09-05 09:27:28,352 Thread-36 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 09:27:28,352 Thread-36 udi_interface ERROR udi_interface:write: Thread-36 2022-09-05 09:27:28,353 Thread-36 udi_interface ERROR udi_interface:write: : 2022-09-05 09:27:28,353 Thread-36 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 09:27:28,354 Thread-36 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner 2022-09-05 09:27:28,358 Thread-36 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 09:27:28,358 Thread-36 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run 2022-09-05 09:27:28,361 Thread-36 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 09:27:28,362 Thread-36 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_9/./vue.py", line 25, in poll 2022-09-05 09:27:28,363 Thread-36 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 09:27:28,363 Thread-36 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_9/./vue.py", line 54, in query 2022-09-05 09:27:28,364 Thread-36 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 09:27:28,365 Thread-36 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 09:27:28,366 Thread-36 udi_interface ERROR udi_interface:write: : 2022-09-05 09:27:28,366 Thread-36 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 @Kevin What about the main node (backup_panel)? Does that show the various values (current, hourly, daily, monthly)? @tazmanfrom the log, it looks like it doing the configuration correctly. The node hierarchy is a bit different in that there is no single controller node now. Each device has a main node (see Kevin's screenshot) with each sensor being a sub-node under that main node. In your case it looks like it creates a node "Home" that should be the main node with the 13 CT's underneath and a node called "Tesla" for the charger. Link to comment
tazman Posted September 5, 2022 Share Posted September 5, 2022 7 minutes ago, bpwwer said: @Kevin What about the main node (backup_panel)? Does that show the various values (current, hourly, daily, monthly)? @tazmanfrom the log, it looks like it doing the configuration correctly. The node hierarchy is a bit different in that there is no single controller node now. Each device has a main node (see Kevin's screenshot) with each sensor being a sub-node under that main node. In your case it looks like it creates a node "Home" that should be the main node with the 13 CT's underneath and a node called "Tesla" for the charger. Without the main controller we will not be able to see the total for the main ct's that show the value of the whole house unless the "HOME" will show that value eventually. If you look at my log there is supposed to be 16 ct circuits but for some reason they are not all being sent to the AC. Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 1 minute ago, tazman said: Without the main controller we will not be able to see the total for the main ct's that show the value of the whole house unless the "HOME" will show that value eventually. If you look at my log there is supposed to be 16 ct circuits but for some reason they are not all being sent to the AC. Yes, the "HOME" node is supposed to show that. It's possible that some of the nodes are missing because the name/address doesn't meet ISY requirements. In that case, they fail to get created on the ISY/IoP. This may also be what causes the error when trying to update some of the nodes. I found the issue with the admin console display. I messed up the node definition file so it wasn't loading any of the node definitions. Once I'm done typing, I'll release another version with that fix and that should get us a bit closer. Node server development, at least for me, is a very iterative process... code, test, fix, test, fix .... So far, we're making good progress thanks to all the feedback. Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 Version 1.0.13 should be in the store now, refresh store, verify it is, and then restart. You will have to restart the admin console after this version starts up but then you see the data fields in the all the nodes. I'll start looking into why some of @tazman's node aren't showing up. Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 @tazman Is it the CT's that are named with an '&' in the name that aren't showing up? I believe that's not a valid character for node names. I'll add some check make sure the names are valid before trying to create the nodes. Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 Getting there. I know how you feel I make a living off programing PLC and it is time comsuming but can be rewarding to. Thank you for all your time you put into this. Now I have read out but only the ct's in the backup panel are working and the panel say's disconnected but it is reading and updating. the main panel shows connected but reads nothing 2022-09-05 14:02:25,351 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down. 2022-09-05 14:02:25,352 Command udi_interface.interface INFO interface:stop: Disconnecting from MQTT... localhost:1888 2022-09-05 14:02:25,353 Command udi_interface.interface INFO interface:_disconnect: MQTT Graceful disconnection. 2022-09-05 14:02:49,126 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2022-09-05 14:02:49,331 Thread-2 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2022-09-05 14:02:49,335 Thread-2 udi_interface INFO vue:parameterHandler: Logging in to Emporia Cloud 2022-09-05 14:02:49,453 MQTT udi_interface.interface INFO interface:_message: custom data response {'customparamsdoc': '<h2>Configuration</h2>\n\n<p>The VUE node server has the following user configuration parameters:</p>\n\n<ul>\n<li>Username : Your emporia account username</li>\n<li>Password : Your emporia account password</li>\n</ul>\n'} 2022-09-05 14:02:49,492 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc 2022-09-05 14:02:49,825 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2022-09-05 14:02:49,828 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2022-09-05 14:02:54,771 Thread-2 udi_interface INFO vue:discover: GID: 136598 2022-09-05 14:02:54,772 Thread-2 udi_interface INFO vue:discover: Manufacturer: A2201A05B524D7EB9C91AC 2022-09-05 14:02:54,773 Thread-2 udi_interface INFO vue:discover: Model: VUE002 2022-09-05 14:02:54,774 Thread-2 udi_interface INFO vue:discover: Firmware: Vue2-159 2022-09-05 14:02:54,774 Thread-2 udi_interface INFO vue:discover: Name: backup panel 2022-09-05 14:02:54,775 Thread-2 udi_interface INFO vue:discover: Creating device node for backup panel (136598) 2022-09-05 14:02:54,777 Thread-2 udi_interface.interface INFO interface:addNode: Adding node backup panel(136598) [None] 2022-09-05 14:02:54,779 Thread-2 udi_interface.interface INFO interface:setController: Using node "136598", driver "ST" for connection status. 2022-09-05 14:02:54,781 Thread-2 udi_interface INFO vue:discover: Found channel: 1,2,3 - None 2022-09-05 14:02:55,050 Thread-2 udi_interface INFO vue:discover: GID: 136598 2022-09-05 14:02:55,051 Thread-2 udi_interface INFO vue:discover: Manufacturer: SXA2201A05B524D7EB9C91AC 2022-09-05 14:02:55,052 Thread-2 udi_interface INFO vue:discover: Model: WAT001 2022-09-05 14:02:55,053 Thread-2 udi_interface INFO vue:discover: Firmware: None 2022-09-05 14:02:55,053 Thread-2 udi_interface INFO vue:discover: Name: backup panel 2022-09-05 14:02:55,054 Thread-2 udi_interface INFO vue:discover: Found channel: 1 - 1 ac compressor 2022-09-05 14:02:55,055 Thread-2 udi_interface INFO vue:discover: Creating child node 1 ac compressor / 136598_1 2022-09-05 14:02:55,056 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 1 ac compressor(136598_1) [None] 2022-09-05 14:02:55,058 Thread-2 udi_interface INFO vue:discover: Found channel: 2 - 2 furnace blower 2022-09-05 14:02:55,059 Thread-2 udi_interface INFO vue:discover: Creating child node 2 furnace blower / 136598_2 2022-09-05 14:02:55,061 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 2 furnace blower(136598_2) [None] 2022-09-05 14:02:55,062 Thread-2 udi_interface INFO vue:discover: Found channel: 3 - don't know 2022-09-05 14:02:55,063 Thread-2 udi_interface INFO vue:discover: Creating child node don't know / 136598_3 2022-09-05 14:02:55,064 Thread-2 udi_interface.interface INFO interface:addNode: Adding node don't know(136598_3) [None] 2022-09-05 14:02:55,066 Thread-2 udi_interface INFO vue:discover: Found channel: 4 - 4 kitchen lights and outlets backyard light 2022-09-05 14:02:55,067 Thread-2 udi_interface INFO vue:discover: Creating child node 4 kitchen lights and outlets backyard light / 136598_4 2022-09-05 14:02:55,068 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 4 kitchen lights and outlets backyard light(136598_4) [None] 2022-09-05 14:02:55,070 Thread-2 udi_interface INFO vue:discover: Found channel: 5 - 5 living room tv 2022-09-05 14:02:55,071 Thread-2 udi_interface INFO vue:discover: Creating child node 5 living room tv / 136598_5 2022-09-05 14:02:55,072 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 5 living room tv(136598_5) [None] 2022-09-05 14:02:55,074 Thread-2 udi_interface INFO vue:discover: Found channel: 6 - 6 playroom lights and bathroom 2022-09-05 14:02:55,075 Thread-2 udi_interface INFO vue:discover: Creating child node 6 playroom lights and bathroom / 136598_6 2022-09-05 14:02:55,076 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 6 playroom lights and bathroom(136598_6) [None] 2022-09-05 14:02:55,078 Thread-2 udi_interface INFO vue:discover: Found channel: 7 - 7 work bench and playroom outlets and refrigerator 2022-09-05 14:02:55,079 Thread-2 udi_interface INFO vue:discover: Creating child node 7 work bench and playroom outlets and refrigerator / 136598_7 2022-09-05 14:02:55,080 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 7 work bench and playroom outlets and refrigerator(136598_7) [None] 2022-09-05 14:02:55,083 Thread-2 udi_interface INFO vue:discover: Found channel: 8 - None 2022-09-05 14:02:55,083 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_8 2022-09-05 14:02:55,085 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_8) [None] 2022-09-05 14:02:55,087 Thread-2 udi_interface INFO vue:discover: Found channel: 9 - None 2022-09-05 14:02:55,088 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_9 2022-09-05 14:02:55,089 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_9) [None] 2022-09-05 14:02:55,091 Thread-2 udi_interface INFO vue:discover: Found channel: 10 - None 2022-09-05 14:02:55,092 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_10 2022-09-05 14:02:55,093 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_10) [None] 2022-09-05 14:02:55,095 Thread-2 udi_interface INFO vue:discover: Found channel: 11 - None 2022-09-05 14:02:55,096 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_11 2022-09-05 14:02:55,097 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_11) [None] 2022-09-05 14:02:55,099 Thread-2 udi_interface INFO vue:discover: Found channel: 12 - None 2022-09-05 14:02:55,100 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_12 2022-09-05 14:02:55,101 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_12) [None] 2022-09-05 14:02:55,103 Thread-2 udi_interface INFO vue:discover: Found channel: 13 - None 2022-09-05 14:02:55,103 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_13 2022-09-05 14:02:55,105 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_13) [None] 2022-09-05 14:02:55,107 Thread-2 udi_interface INFO vue:discover: Found channel: 14 - None 2022-09-05 14:02:55,107 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_14 2022-09-05 14:02:55,109 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_14) [None] 2022-09-05 14:02:55,110 Thread-2 udi_interface INFO vue:discover: Found channel: 15 - None 2022-09-05 14:02:55,111 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_15 2022-09-05 14:02:55,113 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_15) [None] 2022-09-05 14:02:55,114 Thread-2 udi_interface INFO vue:discover: Found channel: 16 - None 2022-09-05 14:02:55,115 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136598_16 2022-09-05 14:02:55,116 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136598_16) [None] 2022-09-05 14:02:55,401 Thread-2 udi_interface INFO vue:discover: GID: 136723 2022-09-05 14:02:55,402 Thread-2 udi_interface INFO vue:discover: Manufacturer: A2203A05B524D7EB9E2C44 2022-09-05 14:02:55,403 Thread-2 udi_interface INFO vue:discover: Model: VUE002 2022-09-05 14:02:55,403 Thread-2 udi_interface INFO vue:discover: Firmware: Vue2-159 2022-09-05 14:02:55,404 Thread-2 udi_interface INFO vue:discover: Name: panel 2022-09-05 14:02:55,405 Thread-2 udi_interface INFO vue:discover: Creating device node for panel (136723) 2022-09-05 14:02:55,406 Thread-2 udi_interface.interface INFO interface:addNode: Adding node panel(136723) [None] 2022-09-05 14:02:55,408 Thread-2 udi_interface.interface INFO interface:setController: Using node "136723", driver "ST" for connection status. 2022-09-05 14:02:55,410 Thread-2 udi_interface INFO vue:discover: Found channel: 1,2,3 - None 2022-09-05 14:02:55,721 Thread-2 udi_interface INFO vue:discover: GID: 136723 2022-09-05 14:02:55,722 Thread-2 udi_interface INFO vue:discover: Manufacturer: SXA2203A05B524D7EB9E2C44 2022-09-05 14:02:55,723 Thread-2 udi_interface INFO vue:discover: Model: WAT001 2022-09-05 14:02:55,723 Thread-2 udi_interface INFO vue:discover: Firmware: None 2022-09-05 14:02:55,724 Thread-2 udi_interface INFO vue:discover: Name: panel 2022-09-05 14:02:55,725 Thread-2 udi_interface INFO vue:discover: Found channel: 1 - None 2022-09-05 14:02:55,726 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_1 2022-09-05 14:02:55,727 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_1) [None] 2022-09-05 14:02:55,730 Thread-2 udi_interface INFO vue:discover: Found channel: 2 - Clothes washer sump pump 2022-09-05 14:02:55,731 Thread-2 udi_interface INFO vue:discover: Creating child node Clothes washer sump pump / 136723_2 2022-09-05 14:02:55,733 Thread-2 udi_interface.interface INFO interface:addNode: Adding node Clothes washer sump pump(136723_2) [None] 2022-09-05 14:02:55,735 Thread-2 udi_interface INFO vue:discover: Found channel: 3 - clothes dryer 2022-09-05 14:02:55,735 Thread-2 udi_interface INFO vue:discover: Creating child node clothes dryer / 136723_3 2022-09-05 14:02:55,737 Thread-2 udi_interface.interface INFO interface:addNode: Adding node clothes dryer(136723_3) [None] 2022-09-05 14:02:55,738 Thread-2 udi_interface INFO vue:discover: Found channel: 4 - solar panels 2022-09-05 14:02:55,739 Thread-2 udi_interface INFO vue:discover: Creating child node solar panels / 136723_4 2022-09-05 14:02:55,741 Thread-2 udi_interface.interface INFO interface:addNode: Adding node solar panels(136723_4) [None] 2022-09-05 14:02:55,743 Thread-2 udi_interface INFO vue:discover: Found channel: 5 - None 2022-09-05 14:02:55,744 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_5 2022-09-05 14:02:55,746 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_5) [None] 2022-09-05 14:02:55,747 Thread-2 udi_interface INFO vue:discover: Found channel: 6 - None 2022-09-05 14:02:55,748 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_6 2022-09-05 14:02:55,750 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_6) [None] 2022-09-05 14:02:55,751 Thread-2 udi_interface INFO vue:discover: Found channel: 7 - leg A backup 2022-09-05 14:02:55,752 Thread-2 udi_interface INFO vue:discover: Creating child node leg A backup / 136723_7 2022-09-05 14:02:55,753 Thread-2 udi_interface.interface INFO interface:addNode: Adding node leg A backup(136723_7) [None] 2022-09-05 14:02:55,755 Thread-2 udi_interface INFO vue:discover: Found channel: 8 - Leg B backup 2022-09-05 14:02:55,755 Thread-2 udi_interface INFO vue:discover: Creating child node Leg B backup / 136723_8 2022-09-05 14:02:55,757 Thread-2 udi_interface.interface INFO interface:addNode: Adding node Leg B backup(136723_8) [None] 2022-09-05 14:02:55,758 Thread-2 udi_interface INFO vue:discover: Found channel: 9 - None 2022-09-05 14:02:55,759 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_9 2022-09-05 14:02:55,761 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_9) [None] 2022-09-05 14:02:55,762 Thread-2 udi_interface INFO vue:discover: Found channel: 10 - None 2022-09-05 14:02:55,763 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_10 2022-09-05 14:02:55,764 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_10) [None] 2022-09-05 14:02:55,766 Thread-2 udi_interface INFO vue:discover: Found channel: 11 - microwave oven 2022-09-05 14:02:55,766 Thread-2 udi_interface INFO vue:discover: Creating child node microwave oven / 136723_11 2022-09-05 14:02:55,768 Thread-2 udi_interface.interface INFO interface:addNode: Adding node microwave oven(136723_11) [None] 2022-09-05 14:02:55,769 Thread-2 udi_interface INFO vue:discover: Found channel: 12 - kitchen deepfryer 2022-09-05 14:02:55,770 Thread-2 udi_interface INFO vue:discover: Creating child node kitchen deepfryer / 136723_12 2022-09-05 14:02:55,771 Thread-2 udi_interface.interface INFO interface:addNode: Adding node kitchen deepfryer(136723_12) [None] 2022-09-05 14:02:55,773 Thread-2 udi_interface INFO vue:discover: Found channel: 13 - None 2022-09-05 14:02:55,774 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_13 2022-09-05 14:02:55,775 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_13) [None] 2022-09-05 14:02:55,777 Thread-2 udi_interface INFO vue:discover: Found channel: 14 - None 2022-09-05 14:02:55,778 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_14 2022-09-05 14:02:55,779 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_14) [None] 2022-09-05 14:02:55,781 Thread-2 udi_interface INFO vue:discover: Found channel: 15 - None 2022-09-05 14:02:55,781 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_15 2022-09-05 14:02:55,783 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_15) [None] 2022-09-05 14:02:55,784 Thread-2 udi_interface INFO vue:discover: Found channel: 16 - None 2022-09-05 14:02:55,785 Thread-2 udi_interface INFO vue:discover: Creating child node None / 136723_16 2022-09-05 14:02:55,786 Thread-2 udi_interface.interface INFO interface:addNode: Adding node None(136723_16) [None] 2022-09-05 14:02:56,075 Thread-2 udi_interface INFO vue:query: 1,2,3 -- 1.7884337416585288 2022-09-05 14:02:56,076 Thread-2 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:02:56,080 Thread-2 udi_interface INFO vue:query: 1 -- 0.7065140579223633 2022-09-05 14:02:56,081 Thread-2 udi_interface INFO vue:query: Updating child node 136598_1 2022-09-05 14:02:56,084 Thread-2 udi_interface INFO vue:query: 2 -- 0.2827261037740442 2022-09-05 14:02:56,085 Thread-2 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:02:56,087 Thread-2 udi_interface INFO vue:query: 4 -- 0.04381106804000007 2022-09-05 14:02:56,087 Thread-2 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:02:56,089 Thread-2 udi_interface INFO vue:query: 5 -- 0.03332825476434496 2022-09-05 14:02:56,090 Thread-2 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:02:56,092 Thread-2 udi_interface INFO vue:query: 6 -- 0.14066050157970852 2022-09-05 14:02:56,094 Thread-2 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:02:56,096 Thread-2 udi_interface INFO vue:query: 7 -- 0.5447702435472277 2022-09-05 14:02:56,097 Thread-2 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:02:56,099 Thread-2 udi_interface INFO vue:query: Balance -- 0.03662351203083991 2022-09-05 14:02:56,100 Thread-2 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:02:56,101 Thread-2 udi_interface ERROR vue:parameterHandler: Discovery failed: 'NoneType' object has no attribute 'update_hour' 2022-09-05 14:02:56,349 Thread-7 udi_interface INFO vue:query: 1,2,3 -- 0.00022756678687201607 2022-09-05 14:02:56,350 Thread-7 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:02:56,352 Thread-7 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:02:56,353 Thread-7 udi_interface INFO vue:query: 2 -- 1.5353426668379042e-06 2022-09-05 14:02:56,353 Thread-7 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:02:56,355 Thread-7 udi_interface INFO vue:query: 4 -- 1.2252633836534288e-05 2022-09-05 14:02:56,355 Thread-7 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:02:56,357 Thread-7 udi_interface INFO vue:query: 5 -- 9.24849510192871e-06 2022-09-05 14:02:56,357 Thread-7 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:02:56,359 Thread-7 udi_interface INFO vue:query: 6 -- 3.8761520385742185e-05 2022-09-05 14:02:56,359 Thread-7 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:02:56,361 Thread-7 udi_interface INFO vue:query: 7 -- 0.00015597915649414064 2022-09-05 14:02:56,362 Thread-7 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:02:56,363 Thread-7 udi_interface INFO vue:query: Balance -- 9.78963838683234e-06 2022-09-05 14:02:56,364 Thread-7 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:02:56,365 Thread-7 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:02:56,366 Thread-7 udi_interface ERROR udi_interface:write: Thread-7 2022-09-05 14:02:56,367 Thread-7 udi_interface ERROR udi_interface:write: : 2022-09-05 14:02:56,367 Thread-7 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:02:56,368 Thread-7 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:02:56,372 Thread-7 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:02:56,373 Thread-7 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:02:56,377 Thread-7 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:02:56,378 Thread-7 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:02:56,379 Thread-7 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:02:56,380 Thread-7 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:02:56,382 Thread-7 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:02:56,382 Thread-7 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:02:56,383 Thread-7 udi_interface ERROR udi_interface:write: : 2022-09-05 14:02:56,384 Thread-7 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:02:58,542 Thread-8 udi_interface INFO vue:query: 1,2,3 -- 0.00023143399980333113 2022-09-05 14:02:58,544 Thread-8 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:02:58,545 Thread-8 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:02:58,546 Thread-8 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 14:02:58,547 Thread-8 udi_interface INFO vue:query: 4 -- 1.1493741141425237e-05 2022-09-05 14:02:58,547 Thread-8 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:02:58,549 Thread-8 udi_interface INFO vue:query: 5 -- 8.664751052856445e-06 2022-09-05 14:02:58,549 Thread-8 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:02:58,551 Thread-8 udi_interface INFO vue:query: 6 -- 3.9502538045247396e-05 2022-09-05 14:02:58,551 Thread-8 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:02:58,552 Thread-8 udi_interface INFO vue:query: 7 -- 0.0001582501729329427 2022-09-05 14:02:58,553 Thread-8 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:02:58,554 Thread-8 udi_interface INFO vue:query: Balance -- 1.3522796630859366e-05 2022-09-05 14:02:58,554 Thread-8 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:02:58,555 Thread-8 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:02:58,556 Thread-8 udi_interface ERROR udi_interface:write: Thread-8 2022-09-05 14:02:58,556 Thread-8 udi_interface ERROR udi_interface:write: : 2022-09-05 14:02:58,557 Thread-8 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:02:58,557 Thread-8 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:02:58,561 Thread-8 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:02:58,561 Thread-8 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:02:58,564 Thread-8 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:02:58,565 Thread-8 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:02:58,566 Thread-8 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:02:58,567 Thread-8 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:02:58,568 Thread-8 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:02:58,568 Thread-8 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:02:58,569 Thread-8 udi_interface ERROR udi_interface:write: : 2022-09-05 14:02:58,569 Thread-8 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:00,448 Thread-20 udi_interface INFO vue:query: 1,2,3 -- 0.0002258571497599284 2022-09-05 14:03:00,449 Thread-20 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:00,451 Thread-20 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:00,452 Thread-20 udi_interface INFO vue:query: 2 -- 1.3990975750817193e-06 2022-09-05 14:03:00,453 Thread-20 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:00,455 Thread-20 udi_interface INFO vue:query: 4 -- 1.1630508634779188e-05 2022-09-05 14:03:00,456 Thread-20 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:00,458 Thread-20 udi_interface INFO vue:query: 5 -- 8.860969013637966e-06 2022-09-05 14:03:00,459 Thread-20 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:00,462 Thread-20 udi_interface INFO vue:query: 6 -- 3.870427449544271e-05 2022-09-05 14:03:00,463 Thread-20 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:00,465 Thread-20 udi_interface INFO vue:query: 7 -- 0.00015437576293945312 2022-09-05 14:03:00,466 Thread-20 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:00,469 Thread-20 udi_interface INFO vue:query: Balance -- 1.0886537101533703e-05 2022-09-05 14:03:00,470 Thread-20 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:00,471 Thread-20 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:00,471 Thread-20 udi_interface ERROR udi_interface:write: Thread-20 2022-09-05 14:03:00,472 Thread-20 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:00,472 Thread-20 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:00,473 Thread-20 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:00,477 Thread-20 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:00,478 Thread-20 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:00,482 Thread-20 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:00,483 Thread-20 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:00,484 Thread-20 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:00,485 Thread-20 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:00,487 Thread-20 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:00,487 Thread-20 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:00,488 Thread-20 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:00,488 Thread-20 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:02,364 Thread-27 udi_interface INFO vue:query: 1,2,3 -- 0.00022825498369004993 2022-09-05 14:03:02,365 Thread-27 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:02,367 Thread-27 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:02,368 Thread-27 udi_interface INFO vue:query: 2 -- 1.5892767906188965e-06 2022-09-05 14:03:02,368 Thread-27 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:02,370 Thread-27 udi_interface INFO vue:query: 4 -- 1.150063090854221e-05 2022-09-05 14:03:02,370 Thread-27 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:02,372 Thread-27 udi_interface INFO vue:query: 5 -- 9.500281016031902e-06 2022-09-05 14:03:02,372 Thread-27 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:02,374 Thread-27 udi_interface INFO vue:query: 6 -- 4.1301036410861546e-05 2022-09-05 14:03:02,375 Thread-27 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:02,376 Thread-27 udi_interface INFO vue:query: 7 -- 0.00015391993204752605 2022-09-05 14:03:02,377 Thread-27 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:02,378 Thread-27 udi_interface INFO vue:query: Balance -- 1.0443826516469315e-05 2022-09-05 14:03:02,378 Thread-27 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:02,379 Thread-27 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:02,380 Thread-27 udi_interface ERROR udi_interface:write: Thread-27 2022-09-05 14:03:02,380 Thread-27 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:02,381 Thread-27 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:02,381 Thread-27 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:02,385 Thread-27 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:02,386 Thread-27 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:02,389 Thread-27 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:02,389 Thread-27 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:02,391 Thread-27 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:02,391 Thread-27 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:02,392 Thread-27 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:02,393 Thread-27 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:02,393 Thread-27 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:02,394 Thread-27 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:03,379 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: GV1 to 1.7884 UOM 33 2022-09-05 14:03:03,515 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_1 :: GV1 to 0.7065 UOM 33 2022-09-05 14:03:03,631 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: GV1 to 0.2827 UOM 33 2022-09-05 14:03:03,675 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: GV1 to 0.0438 UOM 33 2022-09-05 14:03:03,729 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: GV1 to 0.0333 UOM 33 2022-09-05 14:03:03,789 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: GV1 to 0.1407 UOM 33 2022-09-05 14:03:03,830 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: GV1 to 0.5448 UOM 33 2022-09-05 14:03:03,891 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8192 UOM 30 2022-09-05 14:03:03,957 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0055 UOM 30 2022-09-05 14:03:04,021 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0441 UOM 30 2022-09-05 14:03:04,063 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0333 UOM 30 2022-09-05 14:03:04,064 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1395 UOM 30 2022-09-05 14:03:04,104 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5615 UOM 30 2022-09-05 14:03:04,107 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8332 UOM 30 2022-09-05 14:03:04,145 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0414 UOM 30 2022-09-05 14:03:04,147 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0312 UOM 30 2022-09-05 14:03:04,186 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1422 UOM 30 2022-09-05 14:03:04,291 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5697 UOM 30 2022-09-05 14:03:04,375 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8131 UOM 30 2022-09-05 14:03:04,452 Thread-28 udi_interface INFO vue:query: 1,2,3 -- 0.00023079700469970702 2022-09-05 14:03:04,452 Thread-28 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:04,454 Thread-28 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:04,455 Thread-28 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 14:03:04,456 Thread-28 udi_interface INFO vue:query: 4 -- 1.1800506379869248e-05 2022-09-05 14:03:04,456 Thread-28 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:04,458 Thread-28 udi_interface INFO vue:query: 5 -- 9.613370895385741e-06 2022-09-05 14:03:04,459 Thread-28 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:04,460 Thread-28 udi_interface INFO vue:query: 6 -- 4.552972157796224e-05 2022-09-05 14:03:04,461 Thread-28 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:04,463 Thread-28 udi_interface INFO vue:query: 7 -- 0.00015228457980685764 2022-09-05 14:03:04,463 Thread-28 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:04,465 Thread-28 udi_interface INFO vue:query: Balance -- 1.1568826039632117e-05 2022-09-05 14:03:04,466 Thread-28 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:04,467 Thread-28 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:04,468 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.005 UOM 30 2022-09-05 14:03:04,469 Thread-28 udi_interface ERROR udi_interface:write: Thread-28 2022-09-05 14:03:04,470 Thread-28 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:04,471 Thread-28 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:04,472 Thread-28 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:04,476 Thread-28 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:04,477 Thread-28 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:04,480 Thread-28 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:04,481 Thread-28 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:04,483 Thread-28 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:04,483 Thread-28 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:04,484 Thread-28 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:04,485 Thread-28 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:04,486 Thread-28 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:04,486 Thread-28 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:04,587 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0419 UOM 30 2022-09-05 14:03:04,669 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0319 UOM 30 2022-09-05 14:03:04,765 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1393 UOM 30 2022-09-05 14:03:04,869 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5558 UOM 30 2022-09-05 14:03:06,276 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8217 UOM 30 2022-09-05 14:03:06,378 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0057 UOM 30 2022-09-05 14:03:06,581 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0414 UOM 30 2022-09-05 14:03:06,609 Thread-41 udi_interface INFO vue:query: 1,2,3 -- 0.0002303920364379883 2022-09-05 14:03:06,610 Thread-41 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:06,613 Thread-41 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:06,613 Thread-41 udi_interface INFO vue:query: 2 -- 1.7564267582363553e-06 2022-09-05 14:03:06,614 Thread-41 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:06,616 Thread-41 udi_interface INFO vue:query: 4 -- 1.1988149219089084e-05 2022-09-05 14:03:06,617 Thread-41 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:06,619 Thread-41 udi_interface INFO vue:query: 5 -- 9.125082227918837e-06 2022-09-05 14:03:06,620 Thread-41 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:06,621 Thread-41 udi_interface INFO vue:query: 6 -- 4.715730455186632e-05 2022-09-05 14:03:06,622 Thread-41 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:06,624 Thread-41 udi_interface INFO vue:query: 7 -- 0.00015081663343641493 2022-09-05 14:03:06,625 Thread-41 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:06,627 Thread-41 udi_interface INFO vue:query: Balance -- 9.548440244462749e-06 2022-09-05 14:03:06,627 Thread-41 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:06,628 Thread-41 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:06,629 Thread-41 udi_interface ERROR udi_interface:write: Thread-41 2022-09-05 14:03:06,629 Thread-41 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:06,630 Thread-41 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:06,631 Thread-41 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:06,635 Thread-41 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:06,636 Thread-41 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:06,639 Thread-41 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:06,640 Thread-41 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:06,641 Thread-41 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:06,642 Thread-41 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:06,643 Thread-41 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:06,644 Thread-41 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:06,645 Thread-41 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:06,645 Thread-41 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:06,695 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0342 UOM 30 2022-09-05 14:03:06,908 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1487 UOM 30 2022-09-05 14:03:06,950 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5541 UOM 30 2022-09-05 14:03:07,077 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8309 UOM 30 2022-09-05 14:03:07,180 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0425 UOM 30 2022-09-05 14:03:07,277 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0346 UOM 30 2022-09-05 14:03:07,395 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1639 UOM 30 2022-09-05 14:03:07,478 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5482 UOM 30 2022-09-05 14:03:07,578 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8294 UOM 30 2022-09-05 14:03:07,673 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0063 UOM 30 2022-09-05 14:03:07,777 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0432 UOM 30 2022-09-05 14:03:07,876 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0329 UOM 30 2022-09-05 14:03:07,980 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1698 UOM 30 2022-09-05 14:03:08,124 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5429 UOM 30 2022-09-05 14:03:08,457 Thread-46 udi_interface INFO vue:query: 1,2,3 -- 0.00023010235256618923 2022-09-05 14:03:08,458 Thread-46 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:08,460 Thread-46 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:08,461 Thread-46 udi_interface INFO vue:query: 2 -- 1.6117747624715169e-06 2022-09-05 14:03:08,462 Thread-46 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:08,464 Thread-46 udi_interface INFO vue:query: 4 -- 1.2098172505696615e-05 2022-09-05 14:03:08,465 Thread-46 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:08,466 Thread-46 udi_interface INFO vue:query: 5 -- 9.647916158040364e-06 2022-09-05 14:03:08,467 Thread-46 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:08,469 Thread-46 udi_interface INFO vue:query: 6 -- 4.560630798339844e-05 2022-09-05 14:03:08,470 Thread-46 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:08,472 Thread-46 udi_interface INFO vue:query: 7 -- 0.0001520877753363715 2022-09-05 14:03:08,473 Thread-46 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:08,475 Thread-46 udi_interface INFO vue:query: Balance -- 9.050405820210827e-06 2022-09-05 14:03:08,475 Thread-46 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:08,476 Thread-46 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:08,477 Thread-46 udi_interface ERROR udi_interface:write: Thread-46 2022-09-05 14:03:08,477 Thread-46 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:08,478 Thread-46 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:08,479 Thread-46 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:08,483 Thread-46 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:08,484 Thread-46 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:08,488 Thread-46 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:08,489 Thread-46 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:08,490 Thread-46 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:08,491 Thread-46 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:08,492 Thread-46 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:08,493 Thread-46 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:08,494 Thread-46 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:08,494 Thread-46 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:08,645 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.8284 UOM 30 2022-09-05 14:03:08,716 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0058 UOM 30 2022-09-05 14:03:08,758 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0436 UOM 30 2022-09-05 14:03:08,886 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0347 UOM 30 2022-09-05 14:03:08,982 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1642 UOM 30 2022-09-05 14:03:09,084 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.5475 UOM 30 2022-09-05 14:03:10,395 Thread-47 udi_interface INFO vue:query: 1,2,3 -- 0.0002643776618109809 2022-09-05 14:03:10,396 Thread-47 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:10,398 Thread-47 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:10,399 Thread-47 udi_interface INFO vue:query: 2 -- 1.3965454366472032e-06 2022-09-05 14:03:10,399 Thread-47 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:10,401 Thread-47 udi_interface INFO vue:query: 4 -- 1.1752004623413086e-05 2022-09-05 14:03:10,402 Thread-47 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:10,404 Thread-47 udi_interface INFO vue:query: 5 -- 8.956594467163085e-06 2022-09-05 14:03:10,405 Thread-47 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:10,407 Thread-47 udi_interface INFO vue:query: 6 -- 4.4949383205837673e-05 2022-09-05 14:03:10,407 Thread-47 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:10,409 Thread-47 udi_interface INFO vue:query: 7 -- 0.00018801717122395834 2022-09-05 14:03:10,410 Thread-47 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:10,412 Thread-47 udi_interface INFO vue:query: Balance -- 9.305962853961499e-06 2022-09-05 14:03:10,413 Thread-47 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:10,414 Thread-47 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:10,414 Thread-47 udi_interface ERROR udi_interface:write: Thread-47 2022-09-05 14:03:10,415 Thread-47 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:10,416 Thread-47 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:10,416 Thread-47 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:10,420 Thread-47 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:10,421 Thread-47 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:10,425 Thread-47 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:10,426 Thread-47 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:10,427 Thread-47 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:10,428 Thread-47 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:10,430 Thread-47 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:10,430 Thread-47 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:10,431 Thread-47 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:10,432 Thread-47 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:10,568 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.9518 UOM 30 2022-09-05 14:03:10,649 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.005 UOM 30 2022-09-05 14:03:10,732 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0423 UOM 30 2022-09-05 14:03:10,821 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0322 UOM 30 2022-09-05 14:03:10,920 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1618 UOM 30 2022-09-05 14:03:11,018 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.6769 UOM 30 2022-09-05 14:03:12,384 Thread-48 udi_interface INFO vue:query: 1,2,3 -- 0.00026120816124810116 2022-09-05 14:03:12,385 Thread-48 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:12,388 Thread-48 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:12,388 Thread-48 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 14:03:12,389 Thread-48 udi_interface INFO vue:query: 4 -- 1.150846693250868e-05 2022-09-05 14:03:12,390 Thread-48 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:12,392 Thread-48 udi_interface INFO vue:query: 5 -- 8.778883616129557e-06 2022-09-05 14:03:12,393 Thread-48 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:12,394 Thread-48 udi_interface INFO vue:query: 6 -- 4.494767083062066e-05 2022-09-05 14:03:12,395 Thread-48 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:12,396 Thread-48 udi_interface INFO vue:query: 7 -- 0.0001852939690483941 2022-09-05 14:03:12,397 Thread-48 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:12,399 Thread-48 udi_interface INFO vue:query: Balance -- 1.067917082044813e-05 2022-09-05 14:03:12,399 Thread-48 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:12,400 Thread-48 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:12,401 Thread-48 udi_interface ERROR udi_interface:write: Thread-48 2022-09-05 14:03:12,401 Thread-48 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:12,402 Thread-48 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:12,403 Thread-48 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:12,407 Thread-48 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:12,408 Thread-48 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:12,412 Thread-48 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:12,413 Thread-48 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:12,414 Thread-48 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:12,415 Thread-48 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:12,416 Thread-48 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:12,417 Thread-48 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:12,418 Thread-48 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:12,418 Thread-48 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:12,537 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.9403 UOM 30 2022-09-05 14:03:12,621 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0414 UOM 30 2022-09-05 14:03:12,711 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0316 UOM 30 2022-09-05 14:03:12,812 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.6671 UOM 30 2022-09-05 14:03:14,374 Thread-49 udi_interface INFO vue:query: 1,2,3 -- 0.00026159231397840713 2022-09-05 14:03:14,375 Thread-49 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:14,377 Thread-49 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:14,378 Thread-49 udi_interface INFO vue:query: 2 -- 1.5200351344214546e-06 2022-09-05 14:03:14,379 Thread-49 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:14,381 Thread-49 udi_interface INFO vue:query: 4 -- 1.1865836249457465e-05 2022-09-05 14:03:14,382 Thread-49 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:14,383 Thread-49 udi_interface INFO vue:query: 5 -- 9.248851140340169e-06 2022-09-05 14:03:14,384 Thread-49 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:14,386 Thread-49 udi_interface INFO vue:query: 6 -- 4.171405368381076e-05 2022-09-05 14:03:14,387 Thread-49 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:14,389 Thread-49 udi_interface INFO vue:query: 7 -- 0.00018756556193033855 2022-09-05 14:03:14,390 Thread-49 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:14,391 Thread-49 udi_interface INFO vue:query: Balance -- 9.677975840038775e-06 2022-09-05 14:03:14,392 Thread-49 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:14,393 Thread-49 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:14,394 Thread-49 udi_interface ERROR udi_interface:write: Thread-49 2022-09-05 14:03:14,394 Thread-49 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:14,395 Thread-49 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:14,396 Thread-49 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:14,400 Thread-49 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:14,401 Thread-49 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:14,405 Thread-49 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:14,406 Thread-49 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:14,407 Thread-49 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:14,408 Thread-49 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:14,409 Thread-49 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:14,410 Thread-49 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:14,411 Thread-49 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:14,412 Thread-49 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:14,602 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.9417 UOM 30 2022-09-05 14:03:14,682 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0055 UOM 30 2022-09-05 14:03:14,761 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0427 UOM 30 2022-09-05 14:03:14,803 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0333 UOM 30 2022-09-05 14:03:14,923 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1502 UOM 30 2022-09-05 14:03:15,017 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.6752 UOM 30 2022-09-05 14:03:16,379 Thread-50 udi_interface INFO vue:query: 1,2,3 -- 0.000259334593878852 2022-09-05 14:03:16,380 Thread-50 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:16,382 Thread-50 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:16,383 Thread-50 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 14:03:16,383 Thread-50 udi_interface INFO vue:query: 4 -- 1.1536038716634114e-05 2022-09-05 14:03:16,384 Thread-50 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:16,386 Thread-50 udi_interface INFO vue:query: 5 -- 9.202681647406684e-06 2022-09-05 14:03:16,387 Thread-50 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:16,389 Thread-50 udi_interface INFO vue:query: 6 -- 3.924940745035807e-05 2022-09-05 14:03:16,390 Thread-50 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:16,391 Thread-50 udi_interface INFO vue:query: 7 -- 0.0001894600084092882 2022-09-05 14:03:16,392 Thread-50 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:16,394 Thread-50 udi_interface INFO vue:query: Balance -- 9.886457655164924e-06 2022-09-05 14:03:16,395 Thread-50 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:16,396 Thread-50 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:16,396 Thread-50 udi_interface ERROR udi_interface:write: Thread-50 2022-09-05 14:03:16,397 Thread-50 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:16,398 Thread-50 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:16,398 Thread-50 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:16,402 Thread-50 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:16,403 Thread-50 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:16,407 Thread-50 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:16,408 Thread-50 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:16,410 Thread-50 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:16,410 Thread-50 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:16,412 Thread-50 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:16,413 Thread-50 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:16,413 Thread-50 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:16,414 Thread-50 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:16,533 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.9336 UOM 30 2022-09-05 14:03:16,632 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0415 UOM 30 2022-09-05 14:03:16,713 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0331 UOM 30 2022-09-05 14:03:16,802 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1413 UOM 30 2022-09-05 14:03:16,905 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.6821 UOM 30 2022-09-05 14:03:18,386 Thread-51 udi_interface INFO vue:query: 1,2,3 -- 0.0002606932110256619 2022-09-05 14:03:18,387 Thread-51 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:18,389 Thread-51 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:18,390 Thread-51 udi_interface INFO vue:query: 2 -- 1.4909470081329347e-06 2022-09-05 14:03:18,391 Thread-51 udi_interface INFO vue:query: Updating child node 136598_2 2022-09-05 14:03:18,393 Thread-51 udi_interface INFO vue:query: 4 -- 1.199189715915256e-05 2022-09-05 14:03:18,393 Thread-51 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:18,395 Thread-51 udi_interface INFO vue:query: 5 -- 9.21558698018392e-06 2022-09-05 14:03:18,396 Thread-51 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:18,398 Thread-51 udi_interface INFO vue:query: 6 -- 4.092085944281684e-05 2022-09-05 14:03:18,399 Thread-51 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:18,401 Thread-51 udi_interface INFO vue:query: 7 -- 0.0001893638780381944 2022-09-05 14:03:18,401 Thread-51 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:18,403 Thread-51 udi_interface INFO vue:query: Balance -- 7.710042397181244e-06 2022-09-05 14:03:18,404 Thread-51 udi_interface INFO vue:query: Updating child node 136598_Balance 2022-09-05 14:03:18,405 Thread-51 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 14:03:18,405 Thread-51 udi_interface ERROR udi_interface:write: Thread-51 2022-09-05 14:03:18,406 Thread-51 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:18,407 Thread-51 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 14:03:18,407 Thread-51 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner 2022-09-05 14:03:18,412 Thread-51 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 14:03:18,413 Thread-51 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run 2022-09-05 14:03:18,416 Thread-51 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 14:03:18,417 Thread-51 udi_interface ERROR udi_interface:write: File "./vue.py", line 25, in poll 2022-09-05 14:03:18,419 Thread-51 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 14:03:18,420 Thread-51 udi_interface ERROR udi_interface:write: File "./vue.py", line 55, in query 2022-09-05 14:03:18,421 Thread-51 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 14:03:18,422 Thread-51 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 14:03:18,422 Thread-51 udi_interface ERROR udi_interface:write: : 2022-09-05 14:03:18,423 Thread-51 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 14:03:18,545 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598 :: CPW to 0.9385 UOM 30 2022-09-05 14:03:18,639 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_2 :: CPW to 0.0054 UOM 30 2022-09-05 14:03:18,723 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_4 :: CPW to 0.0432 UOM 30 2022-09-05 14:03:18,812 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_5 :: CPW to 0.0332 UOM 30 2022-09-05 14:03:18,913 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_6 :: CPW to 0.1473 UOM 30 2022-09-05 14:03:19,009 MQTT udi_interface.interface INFO interface:_message: Successfully set 136598_7 :: CPW to 0.6817 UOM 30 2022-09-05 14:03:20,428 Thread-52 udi_interface INFO vue:query: 1,2,3 -- 0.0002254942237006293 2022-09-05 14:03:20,429 Thread-52 udi_interface INFO vue:query: Updating child node 136598 2022-09-05 14:03:20,431 Thread-52 udi_interface INFO vue:query: 1 -- 0.0 2022-09-05 14:03:20,432 Thread-52 udi_interface INFO vue:query: 2 -- 0.0 2022-09-05 14:03:20,433 Thread-52 udi_interface INFO vue:query: 4 -- 1.1443371242947049e-05 2022-09-05 14:03:20,433 Thread-52 udi_interface INFO vue:query: Updating child node 136598_4 2022-09-05 14:03:20,435 Thread-52 udi_interface INFO vue:query: 5 -- 9.414665434095594e-06 2022-09-05 14:03:20,436 Thread-52 udi_interface INFO vue:query: Updating child node 136598_5 2022-09-05 14:03:20,438 Thread-52 udi_interface INFO vue:query: 6 -- 3.957937452528212e-05 2022-09-05 14:03:20,439 Thread-52 udi_interface INFO vue:query: Updating child node 136598_6 2022-09-05 14:03:20,441 Thread-52 udi_interface INFO vue:query: 7 -- 0.00015306245591905382 2022-09-05 14:03:20,441 Thread-52 udi_interface INFO vue:query: Updating child node 136598_7 2022-09-05 14:03:20,443 Thread-52 udi_interface INFO vue:query: Balance -- 1.1994356579250726e-05 2022-09-05 14:03:20,444 Thread-52 udi_interface INFO vue:query: Updating child node 136598_Balance Link to comment
Geddy Posted September 5, 2022 Share Posted September 5, 2022 @Kevin @tazman @TJF1960 Will you please STOP posting the text (full or clips) of your logs? Logs should be posted as file attachments. I'm not sure why one of you keep saying "it won't let me upload the log". I've tried it...you just need to take an extra step to put it into a .zip file. In Windows: Download your log open the folder you saved it to Right click -> Send to -> Compressed (Zipped) Folder rename/accept name Upload ZIP file to your post with "Choose files" or drag-and-drop into the post. It's much easier for the developer to read the logs as files rather than posts on the forums. At least it's more helpful (IMO). And it cuts down on the useless scrolling that exists in this thread of late. PS: Also, never post PG3 system logs in open forums. Those should only be sent through PM. Individual node server logs might be okay to post here, but do remember...these are PUBLIC FORUMS. It's possible some of this stuff might have personal information that you don't want posted openly. Thanks! 1 Link to comment
tazman Posted September 5, 2022 Share Posted September 5, 2022 20 minutes ago, bpwwer said: @tazman Is it the CT's that are named with an '&' in the name that aren't showing up? I believe that's not a valid character for node names. I'll add some check make sure the names are valid before trying to create the nodes. You are correct it was the characters that were preventing some ct's from showing so I corrected that and they all show in the AC now but they still all show the same value. Everything looks good for the nodes in PG3 but does not transfer to the AC for some reason. 2022-09-05 11:10:04,313 Thread-28 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': '31548_16', 'driver': 'CPW', 'value': '2.0723', 'uom': 30}]} 2022-09-05 11:10:04,314 Thread-28 udi_interface INFO vue:query: TotalUsage -- 0.0008593049197726779 2022-09-05 11:10:04,315 Thread-28 udi_interface INFO vue:query: Updating child node 31548_TotalUsage 2022-09-05 11:10:04,316 Thread-28 udi_interface ERROR udi_interface:write: Exception in thread 2022-09-05 11:10:04,317 Thread-28 udi_interface ERROR udi_interface:write: Thread-28 2022-09-05 11:10:04,318 Thread-28 udi_interface ERROR udi_interface:write: : 2022-09-05 11:10:04,318 Thread-28 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-09-05 11:10:04,319 Thread-28 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner 2022-09-05 11:10:04,323 Thread-28 udi_interface ERROR udi_interface:write: self.run() 2022-09-05 11:10:04,325 Thread-28 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run 2022-09-05 11:10:04,328 Thread-28 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2022-09-05 11:10:04,329 Thread-28 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_8/./vue.py", line 25, in poll 2022-09-05 11:10:04,331 Thread-28 udi_interface ERROR udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True) 2022-09-05 11:10:04,332 Thread-28 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_8/./vue.py", line 55, in query 2022-09-05 11:10:04,333 Thread-28 udi_interface ERROR udi_interface:write: polyglot.getNode(address).update_current(channel.usage) 2022-09-05 11:10:04,334 Thread-28 udi_interface ERROR udi_interface:write: AttributeError 2022-09-05 11:10:04,335 Thread-28 udi_interface ERROR udi_interface:write: : 2022-09-05 11:10:04,335 Thread-28 udi_interface ERROR udi_interface:write: 'NoneType' object has no attribute 'update_current' 2022-09-05 11:10:04,403 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2022-09-05 11:10:04,405 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 I just tried it twice just as you said and it gives me an error it was working yesterday but not today it might be the size that it has gotten to Link to comment
tazman Posted September 5, 2022 Share Posted September 5, 2022 6 minutes ago, Geddy said: @Kevin @tazman @TJF1960 Will you please STOP posting the text (full or clips) of your logs? Logs should be posted as file attachments. I'm not sure why one of you keep saying "it won't let me upload the log". I've tried it...you just need to take an extra step to put it into a .zip file. In Windows: Download your log open the folder you saved it to Right click -> Send to -> Compressed (Zipped) Folder rename/accept name Upload ZIP file to your post with "Choose files" or drag-and-drop into the post. It's much easier for the developer to read the logs as files rather than posts on the forums. At least it's more helpful (IMO). And it cuts down on the useless scrolling that exists in this thread of late. PS: Also, never post PG3 system logs in open forums. Those should only be sent through PM. Individual node server logs might be okay to post here, but do remember...these are PUBLIC FORUMS. It's possible some of this stuff might have personal information that you don't want posted openly. Thanks! I was trying to upload the file but it would not upload. I think I was downloading the log package and it was to big but I will try to do the file via PM in the future. Link to comment
Geddy Posted September 5, 2022 Share Posted September 5, 2022 @Kevin you're probably not putting the .txt file into .zip format. 13 minutes ago, tazman said: I think I was downloading the log package and it was to big but I will try to do the file via PM in the future. Same for you @tazman, the forums will not allow you to upload a .txt file. I tested with two different node servers downloading their individual logs. They downloaded as .txt files. The system said upload failed. I compressed them to .zip and it uploaded just fine. One log file was several mb in size as .txt file was compressed to ~150kb as .zip. If you have the error that it was too big then you're probably uploading a .txt file. Always compress and attach as .zip files! Even if you try to send in PM it won't let you send a .txt file. You should attach as .zip. Either way, I'm sure you agree that the lengthy logs showing above make this a little lot more difficult to read and actually keep up with the help being offered. Thanks! 1 Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 how do I clear the server log. mine have become 48,000 kb compressed now the only way I have found to clear them out is to uninstall them and reinstall them there was a clear log before but it seems to be gone? Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 From both the log posting it appears to be the same issue effecting both. I think it's the total/balance channels that create node address that the ISY can't handle and thus when it tries to update those it fails. Right now, when something fails in the updates, it stops and doesn't try to update anything else. I'll fix that so that it continues and finishes updating the rest of the devices/channels. I'll also look at fixing the addresses so that it's not trying to create nodes with invalid addresses. @Geddywhile I agree that .zip attachments would make the thread easier to follow, I also don't have a problem with log snippets. In general, I only need to see the part of the log where it's failing. Right now the node server is generating quite a bit of log info quickly since it's doing some of the updates every second. There really isn't any way to to clear out the log short of uninstalling the node server and re-installing it. The log does start over every day but that doesn't really help when it's been running for hours generating log info every second. As we get things working better I'll remove most of that output. Also, increasing the short poll interval to something like 10 or even 20 seconds would reduce the frequency of the logging a lot but still generate what we need in a reasonable time frame. 1 Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 version 1.0.14 should be available in the store now. refresh store and restart to test it. This has the 2 changes discussed in the post above. Link to comment
bpwwer Posted September 5, 2022 Share Posted September 5, 2022 I just realized I didn't address @Kevin's issue of one device showing connected while the other shows disconnected. I tried using PG3's built in connection status for those and I think it may only properly handle connection status on one node for the node server. That is something I'll need to look into. Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 The install stopped at my unnamed channel and just quit. 2022-09-05 15:20:15,777 Command udi_interface.interface INFO interface:_disconnect: MQTT Graceful disconnection. 2022-09-05 15:21:24,294 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-09-05 15:21:26,471 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.47 Starting... 2022-09-05 15:21:27,225 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.0.63 [ISY: 5.4.4, Slot: 6] 2022-09-05 15:21:27,227 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.12.167', 'netmask': '255.255.255.0', 'broadcast': '192.168.12.255'} 2022-09-05 15:21:27,229 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:1888 2022-09-05 15:21:27,236 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'config': {'version': '1.0.14'}} 2022-09-05 15:21:27,293 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2022-09-05 15:21:27,295 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:5e:df:b4_6 - MID: 1 Result: 0 2022-09-05 15:21:27,315 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-09-05 15:21:27,402 MQTT udi_interface.interface INFO interface:_message: Successfully set 136723 :: ST to 1 UOM 25 2022-09-05 15:21:30,261 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2022-09-05 15:21:30,478 Thread-2 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2022-09-05 15:21:30,482 Thread-2 udi_interface INFO vue:parameterHandler: Logging in to Emporia Cloud 2022-09-05 15:21:30,636 MQTT udi_interface.interface INFO interface:_message: custom data response {'customparamsdoc': '<h2>Configuration</h2>\n\n<p>The VUE node server has the following user configuration parameters:</p>\n\n<ul>\n<li>Username : Your emporia account username</li>\n<li>Password : Your emporia account password</li>\n</ul>\n'} 2022-09-05 15:21:30,679 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc 2022-09-05 15:21:30,974 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2022-09-05 15:21:30,988 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2022-09-05 15:21:36,110 Thread-2 udi_interface INFO vue:discover: GID: 136598 2022-09-05 15:21:36,111 Thread-2 udi_interface INFO vue:discover: Manufacturer: A2201A05B524D7EB9C91AC 2022-09-05 15:21:36,112 Thread-2 udi_interface INFO vue:discover: Model: VUE002 2022-09-05 15:21:36,112 Thread-2 udi_interface INFO vue:discover: Firmware: Vue2-159 2022-09-05 15:21:36,113 Thread-2 udi_interface INFO vue:discover: Name: backup panel 2022-09-05 15:21:36,115 Thread-2 udi_interface INFO vue:discover: Creating device node for backup panel (136598) 2022-09-05 15:21:36,117 Thread-2 udi_interface.interface INFO interface:addNode: Adding node backup panel(136598) [None] 2022-09-05 15:21:36,119 Thread-2 udi_interface.interface INFO interface:setController: Using node "136598", driver "ST" for connection status. 2022-09-05 15:21:36,121 Thread-2 udi_interface INFO vue:discover: Found channel: 1,2,3 - None 2022-09-05 15:21:36,419 Thread-2 udi_interface INFO vue:discover: GID: 136598 2022-09-05 15:21:36,420 Thread-2 udi_interface INFO vue:discover: Manufacturer: SXA2201A05B524D7EB9C91AC 2022-09-05 15:21:36,421 Thread-2 udi_interface INFO vue:discover: Model: WAT001 2022-09-05 15:21:36,421 Thread-2 udi_interface INFO vue:discover: Firmware: None 2022-09-05 15:21:36,422 Thread-2 udi_interface INFO vue:discover: Name: backup panel 2022-09-05 15:21:36,423 Thread-2 udi_interface INFO vue:discover: Found channel: 1 - 1 ac compressor 2022-09-05 15:21:36,425 Thread-2 udi_interface INFO vue:discover: Creating child node 1 ac compressor / 136598_1 2022-09-05 15:21:36,427 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 1 ac compressor(136598_1) [None] 2022-09-05 15:21:36,429 Thread-2 udi_interface INFO vue:discover: Found channel: 2 - 2 furnace blower 2022-09-05 15:21:36,430 Thread-2 udi_interface INFO vue:discover: Creating child node 2 furnace blower / 136598_2 2022-09-05 15:21:36,432 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 2 furnace blower(136598_2) [None] 2022-09-05 15:21:36,433 Thread-2 udi_interface INFO vue:discover: Found channel: 3 - don't know 2022-09-05 15:21:36,434 Thread-2 udi_interface INFO vue:discover: Creating child node dont know / 136598_3 2022-09-05 15:21:36,436 Thread-2 udi_interface.interface WARNING interface:addNode: addNode(): Cannot be used to change the node's name 2022-09-05 15:21:36,437 Thread-2 udi_interface.interface INFO interface:addNode: Adding node don't know(136598_3) [None] 2022-09-05 15:21:36,438 Thread-2 udi_interface INFO vue:discover: Found channel: 4 - 4 kitchen lights and outlets backyard light 2022-09-05 15:21:36,439 Thread-2 udi_interface INFO vue:discover: Creating child node 4 kitchen lights and outlets backyard light / 136598_4 2022-09-05 15:21:36,441 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 4 kitchen lights and outlets backyard light(136598_4) [None] 2022-09-05 15:21:36,443 Thread-2 udi_interface INFO vue:discover: Found channel: 5 - 5 living room tv 2022-09-05 15:21:36,444 Thread-2 udi_interface INFO vue:discover: Creating child node 5 living room tv / 136598_5 2022-09-05 15:21:36,446 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 5 living room tv(136598_5) [None] 2022-09-05 15:21:36,448 Thread-2 udi_interface INFO vue:discover: Found channel: 6 - 6 playroom lights and bathroom 2022-09-05 15:21:36,448 Thread-2 udi_interface INFO vue:discover: Creating child node 6 playroom lights and bathroom / 136598_6 2022-09-05 15:21:36,450 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 6 playroom lights and bathroom(136598_6) [None] 2022-09-05 15:21:36,452 Thread-2 udi_interface INFO vue:discover: Found channel: 7 - 7 work bench and playroom outlets and refrigerator 2022-09-05 15:21:36,453 Thread-2 udi_interface INFO vue:discover: Creating child node 7 work bench and playroom outlets and refrigerator / 136598_7 2022-09-05 15:21:36,454 Thread-2 udi_interface.interface INFO interface:addNode: Adding node 7 work bench and playroom outlets and refrigerator(136598_7) [None] 2022-09-05 15:21:36,456 Thread-2 udi_interface INFO vue:discover: Found channel: 8 - None 2022-09-05 15:21:36,457 Thread-2 udi_interface ERROR vue:parameterHandler: Discovery failed: encoding without a string argument Link to comment
tazman Posted September 5, 2022 Share Posted September 5, 2022 @bpwwerTHANK YOU! you are very close for me. The main thing I notice is the air conditioner (#16) ct gets stuck and does not change value from the log it looks like it might be a scaling problem. PG3.zip 1 Link to comment
Kevin Posted September 5, 2022 Share Posted September 5, 2022 1 minute ago, tazman said: @bpwwerTHANK YOU! you are very close for me. The main thing I notice is the air conditioner (#16) ct gets stuck and does not change value from the log it looks like it might be a scaling problem. PG3.zip 2.2 kB · 0 downloads see I don't have that problem here in Buffalo we are getting ready to turn the heat on LOL I wont see that issue until next July LOL Link to comment
tazman Posted September 5, 2022 Share Posted September 5, 2022 1 minute ago, Kevin said: see I don't have that problem here in Buffalo we are getting ready to turn the heat on LOL I wont see that issue until next July LOL Well I moved from PA about 10 years ago and I'm happy to have that problem ;) Link to comment
