6 button Key Pad and FanLinc going crazy
I Have a 6 button key pad and a Fan Linc.  I accidently deleted it and now playing hell to get it to work again.  It still works via Alexia.
1st Question.  WHY is button A and B defualt on.  ????
What are you using to control your devices? If you've deleted the device, Alexa should not be able to control it.
Are you referring to the A and B button or the large top and bottom buttons
1 minute ago, danncas said:
a and b
A and B are not on by default unless you have an 8 button faceplate on a 6 button keypad making the large button A and B.
update. I have every button doing what it should.  Only problem is I dont remember how I made tnhe button light out for each scene  ex.. button A when fan on high  ect
Follow the directions in this link for either 5.x firmware or if you scroll down a bit you will find the 4.x setup. Both the 5.x and the 4.x listed will keep the lights in sync, and support voice integration and control via Alexa etc.
https://wiki.universal-devices.com/index.php?title=ISY994i:INSTEON_Device:FanLinc-KPL_FanLinc_KeypadLinc_Configuration
I found that The one Scene Doesnt work for what  I want. So I have 4 Scenes  high med low off.
Now how do I get the A ,B,C,D,  LED  to light with each scene. I tried a program staus of fan motor to run a LED scene but nothing works.  IDEAS ????
Edited by danncas
typo
See link provided above. Just have to read through it
Edited by lilyoyo1
