PLM DB9 to RJ45 cable
 have not seen this information, but moving the Insteon 994 setup to Polisy I need to install the serial cable, which of course is long gone.
I need to set it up very quickly so does anyone have the pinout for the Polisy serial port to the Smarthome 2413s?
much appreciated
thanks  i can make one now.
  • 3 months later...
Perhaps one of the easiest approaches is to buy the RS232 port with wiring terminal, cut off one end of an ethernet cable and make the three connections needed.
Amazon.com: YIOVVOM DB9 Breakout Connector to Wiring Terminal RS232 D-SUB Male Serial Adapters Port Breakout Board Solder-Free Module with case( Female Serial Adapter) : Electronics
