June 10, 20224 yr 11 minutes ago, drprm1 said: Again, where do you see “toggle” Is it a single node or associated with something else? It is a separate node
June 10, 20224 yr 42 minutes ago, Panda88 said: I need to implement finger - it is not supported yet - I only use the other garage controller - if you are willing to help test it I can add the code for finger Absolutely!
June 10, 20224 yr When I implemented finger it seemed to take control of the garage sensor ns. Not sure how
June 10, 20224 yr 2 hours ago, drprm1 said: When I implemented finger it seemed to take control of the garage sensor ns. Not sure how 2 hours ago, drprm1 said: I Well I don’t have it Yes - I need to create a node for the finger controller - i'll see if I can add it tomorrow - and then you can give it a try - I do not have one, so I cannot test it here
June 10, 20224 yr 2 hours ago, drprm1 said: When I implemented finger it seemed to take control of the garage sensor ns. Not sure how The API keeps the two separate - I need to create a finger node for it to work - the yolink app may link them for direct control (no need to go through cloud)
June 10, 20224 yr 8 hours ago, Panda88 said: The API keeps the two separate - I need to create a finger node for it to work - the yolink app may link them for direct control (no need to go through cloud) Greatly appreciate your help with YoLink!
June 10, 20224 yr 3 hours ago, drprm1 said: Greatly appreciate your help with YoLink! Dropped 0.3.6 - should support Finger - if you run into issues set debug level to debug and send me the log Hopefully it works, but I have no way to test
June 10, 20224 yr The finger update does control the door by hitting the toggle button…. Kind of a pain to have to change over to a different screen to tell if the door is open or closed I had the garage status Yolink before getting the finger controller. (They have to change the name) When finger was set up it meshed with the status device to show on one page.
June 10, 20224 yr 1 hour ago, drprm1 said: The finger update does control the door by hitting the toggle button…. Kind of a pain to have to change over to a different screen to tell if the door is open or closed I had the garage status Yolink before getting the finger controller. (They have to change the name) When finger was set up it meshed with the status device to show on one page. I think they have an API with more capability that what is offered externally - lot of settings in the APP is not available in the external API. It would have been great to be able to combine the two but unfortunately I do not know how
June 10, 20224 yr Dropped 0.4.0 Added support for Control (and state) in relevant nodes Let me know it works
June 11, 20224 yr 1 hour ago, drprm1 said: Installed 4.0 Nothing different on any of my nodes. Changes should be int he programming are - if you choose control in the conditional statement the nodes that can be controlled should show up now - e.g. a motion sensor should show up allowing control when there is motion - vs. a state change as before - In my mind there is little difference as the node server is MQTT based so the state change happens at the same time but it does not hurt to support both I guess . Or are you saying you do not see the nodes under control?
June 11, 20224 yr Can’t speak for motion detectors as I have none. The nodes show up in programming Here are programming options for finger and a plug
June 11, 20224 yr While there is no control over the door on the node page of AC there is in UD mobile
June 11, 20224 yr 2 hours ago, drprm1 said: Can’t speak for motion detectors as I have none. The nodes show up in programming Here are programming options for finger and a plug the changes are in the IF portion
June 11, 20224 yr 2 hours ago, drprm1 said: While there is no control over the door on the node page of AC there is in UD mobile Is this a yolink device ? The door state is an input (opened or closed) - to control the door need to use the finger - issue a toggle to the finger
June 11, 20224 yr Author Odd, I install ver 4.0 and looks OK for a few seconds then reverts back to ver 3.6. I have uninstalled and reinstalled several times, same issue
June 11, 20224 yr 0 means closed - there is an issue that I have been struggling to find on the udiMobile - is somehow does not pick up the number to text conversion
June 11, 20224 yr 29 minutes ago, jkraus said: Odd, I install ver 4.0 and looks OK for a few seconds then reverts back to ver 3.6. I have uninstalled and reinstalled several times, same issue I forgot to change the version number in the code - did a 0.4.1 - try that
June 11, 20224 yr Author OK now 4.1 so that worked, but my Motion sensor is gone, but may be an issue on my side not sure, but was working before
June 11, 20224 yr 29 minutes ago, jkraus said: OK now 4.1 so that worked, but my Motion sensor is gone, but may be an issue on my side not sure, but was working before If a device is not on line when restarted it is removed - Maybe that is too aggressive - let me know. Send me an log and I can take a look Edited June 11, 20224 yr by Panda88
June 11, 20224 yr Author well "on-line" for a MS? it showed up on the config portion of your NS, but yesterday it showed up on the AC but not now. attached is log file UDReport.txt
