19 minutes ago, jkraus said:
well "on-line" for a MS?  it showed up on the config portion of your NS, but yesterday it showed up on the AC but not now.  attached is log file
I need the log from the node server - go to polisy and go to node server and then download log
The on-line checks if the cloud api has a connection/communication with the motion sensor
It is possible I made a mistake but mine show up???
yes - it detect the motion sensor as off line when installing and then it removes it - It is probably too aggressive - I should just keep it an let it show off-line - I have to assume that devices registered are supposed to exits
I'll look at making that change later
yes, when it is off line it now shows an error in the program that was using it (since it is no longer available)
Pardon my ignorance, does this node server work thru a local API, or thru a Yolink cloud service?
There is no local API yet - they are working on something but not released yet - will likely need a new version of HUB to do it
Yes - this is expected
OK, is there a fix, otherwise it appears that I would not be able to use it?
Edited by jkraus
I'll be looking at it today - hopefully not too complex.  Also, Maybe I should change the error to warning - program should keep running and as soon as node is back on-line it should pick up again (assuming it was there when the Node server startted)
Thanks for the reply. Their product line looks very promising, but being dependent on their cloud is a deal breaker for me. No need to look further than what just happened with Smarthome.
Try 0.4.2 - I no longer remove nodes - There may be an issue with multi devices  - as I cannot create the sub nodes as there is no information on them - I'll look to keep the state but it is a more complex change
0.4.2
Not sure if this started with this version but none of my three temperature probes are updating....They do show up in AC just not with the updated temperatures......
2 hours ago, drprm1 said:
0.4.2
Can you provide a log file from the node serer?.  Aldo try to restart the node server after update.  I think there were some cloud issues yesterday
4 hours ago, drprm1 said:
Are you running a different application with the same credentials (like HA or similar) - It seems only one one application can use the same credentials at a time .  I am not 100% sure, but I have seen the same when using 2 different ISYs running the same code.   I see the code initializing but then nothing happens - it times out and reacquires the token.  I think another application has the control
I did find an error on the door sensor that I fixed - I did not update version yet but uploaded the fix I am travelling and cannot test the code change.
Only running AC and UD Mobile....And YoLink app on phone
Hey @Panda88,
Thanks for working so hard on this Node server!  The yolink stuff is awesome. The LoRa connections are really robust and battery life is so much better than the wireless tags I used previously.  I have an outdoor motion in the end of my dock some 400' from my hub and it works great.
The latest addition of the speakerhub creates so many interesting possibilities.  Have a look at this video where I use it to trip a broadcast on my google home devices triggered by a motion detector on my driveway.
Looking forward to other devices they create.
Thanks again,
Paul
Forgive me for hijacking the thread a little.  Just wanted you to know you work is greatly appreciated!
Edited by palayman
Totally agree with palayman.
Relying  more and more on YoLink than CAO tags (esp now with NS)
Using mostly for temperature monitoring...Nothing critical till NS gets dialed in.
My favorite is the pool temperature monitor. Had CAO tag monitor for it which would always get moisture inside and die. (tried four different ones which all leaked and died). Got a YoLink monitor which has been rock solid for eight months. I even found it at the bottom of the pool once.
Edited by drprm1
Really strange - There is no communication from the Yolink cloud - Using MQTT the sensors should report by them selves - I am only querying once an hour - nothing coming from the cloud -  maybe try to generate new credentials
For the UDI mobile issue - did you try to reboot the PoI ?  The text files are only read at reboot - updating the server is not enough - little strange but it seems to be the case
Rebooted polyglot and temps are updated for now. I'll keep an eye on it.
Thx
Not sure if this means anything but when I look at this Node server in dashboard it will show, in my case, that I have ten nodes. If I click on the node tab it will often show nothing. (ie the nodes seem to disappear)..They are all present in the configuration but seem to come and go under the node tab
Maybe connecting, disconnecting?
Edited by drprm1
When you reboot it is designed to remove existing nodes and then recreate them - you often need to refresh the browser to the the node server to show all - it is a known polyglot UI issue
Have you updated polyglot to latest version?  There have been some node handling changes recently
I do not see the behavior you describe - maybe you can enable debug in the log and send me a long log - Maybe I can figure out what is happening
