ISY (IoP) not found after this morning's update
I updated the Polisy via the web page this morning and I can tell that the ISY is not working, as certain events have taken place with no notification, and I cannot get to the admin console - I have rebooted the Polisy several times - also "Settings->Polisy Configuration" hangs indefinitely - have cleared Java cache, redownloaded admin console app, etc. but no success - any suggestions?
6/10/2022, 09:00:21 [polyglot] info: MyQ(11): n011_cg08464cd743 GV0 set sucessfully to 2550 : UOM 58
6/10/2022, 09:00:30 [polyglot] info: MQTTS: Client Disconnected:
6/10/2022, 09:00:30 [polyglot] error: MQTTS: clientError: polyglot_frontend-uVWTm read ECONNRESET
6/10/2022, 09:00:30 [polyglot] info: Caught SIGTERM/SIGINT Shutting down.
6/10/2022, 09:00:30 [polyglot] info: Rachio(4): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: HueEmulator(2): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: HarmonyHub(3): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: WeatherBit(6): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: Ecobee(9): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: Virtual(7): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: Push(12): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: Rachio(4): Node server Disconnected.
6/10/2022, 09:00:30 [polyglot] info: HueEmulator(2): Node server Disconnected.
6/10/2022, 09:00:30 [polyglot] info: MyQ(11): Processing command: connected
6/10/2022, 09:00:30 [polyglot] info: HarmonyHub(3): Node server Disconnected.
6/10/2022, 09:00:30 [polyglot] info: WeatherBit(6): Node server Disconnected.
6/10/2022, 09:00:30 [polyglot] info: Push(12): Node server Disconnected.
6/10/2022, 09:00:31 [polyglot] info: Ecobee(9): Node server Disconnected.
6/10/2022, 09:00:31 [polyglot] info: Virtual(7): Node server Disconnected.
6/10/2022, 09:00:31 [polyglot] info: EnvisaLink-DSC(1): Processing command: connected
6/10/2022, 09:00:31 [polyglot] info: iAquaLink(10): Processing command: connected
6/10/2022, 09:00:31 [polyglot] info: MyQ(11): Node server Disconnected.
6/10/2022, 09:00:31 [polyglot] info: iAquaLink(10): Node server Disconnected.
6/10/2022, 09:00:31 [polyglot] info: EnvisaLink-DSC(1): Node server Disconnected.
6/10/2022, 09:00:31 [polyglot] info: MQTT Client Services Stopping Gracefully.
6/10/2022, 09:01:42 [polyglot] info: Starting Polyglot....
6/10/2022, 09:01:42 [polyglot] info: Settings: Polyglot Version 2.2.13
6/10/2022, 09:01:42 [polyglot] info: Settings: Retrieved config from database
6/10/2022, 09:01:42 [polyglot] info: Running in Polisy mode
6/10/2022, 09:01:42 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
6/10/2022, 09:01:42 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883
6/10/2022, 09:01:43 [polyglot] info: MQTT Client Service: Started
6/10/2022, 09:01:43 [polyglot] info: HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 443
6/10/2022, 09:01:43 [polyglot] info: MQTTS: polyglot authenticated successfully.
6/10/2022, 09:01:43 [polyglot] info: MQTTS: Client Connected:
6/10/2022, 09:01:43 [polyglot] error: ISY: connection failed. Retrying... Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:43 [polyglot] error: ISY: connection exceeded max re-tries. Aborting. Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:43 [polyglot] error: ISY: RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:43 [polyglot] error: EnvisaLink-DSC(1): NS getNodesFromISY RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
    at new RequestError (/snapshot/polyglot-v2/node_modules/request-promise-core/lib/errors.js:14:15)
    at Request.<anonymous> (/snapshot/polyglot-v2/node_modules/request-promise-core/lib/plumbing.js:87:29)
    at Request.RP$callback [as _callback] (/snapshot/polyglot-v2/node_modules/request-promise-core/lib/plumbing.js:46:31)
    at /snapshot/polyglot-v2/node_modules/request/request.js:185:22
    at Request.emit (events.js:315:20)
    at Request.onRequestError (/snapshot/polyglot-v2/node_modules/request/request.js:881:8)
    at ClientRequest.emit (events.js:327:22)
    at Socket.socketErrorListener (_http_client.js:426:9)
    at Socket.emit (events.js:315:20)
    at emitErrorNT (internal/streams/destroy.js:92:8)
    at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
    at processTicksAndRejections (internal/process/task_queues.js:84:21)
6/10/2022, 09:01:43 [polyglot] info: NS: Starting Local Node server EnvisaLink-DSC profile number 1 :: Version 2.1.7
6/10/2022, 09:01:43 [polyglot] error: iAquaLink(10): NS getNodesFromISY RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:43 [polyglot] info: NS: Starting Local Node server iAquaLink profile number 10 :: Version 1.0.7
6/10/2022, 09:01:43 [polyglot] error: MyQ(11): NS getNodesFromISY RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:43 [polyglot] info: NS: Starting Local Node server MyQ profile number 11 :: Version 2.3.17
6/10/2022, 09:01:44 [polyglot] error: ISY: connection failed. Retrying... Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:44 [polyglot] error: ISY: connection exceeded max re-tries. Aborting. Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:44 [polyglot] error: ISY: RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:44 [polyglot] error: Push(12): NS getNodesFromISY RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
6/10/2022, 09:01:44 [polyglot] info: NS: Starting Local Node server Push profile number 12 :: Version 1.0.6
6/10/2022, 09:01:44 [polyglot] error: HueEmulator(2): NS getNodesFromISY RequestError: Error: connect ECONNREFUSED 127.0.0.1:8080
also appears that all services are running: udx, pg3, polyglot, isy and I cannot seem to get the credentials to connect to the ISY under "settings->Polyglot Settings" as the red notice always appears even after I have saved the proper credentials (and I have also tried admin/admin)
What do you mean by " not getting to the admin console"?  Does the ISY launcher open?
Try rebooting Polyglot
Also try removing power from the Polisy then let it reboot
This doesn't look right.  When I grep through my logs I see the same thing, only the "Port" value is 3000
I just did updates using ssh this morning and there was no IoP or PG3 updates... only a few bsd packages which I can't remember.
I rebooted entire Polisy and I can still login PG3 and AC.
I would suggest opening a ticket.
The admin console says "ISY not found"
Thanks - I'll try that when I get home
I'm only running PG2 node servers - I think that may have something to do with the port #, unless I'm mistaken
I did that first thing - I am hopeful that there is a fix - I just updated via the web page this morning, not sure what happened...
Polyglot settings:
Your Polyglot Web port should be 443
ISY settings:
Port should be 8080
MQTT Settings:
MQTT Port should be 1883
All - thanks - fixed after an email from Michel instructing me to do another round of updates via SSH (although, I tried that on my own earlier - I suspect something in the earlier update caused a problem and I think UDI fixed it in the following update)
All,
Sincere apologies. I should be fired!
For security reasons, we are changing the way udx, isy, pg3, and node servers are configured and communicate. In the process, we added another library (libwebsockets) for mqtt. But, udx had a conflict and thus a failure.
The upgrade upgrades udx to 2.6.4 and removes the conflict.
7 minutes ago, Michel Kohanim said:
All,
Hmm, I have 2.6.3 and upgraded this morning but not sure if that was a package that was updated, but did not experience any issues... I just checked updates again now and seen this... is this safe?
Edit... I went ahead and still works fine!
Edited by brians
No worries - every time I have encountered a problem like this (although the possibility of having to factory reset scares me), you have fixed it quickly - thanks!
