Electricity Log File Question for ISY
In anticipation of my new smart meter from our local CA Utility being installed, I turned on the flex your power polling in the electricity tab.
I just noticed in my log file that an entry was made
It had 0 in the Device column and Flexyou in the Control column.
I was wondering if this is correct or should they be reversed so that device would be flexyou and control would be 0 or 255..
Not a big deal just wondering
Hi stevehoyt,
Flex Your Power is a program independent of the Smart Meters. It simply gives you an indication of when CA ISOs may need your help.
0 = in active and the control is the module = Flex Your Power.
