Can the Polisy be wall mounted? Where can I buy an extra Polisy power supply?
Thank you,
Steve
While it can't be wall mounted as is there was a thread not to long ago talking about a 3D printed mounting bracket...see here...
Based on the reply above from @Michel Kohanim it looks like the Polisy and ISY994 can use similar power supplies. There has been a lot of other posts about the specifics of the ISY994 power supply.
From the wiki there is this about the power supply:
https://wiki.universal-devices.com/index.php?title=Main_Page#Front_Panel_LEDs.2FLights
Quote
You can try any power supply that outputs anywhere between 5 volt and 30 volts, center positive, 2mm barrel connector
Quote
I wondered yesterday when I read this thread if the wiki should be updated?  While the ISY994 accepts a wide variety of voltages, is that also true of Polisy?
  • 2 months later...
@Michel Kohanim I would like to know the answer as well.  I might be having a power supply issue and I wonder if I can just try the ISY power supply I already have.  It is only 5 volts and 0.5 amps but the Polisy has a 12V one with 2.0 amps.
