KPL LED (Non-Toggle Mode) constantly lit
Is there a way to get my KPL LED for Non-Toggle OFF mode to be unlit? Currently, regardless of if I try non-toggle ON or non-toggle OFF the LED remains lit.
Out of curiosity, are the other keys lit while in the off condition? My experience is that non-toggle off buttons will be dim, based on the setting of the entire keypad. I recall, too, that earlier models of keypads have differing capabilities with regards to backlighting and ISY access to this feature.
I should clarify, the key is not lighted to the background brightness level, but rather the full bright ON level.
They other keys are at the background brightness.
I would double check to confirm it is not set to non-toggle on, otherwise, I have no explanation within the realm of a functioning device.
Though I have never tried it, is it possible that this keypad is part of a scene that has turned it on, or in response to a programmed command? I am not even sure that it is possible to turn on a keypad set into the non-toggle off mode, but it may be worth checking.
