Polys 'Connected' - but 'Not Running' - missing '/lib/libc.so.7'
Issuing a 'Stop' 'Start' or 'Restart' does not appear to do anything in the GUI. Bulbs that were working are not working.
This appears to affect all node servers on PG3...
When starting LiFX - I see this in the debug log:
9/24/2022, 11:12:18 [pg3] info: startNs:: LiFX
9/24/2022, 11:12:18 [pg3] info: startNs:: LiFX is valid
9/24/2022, 11:12:18 [pg3] debug: checkLicense:: LiFX Getting node server store entry
9/24/2022, 11:12:18 [pg3] debug: checkLicense:: LiFX Getting node server purchase record
9/24/2022, 11:12:18 [pg3] debug: Getting status for LiFX {MAC} {GUID}
9/24/2022, 11:12:18 [pg3] info: checkLicense:: LiFX No license found for Free node server.
9/24/2022, 11:12:18 [pg3] info: startNs:: LiFX finished update check
9/24/2022, 11:12:18 [pg3] info: [LiFX(6)] :: Starting Node server - Version 2.1.26
9/24/2022, 11:12:18 [pg3] info: startNs:: LiFX updating database (enabled, timestarted)
9/24/2022, 11:12:18 [pg3] error: [LiFX(6)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/24/2022, 11:12:18 [pg3] debug: [LiFX(6)] :: Exit cause code: 1 - signal: null
Seems a library is missing (!). Not sure how that happened. Any ideas to resolve? It was working prior to the last 'pkg update && pkg upgrade' where the latest udx (among some other items) were updated.
Edited by MWareman
More from the log - during a reboot:
9/25/2022, 11:06:13 [pg3] error: [Sonos(14)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] debug: [Sonos(14)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] info: startNs:: Sonos starting polls
9/25/2022, 11:06:13 [pg3] info: Starting Node server Info timer 0
9/25/2022, 11:06:13 [pg3] error: [Timedata(9)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [ELK(10)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [LiFX(6)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [Sun(11)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [Ping(8)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [Plex-WebHook(12)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [WirelessTag(4)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [NOAA(5)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [UnifiPresence(15)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [MQTT(13)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] error: [WeatherFlow(7)] :: STDERR: ld-elf.so.1: /lib/libc.so.7: version FBSD_1.7 required by /usr/local/lib/libpython3.9.so.1.0 not found
9/25/2022, 11:06:13 [pg3] debug: [Timedata(9)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [ELK(10)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [LiFX(6)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [Sun(11)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [Ping(8)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [Plex-WebHook(12)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [WirelessTag(4)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:13 [pg3] debug: [NOAA(5)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:14 [pg3] debug: [UnifiPresence(15)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:14 [pg3] debug: [MQTT(13)] :: Exit cause code: 1 - signal: null
9/25/2022, 11:06:14 [pg3] debug: [WeatherFlow(7)] :: Exit cause code: 1 - signal: null
Looking at everything that updated a couple of days ago:
Quote
Sep 23 20:33:05 polisy pkg[2395]: python39 upgraded: 3.9.13 -> 3.9.14
Sep 23 20:33:05 polisy pkg[2395]: ca_root_nss upgraded: 3.81 -> 3.83
Sep 23 20:33:06 polisy pkg[2395]: py39-tzdata-2022.2 installed
Sep 23 20:33:06 polisy pkg[2395]: py39-acme upgraded: 1.29.0,1 -> 1.30.0,1
Sep 23 20:33:08 polisy pkg[2395]: nspr upgraded: 4.34.1 -> 4.35
Sep 23 20:33:08 polisy pkg[2395]: sqlite3 upgraded: 3.39.2,1 -> 3.39.3,1
Sep 23 20:33:11 polisy pkg[2395]: nss upgraded: 3.82 -> 3.83
Sep 23 20:33:12 polisy pkg[2395]: libdeflate upgraded: 1.13 -> 1.14
Sep 23 20:33:12 polisy pkg[2395]: py39-sqlite3 upgraded: 3.9.13_7 -> 3.9.14_7
Sep 23 20:33:12 polisy pkg[2395]: libXft upgraded: 2.3.5 -> 2.3.6
Sep 23 20:33:12 polisy pkg[2395]: dmidecode upgraded: 3.4_1 -> 3.4_2
Sep 23 20:33:49 polisy pkg[2395]: pg3 upgraded: 3.1.6 -> 3.1.10
Sep 23 20:33:50 polisy pkg[2395]: harfbuzz upgraded: 5.1.0 -> 5.2.0
Sep 23 20:33:51 polisy pkg[2395]: py39-certbot upgraded: 1.29.0,1 -> 1.30.0,1
Sep 23 20:33:53 polisy pkg[2395]: avahi-app upgraded: 0.8 -> 0.8_1
Sep 23 20:33:53 polisy pkg[2395]: py39-pytz-deprecation-shim upgraded: 0.1.0.post0 -> 0.1.0.post0_1
Sep 23 20:34:22 polisy pkg[2395]: perl5 upgraded: 5.32.1_1 -> 5.32.1_3
Sep 23 20:34:23 polisy pkg[2395]: udx upgraded: 3.3.0_2 -> 3.3.0_6
I tried reverting pg3 and udx - but this did not resolve the issue at all. I have a feeling there is a missing dependency in the updated python39.
Yes, this is a known issue.  For a period of time, the update wasn't updating one of the dependencies (that library it complains about). It should be fixed now if you do another update.
The recommended way to update is to use the "Update Packages" button in the Admin Console configuration screen.
No updates yet:
Should I be expecting to see something thru the 'pkg update && pkg upgrade' process?
Interesting.
I had not been doing this - rather 'pkg update && pkg upgrade' at the cli.
Opening the admin console - I hit this button and immediately the admin console (and finder) closed. As if it crashed. Thru SSH - I was watching /var/log/messages and nothing.
After a few mins - I started the admin console again - and all of a sudden I see events like this in /var/log/messages:
Sep 25 13:38:04 polisy pkg[4779]: FreeBSD-runtime-13.0p11 deinstalled
Sep 25 13:38:08 polisy pkg[4779]: FreeBSD-utilities-13.0p11 deinstalled
Sep 25 13:38:09 polisy pkg[4779]: FreeBSD-libbsdxml-13.0p11 deinstalled
Sep 25 13:38:09 polisy pkg[4779]: FreeBSD-libregex-13.0p11 deinstalled
Sep 25 13:38:09 polisy pkg[4779]: FreeBSD-libregex-dev-13.0p11 deinstalled
Sep 25 13:38:09 polisy pkg[4779]: FreeBSD-utilities-dev-13.0p11 deinstalled
Sep 25 13:38:09 polisy pkg[4779]: FreeBSD-libbsdxml-dev-13.0p11 deinstalled
Sep 25 13:38:14 polisy pkg[4779]: FreeBSD-runtime-13.1p2 installed
Sep 25 13:38:14 polisy pkg[4779]: FreeBSD-libmagic-13.0p11 deinstalled
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-runtime-dev-13.0p11 deinstalled
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-rc-13.0p11 deinstalled
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-liblzma-13.0p11 deinstalled
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-libthread_db upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-libbsm upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-libsmb upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-libbsdstat upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:15 polisy pkg[4779]: FreeBSD-libucl upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:16 polisy pkg[4779]: FreeBSD-bluetooth upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:16 polisy pkg[4779]: FreeBSD-libvgl upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:16 polisy pkg[4779]: FreeBSD-libcuse upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:16 polisy pkg[4779]: FreeBSD-libarchive upgraded: 13.0p11 -> 13.1p2
Sep 25 13:38:19 polisy pkg[4779]: FreeBSD-openssl-13.1p2 installed
Sep 25 13:38:19 polisy pkg[4779]: FreeBSD-libmagic-13.1p2 installed
I suspect these are the dependencies being spoke of (at some point I did earlier see a 'running kernel mismatch' error).
At the end of the upgrades - Polisy auto-rebooted:
Sep 25 13:40:02 polisy reboot[5956]: rebooted by admin
For some things, the pkg update commands can still be used, but the admin console update packages is doing some additional stuff to make sure everything is right and dependencies are correct (don't ask me what, I don't know).
  • Haha 1
Update: *MUCH* better. Polys all started. Problem looks solved. Still don't know why the admin console update did things beyond the pkg package manager.
Thank you @bpwwerfor the solution!
Good to know - thank you!
On 9/25/2022 at 3:12 PM, Michel Kohanim said:
@MWareman,
Pkg update does not go between revisions such as 13.0 to 13.1. So, the button also calls a script that makes those updates and cleans up after itself.
That makes sense now. It was odd at the time because 'pkg update' updated something that had a dependancy on a newer library that had not yet been updated.
Is there a cli way of (for instance) going from 13.0 to 13.1 safely?
35 minutes ago, Michel Kohanim said:
Hi @MWareman,
Yes:
Through ISY:
sudo /usr/local/etc/udx.d/static/udxop.sh upgrade.polisy (this is what's called from the Admin Console)
Or, brute force:
curl -s https://pkg.isy.io/script/update131.sh | sudo bash
The first is preferred because it also checks other things such as python upgrade and node servers.
This has let me down a rabbithole now..  :P
I have been having trouble witht he BIOS update - it just seemed to fail from the GUI. Of course - I noticed the 'update.bios' command in the script..  :P
[admin@polisy ~]$ sudo /usr/local/etc/udx.d/static/udxops.sh update.bios
executing from /usr/local/etc/udx.d/static
Sun Oct  2 18:28:03 CDT 2022|/usr/local/etc/udx.d/static/udxops.sh: starting bios update
Sun Oct  2 18:28:04 CDT 2022|/usr/local/etc/udx.d/static/udxops.sh: bios mfr: Universal Devices
Sun Oct  2 18:28:04 CDT 2022|/usr/local/etc/udx.d/static/udxops.sh: bios product: Polisy
Sun Oct  2 18:28:04 CDT 2022|/usr/local/etc/udx.d/static/udxops.sh: bios ver: 1.0.0
Sun Oct  2 18:28:04 CDT 2022|/usr/local/etc/udx.d/static/udxops.sh: bios version 100 is old and needs to be upgraded
flashrom  on FreeBSD 13.1-RELEASE-p2 (amd64)
flashrom is free software, get the source code at https://flashrom.org
Using default programmer "internal" with arguments "".
Using clock_gettime for delay loops (clk_id: 4, resolution: 2ns).
coreboot table found at 0xcfec5000.
Found chipset "AMD FCH".
Enabling flash write... OK.
Found Winbond flash chip "W25Q64.V" (8192 kB, SPI) mapped at physical address 0x00000000ff800000.
Using regions: "RW_SECTION_A", "RW_SECTION_B", "PSPDIR".
Reading old flash chip contents... done.
Erasing and writing flash chip... FAILED at 0x00030000! Expected=0xff, Found=0x24, failed byte count from 0x00030000-0x00030fff: 0xd                                              d2
ERASE FAILED!
Reading current flash chip contents... done. Looking for another erase function.
FAILED at 0x00030000! Expected=0xff, Found=0x24, failed byte count from 0x00030000-0x00037fff: 0x7c92
ERASE FAILED!
FAILED at 0x00030000! Expected=0xff, Found=0x24, failed byte count from 0x00030000-0x0003ffff: 0xf708
ERASE FAILED!
FAILED at 0x00000000! Expected=0xff, Found=0x2f, failed byte count from 0x00000000-0x007fffff: 0x555677
ERASE FAILED!
ERASE FAILED!
No usable erase functions left.
FAILED!
Uh oh. Erase/write failed.
Your flash chip is in an unknown state.
Get help on IRC at chat.freenode.net (channel #flashrom) or
mail flashrom@flashrom.org with the subject "FAILED: <your board name>"!
DO NOT REBOOT OR POWEROFF!
Sun Oct  2 18:29:37 CDT 2022|/usr/local/etc/udx.d/static/udxops.sh: bios update ... rebooting
POLISY then rebooted - and (fortunately) it came back. Seems the BIOS update process is failing on my POLISY and thru the CLI there is at least some detail as to why. How would I go about addressing this?
Thank you!
21 minutes ago, Michel Kohanim said:
@MWareman, do NOT poweroff. Please send your address to sales@universal-devices.com and request for a flash chip.
Request sent!
Thank you.
      37.8k
      377.5k
