ISY died, need replacement
Hello guys
After 9 years of service, my ISY died last night. After I realized all morning programs were not executed, I checked ISY and all LEDs were off. I checked the power supply and it was dead (no 5V). I replaced it, ISY boot up but it works for 1 min before the RX LED stops blinking an stay on all the time. I can log in on admin control but it is looked on a system busy status. I think PLM is ok because i managed to send some commands before the system busy scenario. However, ISY stays on this infinite loop of "writing 0 bytes to devices".
So, my first question is, should I move to Polisy or should I buy a new ISY? Im not familiar with Polisy, not sure if it is worth the upgrade.
Eduardo
Solved by hart2hart
3 minutes ago, eduardo_garcia said:
Hello guys
Eduardo
You could try replacing the power supply
Polisy is the newest version of the isy released a few years ago (currently out of stock). You can find out more information on UDI's website.
The eisy is the future (not yet released). With polisy being out of stock, I'd wait for eisy.
Either way, it's up to you to decide if you want to continue using a discontinued 9 year old device (if it's a power supply issue), or move forward and upgrade to the latest system they have to offer.
Edited by lilyoyo1
Hello lilyoyo1
I replaced the power supply, but ISY keeps on locked on system busy status. I guess something else is broken here.
I will have to wait for the new eisy. I hope Michael may ship it overseas :)
thanks
Eduardo
Hello lilyoyo1
I will have to wait for the new eisy. I hope Michael may ship it overseas [emoji4]
thanks
Eduardo
Maybe SD card was damaged when power supply failed. Replace it and restore a backup might be a possibility. Also, just saw post where a rj45 cable went bad and caused issues.
Thank you for the suggestion Hart2hart. I replaced the SD card and it fixed the issue. power supply and sd card died at the same time 😀
The failing power supply. May have caused the controller to write garbage to the SD card. Power supply issues are a failure we see here. I had a few over the years myself.
Glad you are back in business.
Thank you for the suggestion Hart2hart. I replaced the SD card and it fixed the issue. power supply and sd card died at the same time [emoji3]
Glad to hear it!
