PG3 backup - nothing happens after hitting download
On the screen
image.png.633eb0595c1ae17673242085aec5fd
When I click on Download, nothing happens.  Does the backup default to a specific folder in Windows?  I would expect it to ask me where I want the download to be placed.
Solved by bpwwer
I'm using Microsoft Edge browser and I get a popup when doing the Backup which then allows me to set the name and location for the zip file.
If on a PC, check the download folder.  I don't get a prompt either but it saves it in the download folder.  I'm using Firefox.
Edited by tmorse305
3.1.11, which I believe is the latest version.
Yes, I have restarted PG3.
Backup still doesn't work.
Did you give permission to download the files? The attached image shows what I see when  backing up PG3.
I have the following in the log file.  Looks like it is getting an error.
10/21/2022, 18:34:26 [pg3] info: Starting Backup Creation 10/21/2022, 18:34:26 [pg3] error: Backup: TypeError [ERR_INVALID_CHAR]: Invalid character in header content ["content-disposition"] at ServerResponse.setHeader (node:_http_outgoing:606:3) at Object.set (/var/polyglot/node_modules/koa/lib/response.js:467:16) at /var/polyglot/node_modules/@universaldevices/pg3/lib/routes/frontend.js:130:18 at dispatch (/var/polyglot/node_modules/koa-compose/index.js:42:32) at /var/polyglot/node_modules/@koa/router/lib/router.js:372:16 at dispatch (/var/polyglot/node_modules/koa-compose/index.js:42:32) at /var/polyglot/node_modules/koa-compose/index.js:34:12 at dispatch (/var/polyglot/node_modules/@koa/router/lib/router.js:377:31) at dispatch (/var/polyglot/node_modules/koa-compose/index.js:42:32) at allowedMethods (/var/polyglot/node_modules/@koa/router/lib/router.js:433:12) at dispatch (/var/polyglot/node_modules/koa-compose/index.js:42:32) at dispatch (/var/polyglot/node_modules/@koa/router/lib/router.js:353:32) at dispatch (/var/polyglot/node_modules/koa-compose/index.js:42:32) at jwt (/var/polyglot/node_modules/koa-jwt/lib/index.js:73:16) at async /var/polyglot/node_modules/@universaldevices/pg3/lib/services/https.js:54:9 at async compressMiddleware (/var/polyglot/node_modules/koa-compress/lib/index.js:52:5)
10/21/2022, 18:35:12 [pg3] info: set to expire on 2023-07-10T11:58:24.000Z
Do you, by chance have any strange characters in your Polisy name? Any punctuation or characters that might make a file name invalid?
Something seems to be triggering the backup to fail because of an invalid character. I wonder if might be in the Polisy name since it doesn't seem to even get to the node server level to backup.
Just ran a backup in Chrome and this is in my log:
10/22/2022, 16:00:16 [pg3] info: Starting Backup Creation
10/22/2022, 16:00:16 [pg3] debug: Creating DB Backup...
10/22/2022, 16:00:16 [pg3] debug: Creating DB Backup: Done
10/22/2022, 16:00:16 [pg3] debug: Backing up node servers
10/22/2022, 16:00:16 [pg3] debug: All node servers added to backup -- finalizing
10/22/2022, 16:00:16 [pg3] debug: Removing Backup Archive from filesystem after download
10/22/2022, 16:00:16 [pg3] info: Backup Successful
Please post back once you get help from support to tell us what resolved the issue.
I am unable to download a backup of my PG3. Settings>Polyglot Settings. There is the button there, and it darkens when my cursor goes over it, popup help appears on hover, ring highlights around it when clicked, but nothing happens. Attempted on multiple browsers.683619600_ScreenShot2022-10-26at10_13_11AM.thumb.png.8275e43acf90cf6709965495081725f7.png
