Dead ISY 994i Power Supply
Red light is blinking on power supply, nothing lights up on the ISY. I need a replacement ASAP! Any recommendations? When I put my city and zip code in the UD online store, the system states it is a four day wait. I need alternatives, please!
Solved by Geddy
What City are you located in?
Do you have access to Amazon Prime?
Mission Viejo CA
Yes, to Prime
Amazon Prime is showing October 28th as a delivery date for a 12 volt 2-amp power supply.
The only other source I can think of is All Electronics in Van Nuys. http://www.allelectronics.com   They might do an overnight ship.
You might also send an email to UD to see if they will ship overnight. I believe they also ship out of Van Nuys.
You can also check the Best Buy store in your area
Note: UD recommends a 12v, 2 amp supply.
Edited by Techman
Thanks so much! Turns out I have an extra ISY with a power supply that a neighbor gave me when they moved! Back up and running! However, I will be buying a spare...
1 hour ago, larryllix said:
Here it is in Canada amazon.ca, since it states "Not available"
There are many similar products on the US store, search the Canadian store for "12v UPS".
Edited by MrBill
I don't find any units that can compare with the specs and price of the unit @Goose66 linked, even for double that price. It seems like a very versatile unit and would not even require the regular power supply for ISY or polisy.
Note that the TalentCell comes with a 2A power supply. It’s fine for ISY (and probably Polisy) and keeping the battery charged. However, if you’re going to run more things off it, you will need to up the amperage of your 12v PS accordingly.
