E12 LED 40w equivalent candelabra bulb, no flicker with Insteon dimmers
ThisIsTheWay
Can anyone suggest an E12 candelabra LED 40w equivalent blub that works well with Insteon dimmers?
I've bought 3 different models off amazon, all flicker when dimmed (even the ones that claim they would not.
I use Feit bulbs and have no flicker.
Which brands have you tried? How many bulbs do you have on one dimmer?
Edited by Techman
1 hour ago, jec6613 said:
If you can find them still, Philips Warm Glow work very well.  Most Amazon knock-off brands do pretty poorly though.
I will grab some of these Phillips Warm Glow.  Have had luck with their other offerings in the past.  A little hard to track down these days.
I tried these three with no luck:
  1. https://www.amazon.com/gp/product/B08T7H2FKN
  2. https://www.amazon.com/gp/product/B0792BKRM
  3. https://www.amazon.com/gp/product/B07V42LQG1
Worst worst case ill just use incandescent
Edited by uffy
I find all brands of bulbs have good and bad.  I always had good luck with Philips bulbs, years back, and bought dozens for my new home, but they were always more expensive. I had really crap bulbs with their first run of Hue bulbs, and terrible luck with two batches of Warm Glow bulbs and now Philips is being faded out from the shelves in Home Depot Canada. The Warm and Glow ones flickered just above, and wouldn't produce any light under about 40% on an Insteon SwitchLinc. Dimmer. I have always had better luck with dimmable bulbs but they are getting very hard to get. All the bulks buy boxes of bulbs, regardless of brand are Non-Dimmable, around here now. I did see GE make a debut in a  Lowes Canada store this morning.
This happened to me with the Cree bulbs also. They were the best in the beginning. Now I have none left and HD Canada took them off the shelves. Feit bulbs were excellent for a time but they have disappeared from out local stores now also.
Best to try a package and don't make any marks on the base. HD would return mine if they were never used and they looked at the base for abrasions,
Ditto on the Phillips. I installed 100 of these in my church running on Insteon switches and am very happy with them.  The color is good and when you dim them they turn more orange, like an incandescent.  They are now just past their one year anniversary with no failures, running about 20 hours per week.  These are more like 60w eq.  It cost about $600, but by my math, we have already saved over $600, so it is all bonus now.  And that is just based on decreased electricity for the bulbs, not the AC savings from 1/10 the heat load.  And they do not flicker at all.  However, on one switch I also had a cheap closet LED and there was some weird interaction that caused them to blink.  I had to remove that closet light.  I did not test these with just one bulb on the switch, I think the least number of bulbs on any one switch is maybe 6.
https://www.bulbsdepot.com/bd39-550250.html
EDIT: I noticed they have two pictures on the website of different looking bulbs.  My bulbs all look like the second picture.  The metal base does poke out of the socket and you can see it.  This is I assume necessary as a heat sink.
Edited by apostolakisl
  • 4 weeks later...
      37.5k
      375.5k
