Purchase and upgrade issue
tjkintz
I have purchased the NS and am left with two choices. From the NS production store, I can install it but slot 1 is not available because that is where the YO NS is already installed. From the Polisy dashboard I can stop, start or restart but get the message Automatic Upgrade failed. The one thing I do not want to do is delete the NS and install it because in the past, that has totally broken anywhere in IoP where I reference a YO node, which is a lot of places. So, how do I get the purchased NS to upgrade the NS in slot 1?
The PG3 log should show why it's failing to upgrade.   We need to see what's in the log after you stop and restart the node server.
Re: PG3 log, it is below. The last entry in the NS log was around 8:38.
11/2/2022, 08:37:41 [pg3] info: [00:0d:b9:5e:e1:4c_1] setup reporting command DON 11/2/2022, 08:37:41 [pg3] debug: Scheduling http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DON to group commandGroup 11/2/2022, 08:37:41 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:e1:4c] :: [200] :: 6.236948ms - http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DON 11/2/2022, 08:37:41 [pg3] debug: MQTT Results: [ns/command/00:0d:b9:5e:e1:4c,1] :: {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:37:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:37:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"shortPoll":{}} 11/2/2022, 08:38:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:41 [pg3] debug: [MESSAGE_PUBLISHED] Client 00:0d:b9:5e:e1:4c_1 has published message on udi/pg3/ns/command/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:41 [pg3] info: [00:0d:b9:5e:e1:4c_1] setup reporting command DOF 11/2/2022, 08:38:41 [pg3] debug: Scheduling http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DOF to group commandGroup 11/2/2022, 08:38:41 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:5e:e1:4c] :: [200] :: 5.594039ms - http://192.168.1.21:8080/rest/ns/1/nodes/n001_setup/report/cmd/DOF 11/2/2022, 08:38:41 [pg3] debug: MQTT Results: [ns/command/00:0d:b9:5e:e1:4c,1] :: {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:38:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"command":[{"address":"setup","success":true}]} 11/2/2022, 08:38:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:50 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:38:50 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":1666454312735,"timeModified":1667159593079,"version":"0.5.21","branch":"main","url":"https://github.com/Panda88CO/udi-yolink","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Beta","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:38:50 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":1666454312735,"timeModified":1667159593079,"version":"0.5.21","branch":"main","url":"https://github.com/Panda88CO/udi-yolink","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Beta","dbVersion":1,"notices":{},"nodes":[{"id":"813b4952-e08d-4fe0-83c7-88adde7d8266","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","name":"Margie Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f77c","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219974598,"timeModified":1659219974598,"dbVersion":1,"drivers":[{"id":"601a4002-db02-462b-b13f-1e07b548f93e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"GV8","value":"1","uom":25,"timeAdded":1659219974841,"timeModified":1667376142394,"dbVersion":1},{"id":"ae83f913-873b-42cc-9be0-c077c6dd3ac5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"ST","value":"1","uom":25,"timeAdded":1659219974854,"timeModified":1667376142460,"dbVersion":1}]},{"id":"c52edaf1-0cf2-46af-83ba-c905e55d8615","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","name":"Tom Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f924","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219980275,"timeModified":1659219980275,"dbVersion":1,"drivers":[{"id":"2d60d34a-cf4b-4907-8a4f-020537fb0405","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"GV8","value":"1","uom":25,"timeAdded":1659219980513,"timeModified":1667376144140,"dbVersion":1},{"id":"ead3fea4-2a4a-4d51-98e6-a57394657850","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"ST","value":"1","uom":25,"timeAdded":1659219980528,"timeModified":1667376144245,"dbVersion":1}]},{"id":"f059b078-e78e-475b-8efe-0562e4d7e86e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","name":"Tom Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fd0a","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219981905,"timeModified":1659219981905,"dbVersion":1,"drivers":[{"id":"1daac6db-30b4-4aca-b002-72fe09151c72","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV0","value":"0","uom":25,"timeAdded":1659219982156,"timeModified":1667399621568,"dbVersion":1},{"id":"fc13a4c5-dd1a-4305-bac2-4b0c55731a8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV1","value":"4","uom":25,"timeAdded":1659219982168,"timeModified":1667399621763,"dbVersion":1},{"id":"6ef1f2b5-acb5-4bcd-a417-10fd20d66350","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV8","value":"1","uom":25,"timeAdded":1659219982180,"timeModified":1667399621861,"dbVersion":1},{"id":"22fc6eaa-2155-4a52-b9de-01d037904601","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"ST","value":"1","uom":25,"timeAdded":1659219982193,"timeModified":1667376144642,"dbVersion":1}]},{"id":"c3ab3751-e116-4a92-8c10-bda2bcb7f7b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","name":"Margie Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fdb4","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219975781,"timeModified":1659219975781,"dbVersion":1,"drivers":[{"id":"fc8a3293-30cc-48db-ab5a-a0b6cd299b28","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV0","value":"0","uom":25,"timeAdded":1659219976036,"timeModified":1667397534012,"dbVersion":1},{"id":"83279de0-998a-449e-a145-e54c0348a5b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV1","value":"4","uom":25,"timeAdded":1659219976048,"timeModified":1667397534160,"dbVersion":1},{"id":"e0d5500f-b840-4627-829e-b1a9adc79ae0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV8","value":"1","uom":25,"timeAdded":1659219976062,"timeModified":1667397534240,"dbVersion":1},{"id":"fe877359-d308-41fc-adad-a23bf191370e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"ST","value":"1","uom":25,"timeAdded":1659219976074,"timeModified":1667376142901,"dbVersion":1}]},{"id":"1b197090-0486-43b6-9075-d5c957952cf0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","name":"Hot water circulate","nodeDefId":"yooutlet","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004424e","private":null,"isPrimary":1,"enabled":1,"timeAdded":1665181551200,"timeModified":1665181551200,"dbVersion":1,"drivers":[{"id":"951c1ea4-a045-4b8f-bfd1-6ab36922424a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV0","value":"1","uom":25,"timeAdded":1665181551466,"timeModified":1667399561462,"dbVersion":1},{"id":"79d2b2e8-bacb-4b5f-a58c-3463b4c5f6d6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV1","value":"0","uom":57,"timeAdded":1665181551481,"timeModified":1667376140591,"dbVersion":1},{"id":"688ad939-7601-46d2-a882-4333d828144b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV2","value":"0","uom":57,"timeAdded":1665181551496,"timeModified":1667376140677,"dbVersion":1},{"id":"cdddf672-7264-4068-9b5a-57039311a69a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV3","value":"0","uom":30,"timeAdded":1665181551509,"timeModified":1667399561684,"dbVersion":1},{"id":"f0ae2242-248e-453f-af1f-7cc15b0494ca","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV4","value":"0","uom":33,"timeAdded":1665181551522,"timeModified":1667399561797,"dbVersion":1},{"id":"eaede574-1d2b-4764-9135-780228d5dc44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV8","value":"1","uom":25,"timeAdded":1665181551534,"timeModified":1667399561586,"dbVersion":1},{"id":"5fc65bf9-cd13-4cda-9a27-9e33c9ad13d8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"ST","value":"1","uom":25,"timeAdded":1665181551545,"timeModified":1667376141268,"dbVersion":1}]},{"id":"50708041-836e-446e-b186-e77f09e32298","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","name":"Cantina heater","nodeDefId":"yomultiout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219969777,"timeModified":1659219969777,"dbVersion":1,"drivers":[{"id":"80039714-76ce-4f95-af07-259d9292385b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"GV8","value":"1","uom":25,"timeAdded":1659219970045,"timeModified":1667376140255,"dbVersion":1},{"id":"aff68dda-aaca-4ddf-99fd-6dd12f34d340","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"ST","value":"1","uom":25,"timeAdded":1659219970063,"timeModified":1667376140386,"dbVersion":1}]},{"id":"b32773ae-4261-4d5d-b907-a706f882dc47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","name":"Outlet-1","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610466136,"timeModified":1661610466136,"dbVersion":1,"drivers":[{"id":"ff95de04-309c-4b49-9333-324702a2959a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV0","value":"0","uom":25,"timeAdded":1661610466465,"timeModified":1667398661282,"dbVersion":1},{"id":"5271dbf3-38ef-4288-b019-358cd131d4e7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV1","value":"0","uom":57,"timeAdded":1661610466479,"timeModified":1667376146838,"dbVersion":1},{"id":"ce32098c-dbb3-4345-96d0-17fe146ec4d0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV2","value":"0","uom":57,"timeAdded":1661610466494,"timeModified":1667376146944,"dbVersion":1},{"id":"95bbc59b-4bd5-48a6-b6b1-480ef8539624","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV4","value":"0","uom":25,"timeAdded":1661610466507,"timeModified":1667376147041,"dbVersion":1},{"id":"a0dd50e0-d8ea-4573-84ca-a219e1f29d47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"ST","value":"1","uom":25,"timeAdded":1661610466522,"timeModified":1667376147157,"dbVersion":1}]},{"id":"9ece1aee-81c3-4689-a621-9842a5a2bd8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","name":"Outlet-2","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610468648,"timeModified":1661610468648,"dbVersion":1,"drivers":[{"id":"7f4417dc-ecd8-4057-8f65-ebc5529f4c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV0","value":"0","uom":25,"timeAdded":1661610468967,"timeModified":1667398661546,"dbVersion":1},{"id":"1c99ee1d-b334-4138-88d4-53210ae0899e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV1","value":"0","uom":57,"timeAdded":1661610468980,"timeModified":1667376147342,"dbVersion":1},{"id":"dafe14ea-587a-4013-a1cd-cc39e7d11c6c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV2","value":"0","uom":57,"timeAdded":1661610468994,"timeModified":1667376147443,"dbVersion":1},{"id":"5614172a-68ee-480f-92cb-c647aeb561aa","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV4","value":"1","uom":25,"timeAdded":1661610469006,"timeModified":1667376147544,"dbVersion":1},{"id":"3d3ad022-377a-4c27-a26c-326b3c9c6391","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"ST","value":"1","uom":25,"timeAdded":1661610469020,"timeModified":1667376147644,"dbVersion":1}]},{"id":"6d2c24c0-54fe-406c-960c-9af185ac102e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","name":"Cistern pump temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9b8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044460744,"timeModified":1666044460744,"dbVersion":1,"drivers":[{"id":"e59a40db-d946-4802-bc27-8ec558c8ed37","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044461244,"timeModified":1667397701830,"dbVersion":1},{"id":"7c000b9e-9df0-4b03-864b-243ce746b4a9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044461204,"timeModified":1667397701531,"dbVersion":1},{"id":"c41c2574-02ac-4f4d-b2e4-08970162b709","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLITEMP","value":"43.3","uom":17,"timeAdded":1666044461161,"timeModified":1667397701209,"dbVersion":1},{"id":"e93b7605-c0bd-47df-bb2e-f8eeef41ef46","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044461175,"timeModified":1667397701321,"dbVersion":1},{"id":"baf6fc89-6e74-4322-b806-132344159166","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044461188,"timeModified":1667397701425,"dbVersion":1},{"id":"31d9fd7e-7609-46b7-9d58-ea94bc1522dd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044461217,"timeModified":1667397701631,"dbVersion":1},{"id":"fa5df1f6-f050-4cbf-a670-a62331810eac","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044461231,"timeModified":1667397701726,"dbVersion":1},{"id":"403d579f-158a-40a7-9126-e87cfe4e0d5f","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044461255,"timeModified":1667397701922,"dbVersion":1},{"id":"db83a019-fdf2-4c89-9d2e-b080a4e014f9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044461269,"timeModified":1667397702025,"dbVersion":1},{"id":"f04d3341-5cfb-4bc6-bea9-ccd78551dafc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"ST","value":"1","uom":25,"timeAdded":1666044461282,"timeModified":1667376145643,"dbVersion":1}]},{"id":"47cf499d-343c-46b9-bb6c-63f9c1e5567e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","name":"Workshop temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9d8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044484166,"timeModified":1666044484166,"dbVersion":1,"drivers":[{"id":"576ebccd-6325-408a-9cce-4e7dd035da8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044484504,"timeModified":1667397942078,"dbVersion":1},{"id":"92c738e7-1714-4b18-9e3a-473b90ef2e56","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044484464,"timeModified":1667397941770,"dbVersion":1},{"id":"69a2ff26-72fc-4579-9187-885c2cebede9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLITEMP","value":"63.9","uom":17,"timeAdded":1666044484425,"timeModified":1667397941480,"dbVersion":1},{"id":"def96c62-1535-40a1-b8dd-d8be5b661b63","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044484439,"timeModified":1667397941578,"dbVersion":1},{"id":"b1c1cb55-2699-47d3-a20f-b39477a684de","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044484452,"timeModified":1667397941678,"dbVersion":1},{"id":"f5603084-7dc8-466f-ab99-986b36fe4425","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044484478,"timeModified":1667397941866,"dbVersion":1},{"id":"689b0176-c49b-4a20-be56-361b1bc46e78","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044484491,"timeModified":1667397941981,"dbVersion":1},{"id":"bb49d897-1bcc-4ba5-beb0-1dfda07aebdf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044484517,"timeModified":1667397942166,"dbVersion":1},{"id":"81d8f982-2122-4ab8-97c4-d9df87f19f82","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044484532,"timeModified":1667397942271,"dbVersion":1},{"id":"811a70d1-5ca7-4fd9-bd6c-c043bb70e980","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"ST","value":"1","uom":25,"timeAdded":1666044484545,"timeModified":1667376149643,"dbVersion":1}]},{"id":"612dc403-b3a7-42d3-b8ae-5f8bf377d0e3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","name":"Fountain input temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004caa9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463004,"timeModified":1666044463004,"dbVersion":1,"drivers":[{"id":"fe90f228-c9e6-441e-a4e2-f0a749787fb4","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463453,"timeModified":1667397522702,"dbVersion":1},{"id":"7f6b61c4-f789-4c03-b39e-2196f9a9abd7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463416,"timeModified":1667397522388,"dbVersion":1},{"id":"1cbff7a0-7dbf-45e8-8d9f-80c01b79d183","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLITEMP","value":"49.1","uom":17,"timeAdded":1666044463374,"timeModified":1667397522090,"dbVersion":1},{"id":"b7967d77-2db7-4847-83a9-a1cd0165900b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463389,"timeModified":1667397522200,"dbVersion":1},{"id":"e2fc26b7-c1d5-4e99-8d65-735a0bc11fc6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463403,"timeModified":1667397522293,"dbVersion":1},{"id":"3bcd9776-c11e-4412-b5d0-c37bc3e578f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463429,"timeModified":1667397522486,"dbVersion":1},{"id":"485e1816-133e-41f8-904a-81150bf07c50","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463442,"timeModified":1667397522596,"dbVersion":1},{"id":"181aa642-3113-40ff-8ec1-324347a72d02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463467,"timeModified":1667397522789,"dbVersion":1},{"id":"c285e167-0c43-420e-9944-81a5f4b23a3e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463479,"timeModified":1667397522891,"dbVersion":1},{"id":"92cf14d1-7bf6-4f08-8745-e5ecbe531802","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"ST","value":"1","uom":25,"timeAdded":1666044463492,"timeModified":1667376146643,"dbVersion":1}]},{"id":"3de77d62-9fdd-436e-b99c-cdd090dc0de3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","name":"Fountain output temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004cce6","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463309,"timeModified":1666044463309,"dbVersion":1,"drivers":[{"id":"b32e2aa0-82c2-44d9-84d8-fa23eafe7da5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463845,"timeModified":1667397524435,"dbVersion":1},{"id":"b8ace59c-8862-4cea-b086-49e4e8f30546","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463802,"timeModified":1667397524136,"dbVersion":1},{"id":"541b7da6-b8be-480e-ae79-ce537a4b3e93","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLITEMP","value":"49.8","uom":17,"timeAdded":1666044463762,"timeModified":1667397523845,"dbVersion":1},{"id":"541c287a-867d-4f76-989f-9e25426e5908","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463775,"timeModified":1667397523941,"dbVersion":1},{"id":"076a03f8-5612-4f1e-9f8e-7262427e3be7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463787,"timeModified":1667397524036,"dbVersion":1},{"id":"6196b0f6-a3e6-44a8-9ca8-245b8785794b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463816,"timeModified":1667397524247,"dbVersion":1},{"id":"d178aacd-0259-491e-a1d6-0b3ed355d4f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463831,"timeModified":1667397524342,"dbVersion":1},{"id":"7339d955-73c4-452d-9b2c-f91f493cf418","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463858,"timeModified":1667397524539,"dbVersion":1},{"id":"9366bb13-5d8f-4805-a265-f85a80d0cb58","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463872,"timeModified":1667397524641,"dbVersion":1},{"id":"3ec971a6-b75c-4403-b1bd-bf85181ff873","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"ST","value":"1","uom":25,"timeAdded":1666044463885,"timeModified":1667376148643,"dbVersion":1}]},{"id":"84765453-a4e9-4b55-a97d-7d2c0419f632","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","name":"Motion Sensor 2","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038bb9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219978109,"timeModified":1659219978109,"dbVersion":1,"drivers":[{"id":"83be7f03-907e-4c2f-818e-aeb790fa5579","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV0","value":"0","uom":25,"timeAdded":1659219978360,"timeModified":1667399381497,"dbVersion":1},{"id":"cdc38e06-a589-457c-8e42-016558b6d552","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV1","value":"4","uom":25,"timeAdded":1659219978373,"timeModified":1667399381657,"dbVersion":1},{"id":"04e9bf2c-d1ff-44d2-a7e4-e1eea73ddedb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV8","value":"1","uom":25,"timeAdded":1659219978386,"timeModified":1667399381768,"dbVersion":1},{"id":"89c54f89-b850-48b3-a539-8083310e9481","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"ST","value":"1","uom":25,"timeAdded":1659219978400,"timeModified":1667376143653,"dbVersion":1}]},{"id":"39a2d5cf-47b7-4ad3-b9b3-eb9c54fa0973","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","name":"Motion Sensor 3","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c01","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219979221,"timeModified":1659219979221,"dbVersion":1,"drivers":[{"id":"a3186ee5-5720-4bb9-88a2-6c1b39c60d70","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV0","value":"0","uom":25,"timeAdded":1659219979473,"timeModified":1667397538194,"dbVersion":1},{"id":"d4aa3ce2-0044-4f51-8b0d-6dcd775e814c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV1","value":"4","uom":25,"timeAdded":1659219979485,"timeModified":1667397538285,"dbVersion":1},{"id":"e500e1b4-fc43-4463-b8f2-33c9a5953edb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV8","value":"1","uom":25,"timeAdded":1659219979498,"timeModified":1667397538389,"dbVersion":1},{"id":"d2a83b20-053f-493d-b2c9-05a85b720809","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"ST","value":"1","uom":25,"timeAdded":1659219979509,"timeModified":1667376144040,"dbVersion":1}]},{"id":"b62973cf-64cb-4b2c-b4e3-38fc77ef3422","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","name":"Motion Sensor 1","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c02","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219977070,"timeModified":1659219977070,"dbVersion":1,"drivers":[{"id":"9bac53bf-3292-41c6-8fdf-cbf1c771eef6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV0","value":"0","uom":25,"timeAdded":1659219977320,"timeModified":1667397540208,"dbVersion":1},{"id":"fdb609fe-8fb8-4927-b4d0-d6a0006683dc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV1","value":"3","uom":25,"timeAdded":1659219977333,"timeModified":1667397540350,"dbVersion":1},{"id":"9b343a78-3275-4d4d-8744-b0079214ecce","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV8","value":"1","uom":25,"timeAdded":1659219977346,"timeModified":1667397540449,"dbVersion":1},{"id":"e8f5f98f-90e0-4bb1-a106-98ac861f85c3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"ST","value":"1","uom":25,"timeAdded":1659219977359,"timeModified":1667376143268,"dbVersion":1}]},{"id":"eeb02526-c938-4f36-a165-9375aa365c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","name":"Leak Sensor workshop","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c020006096f","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219973217,"timeModified":1659219973217,"dbVersion":1,"drivers":[{"id":"f6e1954a-b11e-44a6-8cbd-ff6b8b958b02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV0","value":"0","uom":25,"timeAdded":1659219973477,"timeModified":1667399296057,"dbVersion":1},{"id":"15d843b7-4c31-4191-b2f3-07787a378c19","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV1","value":"4","uom":25,"timeAdded":1659219973490,"timeModified":1667399296167,"dbVersion":1},{"id":"1cfe2ec4-98b8-4508-b2ce-2d5aedc91763","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV8","value":"1","uom":25,"timeAdded":1659219973503,"timeModified":1667399296254,"dbVersion":1},{"id":"c9ad6248-b2c6-4549-afbb-5fd5dafd0b44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"ST","value":"1","uom":25,"timeAdded":1659219973515,"timeModified":1667376142269,"dbVersion":1}]},{"id":"7f75a877-cbdf-4757-ac7f-51546d947f7b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","name":"Leak Sensor mechanical","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200062dc7","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219972135,"timeModified":1659219972135,"dbVersion":1,"drivers":[{"id":"4dab0393-4983-409c-9ea6-88cc7a71c67a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV0","value":"0","uom":25,"timeAdded":1659219972388,"timeModified":1667397581732,"dbVersion":1},{"id":"1a8e4797-6f40-4d5c-ad1d-3082bb283711","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV1","value":"4","uom":25,"timeAdded":1659219972402,"timeModified":1667397581857,"dbVersion":1},{"id":"f48ade65-06a3-4f51-9b2c-cd746d2cb927","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV8","value":"1","uom":25,"timeAdded":1659219972417,"timeModified":1667397581952,"dbVersion":1},{"id":"6aa5bea0-a8ea-442b-81a1-0aba21bd3845","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"ST","value":"1","uom":25,"timeAdded":1659219972430,"timeModified":1667376141908,"dbVersion":1}]},{"id":"09f24158-a0e8-4df1-8876-834ee222fbfc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","name":"Leak Sensor laundry","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200063e2d","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219971048,"timeModified":1659219971048,"dbVersion":1,"drivers":[{"id":"c0ac137c-91dd-4803-b7fb-fbefe08782a5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV0","value":"0","uom":25,"timeAdded":1659219971294,"timeModified":1667397527863,"dbVersion":1},{"id":"a0763505-4d58-4561-a881-161aa3926995","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV1","value":"4","uom":25,"timeAdded":1659219971307,"timeModified":1667397528042,"dbVersion":1},{"id":"44fab85e-1ba7-4937-83ad-825aea509aa1","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV8","value":"1","uom":25,"timeAdded":1659219971319,"timeModified":1667397528136,"dbVersion":1},{"id":"4f145713-2c94-4a40-8b6b-2b19ad489de7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"ST","value":"1","uom":25,"timeAdded":1659219971335,"timeModified":1667376141506,"dbVersion":1}]},{"id":"ff66ae77-aca3-49ea-b433-36ec9abe5cbd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","name":"YoLinkSetup","nodeDefId":"setup","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"setup","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219635531,"timeModified":1659219635531,"dbVersion":1,"drivers":[{"id":"a70e282a-e740-4523-855c-c41a01cbc884","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","driver":"ST","value":"1","uom":25,"timeAdded":1659219635789,"timeModified":1667376140104,"dbVersion":1}]}]}} 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved oauth 11/2/2022, 08:38:55 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1},{"id":"73af4323-2592-49b1-bef8-ee3b5a08e8bf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"oauth","value":"","dbVersion":1}]} 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:38:55 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:38:55 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1}]} 11/2/2022, 08:38:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:38:59 [pg3] info: [YoLink(1)]: Restarting Node server 11/2/2022, 08:38:59 [pg3] info: [YoLink(1)]: Stopping Node server 11/2/2022, 08:38:59 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1] {"stop":{}} 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 to broker pg3_broker 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:38:59 [pg3] info: MQTTS: Client Disconnected: 00:0d:b9:5e:e1:4c_1 11/2/2022, 08:38:59 [pg3] debug: Client 00:0d:b9:5e:e1:4c_1 unsubscribed from udi/pg3/ns/clients/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:38:59 [pg3] debug: UpdateConnected: current status = {"connected":0} 11/2/2022, 08:38:59 [pg3] debug: ****** No connection status node/driver defined. 11/2/2022, 08:38:59 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:02 [pg3] info: YoLink stopped 11/2/2022, 08:39:02 [pg3] info: Waiting for YoLink to go away 11/2/2022, 08:39:02 [pg3] debug: [YoLink(1)] :: Exit cause code: null - signal: SIGTERM 11/2/2022, 08:39:02 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:06 [pg3] info: startNs:: YoLink 11/2/2022, 08:39:06 [pg3] info: startNs:: YoLink is valid 11/2/2022, 08:39:06 [pg3] info: UPGRADE AVAILABLE from 0.5.21 to 0.6.1 11/2/2022, 08:39:06 [pg3] debug: Deploy YoLink in /var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:39:06 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 08:39:06 [pg3] error: YoLink automatic update failed 11/2/2022, 08:39:06 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"restartNs":{"success":false,"error":"automatic update failed"}} 11/2/2022, 08:39:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:19 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:39:19 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:39:19 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/node servers/admin to broker pg3_broker 11/2/2022, 08:39:30 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:39:30 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:39:30 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:39:42 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"notices":{},"nodes":[{"id":"813b4952-e08d-4fe0-83c7-88adde7d8266","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","name":"Margie Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f77c","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219974598,"timeModified":1659219974598,"dbVersion":1,"drivers":[{"id":"601a4002-db02-462b-b13f-1e07b548f93e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"GV8","value":"1","uom":25,"timeAdded":1659219974841,"timeModified":1667376142394,"dbVersion":1},{"id":"ae83f913-873b-42cc-9be0-c077c6dd3ac5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"ST","value":"1","uom":25,"timeAdded":1659219974854,"timeModified":1667376142460,"dbVersion":1}]},{"id":"c52edaf1-0cf2-46af-83ba-c905e55d8615","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","name":"Tom Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f924","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219980275,"timeModified":1659219980275,"dbVersion":1,"drivers":[{"id":"2d60d34a-cf4b-4907-8a4f-020537fb0405","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"GV8","value":"1","uom":25,"timeAdded":1659219980513,"timeModified":1667376144140,"dbVersion":1},{"id":"ead3fea4-2a4a-4d51-98e6-a57394657850","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"ST","value":"1","uom":25,"timeAdded":1659219980528,"timeModified":1667376144245,"dbVersion":1}]},{"id":"f059b078-e78e-475b-8efe-0562e4d7e86e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","name":"Tom Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fd0a","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219981905,"timeModified":1659219981905,"dbVersion":1,"drivers":[{"id":"1daac6db-30b4-4aca-b002-72fe09151c72","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV0","value":"0","uom":25,"timeAdded":1659219982156,"timeModified":1667399621568,"dbVersion":1},{"id":"fc13a4c5-dd1a-4305-bac2-4b0c55731a8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV1","value":"4","uom":25,"timeAdded":1659219982168,"timeModified":1667399621763,"dbVersion":1},{"id":"6ef1f2b5-acb5-4bcd-a417-10fd20d66350","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV8","value":"1","uom":25,"timeAdded":1659219982180,"timeModified":1667399621861,"dbVersion":1},{"id":"22fc6eaa-2155-4a52-b9de-01d037904601","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"ST","value":"1","uom":25,"timeAdded":1659219982193,"timeModified":1667376144642,"dbVersion":1}]},{"id":"c3ab3751-e116-4a92-8c10-bda2bcb7f7b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","name":"Margie Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fdb4","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219975781,"timeModified":1659219975781,"dbVersion":1,"drivers":[{"id":"fc8a3293-30cc-48db-ab5a-a0b6cd299b28","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV0","value":"0","uom":25,"timeAdded":1659219976036,"timeModified":1667397534012,"dbVersion":1},{"id":"83279de0-998a-449e-a145-e54c0348a5b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV1","value":"4","uom":25,"timeAdded":1659219976048,"timeModified":1667397534160,"dbVersion":1},{"id":"e0d5500f-b840-4627-829e-b1a9adc79ae0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV8","value":"1","uom":25,"timeAdded":1659219976062,"timeModified":1667397534240,"dbVersion":1},{"id":"fe877359-d308-41fc-adad-a23bf191370e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"ST","value":"1","uom":25,"timeAdded":1659219976074,"timeModified":1667376142901,"dbVersion":1}]},{"id":"1b197090-0486-43b6-9075-d5c957952cf0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","name":"Hot water circulate","nodeDefId":"yooutlet","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004424e","private":null,"isPrimary":1,"enabled":1,"timeAdded":1665181551200,"timeModified":1665181551200,"dbVersion":1,"drivers":[{"id":"951c1ea4-a045-4b8f-bfd1-6ab36922424a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV0","value":"1","uom":25,"timeAdded":1665181551466,"timeModified":1667399561462,"dbVersion":1},{"id":"79d2b2e8-bacb-4b5f-a58c-3463b4c5f6d6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV1","value":"0","uom":57,"timeAdded":1665181551481,"timeModified":1667376140591,"dbVersion":1},{"id":"688ad939-7601-46d2-a882-4333d828144b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV2","value":"0","uom":57,"timeAdded":1665181551496,"timeModified":1667376140677,"dbVersion":1},{"id":"cdddf672-7264-4068-9b5a-57039311a69a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV3","value":"0","uom":30,"timeAdded":1665181551509,"timeModified":1667399561684,"dbVersion":1},{"id":"f0ae2242-248e-453f-af1f-7cc15b0494ca","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV4","value":"0","uom":33,"timeAdded":1665181551522,"timeModified":1667399561797,"dbVersion":1},{"id":"eaede574-1d2b-4764-9135-780228d5dc44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV8","value":"1","uom":25,"timeAdded":1665181551534,"timeModified":1667399561586,"dbVersion":1},{"id":"5fc65bf9-cd13-4cda-9a27-9e33c9ad13d8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"ST","value":"1","uom":25,"timeAdded":1665181551545,"timeModified":1667376141268,"dbVersion":1}]},{"id":"50708041-836e-446e-b186-e77f09e32298","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","name":"Cantina heater","nodeDefId":"yomultiout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219969777,"timeModified":1659219969777,"dbVersion":1,"drivers":[{"id":"80039714-76ce-4f95-af07-259d9292385b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"GV8","value":"1","uom":25,"timeAdded":1659219970045,"timeModified":1667376140255,"dbVersion":1},{"id":"aff68dda-aaca-4ddf-99fd-6dd12f34d340","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"ST","value":"1","uom":25,"timeAdded":1659219970063,"timeModified":1667376140386,"dbVersion":1}]},{"id":"b32773ae-4261-4d5d-b907-a706f882dc47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","name":"Outlet-1","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610466136,"timeModified":1661610466136,"dbVersion":1,"drivers":[{"id":"ff95de04-309c-4b49-9333-324702a2959a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV0","value":"0","uom":25,"timeAdded":1661610466465,"timeModified":1667398661282,"dbVersion":1},{"id":"5271dbf3-38ef-4288-b019-358cd131d4e7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV1","value":"0","uom":57,"timeAdded":1661610466479,"timeModified":1667376146838,"dbVersion":1},{"id":"ce32098c-dbb3-4345-96d0-17fe146ec4d0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV2","value":"0","uom":57,"timeAdded":1661610466494,"timeModified":1667376146944,"dbVersion":1},{"id":"95bbc59b-4bd5-48a6-b6b1-480ef8539624","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV4","value":"0","uom":25,"timeAdded":1661610466507,"timeModified":1667376147041,"dbVersion":1},{"id":"a0dd50e0-d8ea-4573-84ca-a219e1f29d47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"ST","value":"1","uom":25,"timeAdded":1661610466522,"timeModified":1667376147157,"dbVersion":1}]},{"id":"9ece1aee-81c3-4689-a621-9842a5a2bd8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","name":"Outlet-2","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610468648,"timeModified":1661610468648,"dbVersion":1,"drivers":[{"id":"7f4417dc-ecd8-4057-8f65-ebc5529f4c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV0","value":"0","uom":25,"timeAdded":1661610468967,"timeModified":1667398661546,"dbVersion":1},{"id":"1c99ee1d-b334-4138-88d4-53210ae0899e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV1","value":"0","uom":57,"timeAdded":1661610468980,"timeModified":1667376147342,"dbVersion":1},{"id":"dafe14ea-587a-4013-a1cd-cc39e7d11c6c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV2","value":"0","uom":57,"timeAdded":1661610468994,"timeModified":1667376147443,"dbVersion":1},{"id":"5614172a-68ee-480f-92cb-c647aeb561aa","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV4","value":"1","uom":25,"timeAdded":1661610469006,"timeModified":1667376147544,"dbVersion":1},{"id":"3d3ad022-377a-4c27-a26c-326b3c9c6391","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"ST","value":"1","uom":25,"timeAdded":1661610469020,"timeModified":1667376147644,"dbVersion":1}]},{"id":"6d2c24c0-54fe-406c-960c-9af185ac102e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","name":"Cistern pump temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9b8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044460744,"timeModified":1666044460744,"dbVersion":1,"drivers":[{"id":"e59a40db-d946-4802-bc27-8ec558c8ed37","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044461244,"timeModified":1667397701830,"dbVersion":1},{"id":"7c000b9e-9df0-4b03-864b-243ce746b4a9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044461204,"timeModified":1667397701531,"dbVersion":1},{"id":"c41c2574-02ac-4f4d-b2e4-08970162b709","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLITEMP","value":"43.3","uom":17,"timeAdded":1666044461161,"timeModified":1667397701209,"dbVersion":1},{"id":"e93b7605-c0bd-47df-bb2e-f8eeef41ef46","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044461175,"timeModified":1667397701321,"dbVersion":1},{"id":"baf6fc89-6e74-4322-b806-132344159166","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044461188,"timeModified":1667397701425,"dbVersion":1},{"id":"31d9fd7e-7609-46b7-9d58-ea94bc1522dd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044461217,"timeModified":1667397701631,"dbVersion":1},{"id":"fa5df1f6-f050-4cbf-a670-a62331810eac","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044461231,"timeModified":1667397701726,"dbVersion":1},{"id":"403d579f-158a-40a7-9126-e87cfe4e0d5f","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044461255,"timeModified":1667397701922,"dbVersion":1},{"id":"db83a019-fdf2-4c89-9d2e-b080a4e014f9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044461269,"timeModified":1667397702025,"dbVersion":1},{"id":"f04d3341-5cfb-4bc6-bea9-ccd78551dafc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"ST","value":"1","uom":25,"timeAdded":1666044461282,"timeModified":1667376145643,"dbVersion":1}]},{"id":"47cf499d-343c-46b9-bb6c-63f9c1e5567e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","name":"Workshop temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9d8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044484166,"timeModified":1666044484166,"dbVersion":1,"drivers":[{"id":"576ebccd-6325-408a-9cce-4e7dd035da8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044484504,"timeModified":1667397942078,"dbVersion":1},{"id":"92c738e7-1714-4b18-9e3a-473b90ef2e56","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044484464,"timeModified":1667397941770,"dbVersion":1},{"id":"69a2ff26-72fc-4579-9187-885c2cebede9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLITEMP","value":"63.9","uom":17,"timeAdded":1666044484425,"timeModified":1667397941480,"dbVersion":1},{"id":"def96c62-1535-40a1-b8dd-d8be5b661b63","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044484439,"timeModified":1667397941578,"dbVersion":1},{"id":"b1c1cb55-2699-47d3-a20f-b39477a684de","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044484452,"timeModified":1667397941678,"dbVersion":1},{"id":"f5603084-7dc8-466f-ab99-986b36fe4425","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044484478,"timeModified":1667397941866,"dbVersion":1},{"id":"689b0176-c49b-4a20-be56-361b1bc46e78","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044484491,"timeModified":1667397941981,"dbVersion":1},{"id":"bb49d897-1bcc-4ba5-beb0-1dfda07aebdf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044484517,"timeModified":1667397942166,"dbVersion":1},{"id":"81d8f982-2122-4ab8-97c4-d9df87f19f82","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044484532,"timeModified":1667397942271,"dbVersion":1},{"id":"811a70d1-5ca7-4fd9-bd6c-c043bb70e980","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"ST","value":"1","uom":25,"timeAdded":1666044484545,"timeModified":1667376149643,"dbVersion":1}]},{"id":"612dc403-b3a7-42d3-b8ae-5f8bf377d0e3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","name":"Fountain input temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004caa9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463004,"timeModified":1666044463004,"dbVersion":1,"drivers":[{"id":"fe90f228-c9e6-441e-a4e2-f0a749787fb4","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463453,"timeModified":1667397522702,"dbVersion":1},{"id":"7f6b61c4-f789-4c03-b39e-2196f9a9abd7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463416,"timeModified":1667397522388,"dbVersion":1},{"id":"1cbff7a0-7dbf-45e8-8d9f-80c01b79d183","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLITEMP","value":"49.1","uom":17,"timeAdded":1666044463374,"timeModified":1667397522090,"dbVersion":1},{"id":"b7967d77-2db7-4847-83a9-a1cd0165900b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463389,"timeModified":1667397522200,"dbVersion":1},{"id":"e2fc26b7-c1d5-4e99-8d65-735a0bc11fc6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463403,"timeModified":1667397522293,"dbVersion":1},{"id":"3bcd9776-c11e-4412-b5d0-c37bc3e578f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463429,"timeModified":1667397522486,"dbVersion":1},{"id":"485e1816-133e-41f8-904a-81150bf07c50","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463442,"timeModified":1667397522596,"dbVersion":1},{"id":"181aa642-3113-40ff-8ec1-324347a72d02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463467,"timeModified":1667397522789,"dbVersion":1},{"id":"c285e167-0c43-420e-9944-81a5f4b23a3e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463479,"timeModified":1667397522891,"dbVersion":1},{"id":"92cf14d1-7bf6-4f08-8745-e5ecbe531802","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"ST","value":"1","uom":25,"timeAdded":1666044463492,"timeModified":1667376146643,"dbVersion":1}]},{"id":"3de77d62-9fdd-436e-b99c-cdd090dc0de3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","name":"Fountain output temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004cce6","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463309,"timeModified":1666044463309,"dbVersion":1,"drivers":[{"id":"b32e2aa0-82c2-44d9-84d8-fa23eafe7da5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463845,"timeModified":1667397524435,"dbVersion":1},{"id":"b8ace59c-8862-4cea-b086-49e4e8f30546","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463802,"timeModified":1667397524136,"dbVersion":1},{"id":"541b7da6-b8be-480e-ae79-ce537a4b3e93","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLITEMP","value":"49.8","uom":17,"timeAdded":1666044463762,"timeModified":1667397523845,"dbVersion":1},{"id":"541c287a-867d-4f76-989f-9e25426e5908","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463775,"timeModified":1667397523941,"dbVersion":1},{"id":"076a03f8-5612-4f1e-9f8e-7262427e3be7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463787,"timeModified":1667397524036,"dbVersion":1},{"id":"6196b0f6-a3e6-44a8-9ca8-245b8785794b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463816,"timeModified":1667397524247,"dbVersion":1},{"id":"d178aacd-0259-491e-a1d6-0b3ed355d4f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463831,"timeModified":1667397524342,"dbVersion":1},{"id":"7339d955-73c4-452d-9b2c-f91f493cf418","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463858,"timeModified":1667397524539,"dbVersion":1},{"id":"9366bb13-5d8f-4805-a265-f85a80d0cb58","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463872,"timeModified":1667397524641,"dbVersion":1},{"id":"3ec971a6-b75c-4403-b1bd-bf85181ff873","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"ST","value":"1","uom":25,"timeAdded":1666044463885,"timeModified":1667376148643,"dbVersion":1}]},{"id":"84765453-a4e9-4b55-a97d-7d2c0419f632","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","name":"Motion Sensor 2","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038bb9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219978109,"timeModified":1659219978109,"dbVersion":1,"drivers":[{"id":"83be7f03-907e-4c2f-818e-aeb790fa5579","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV0","value":"0","uom":25,"timeAdded":1659219978360,"timeModified":1667399381497,"dbVersion":1},{"id":"cdc38e06-a589-457c-8e42-016558b6d552","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV1","value":"4","uom":25,"timeAdded":1659219978373,"timeModified":1667399381657,"dbVersion":1},{"id":"04e9bf2c-d1ff-44d2-a7e4-e1eea73ddedb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV8","value":"1","uom":25,"timeAdded":1659219978386,"timeModified":1667399381768,"dbVersion":1},{"id":"89c54f89-b850-48b3-a539-8083310e9481","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"ST","value":"1","uom":25,"timeAdded":1659219978400,"timeModified":1667376143653,"dbVersion":1}]},{"id":"39a2d5cf-47b7-4ad3-b9b3-eb9c54fa0973","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","name":"Motion Sensor 3","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c01","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219979221,"timeModified":1659219979221,"dbVersion":1,"drivers":[{"id":"a3186ee5-5720-4bb9-88a2-6c1b39c60d70","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV0","value":"0","uom":25,"timeAdded":1659219979473,"timeModified":1667397538194,"dbVersion":1},{"id":"d4aa3ce2-0044-4f51-8b0d-6dcd775e814c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV1","value":"4","uom":25,"timeAdded":1659219979485,"timeModified":1667397538285,"dbVersion":1},{"id":"e500e1b4-fc43-4463-b8f2-33c9a5953edb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV8","value":"1","uom":25,"timeAdded":1659219979498,"timeModified":1667397538389,"dbVersion":1},{"id":"d2a83b20-053f-493d-b2c9-05a85b720809","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"ST","value":"1","uom":25,"timeAdded":1659219979509,"timeModified":1667376144040,"dbVersion":1}]},{"id":"b62973cf-64cb-4b2c-b4e3-38fc77ef3422","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","name":"Motion Sensor 1","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c02","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219977070,"timeModified":1659219977070,"dbVersion":1,"drivers":[{"id":"9bac53bf-3292-41c6-8fdf-cbf1c771eef6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV0","value":"0","uom":25,"timeAdded":1659219977320,"timeModified":1667397540208,"dbVersion":1},{"id":"fdb609fe-8fb8-4927-b4d0-d6a0006683dc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV1","value":"3","uom":25,"timeAdded":1659219977333,"timeModified":1667397540350,"dbVersion":1},{"id":"9b343a78-3275-4d4d-8744-b0079214ecce","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV8","value":"1","uom":25,"timeAdded":1659219977346,"timeModified":1667397540449,"dbVersion":1},{"id":"e8f5f98f-90e0-4bb1-a106-98ac861f85c3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"ST","value":"1","uom":25,"timeAdded":1659219977359,"timeModified":1667376143268,"dbVersion":1}]},{"id":"eeb02526-c938-4f36-a165-9375aa365c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","name":"Leak Sensor workshop","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c020006096f","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219973217,"timeModified":1659219973217,"dbVersion":1,"drivers":[{"id":"f6e1954a-b11e-44a6-8cbd-ff6b8b958b02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV0","value":"0","uom":25,"timeAdded":1659219973477,"timeModified":1667399296057,"dbVersion":1},{"id":"15d843b7-4c31-4191-b2f3-07787a378c19","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV1","value":"4","uom":25,"timeAdded":1659219973490,"timeModified":1667399296167,"dbVersion":1},{"id":"1cfe2ec4-98b8-4508-b2ce-2d5aedc91763","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV8","value":"1","uom":25,"timeAdded":1659219973503,"timeModified":1667399296254,"dbVersion":1},{"id":"c9ad6248-b2c6-4549-afbb-5fd5dafd0b44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"ST","value":"1","uom":25,"timeAdded":1659219973515,"timeModified":1667376142269,"dbVersion":1}]},{"id":"7f75a877-cbdf-4757-ac7f-51546d947f7b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","name":"Leak Sensor mechanical","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200062dc7","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219972135,"timeModified":1659219972135,"dbVersion":1,"drivers":[{"id":"4dab0393-4983-409c-9ea6-88cc7a71c67a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV0","value":"0","uom":25,"timeAdded":1659219972388,"timeModified":1667397581732,"dbVersion":1},{"id":"1a8e4797-6f40-4d5c-ad1d-3082bb283711","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV1","value":"4","uom":25,"timeAdded":1659219972402,"timeModified":1667397581857,"dbVersion":1},{"id":"f48ade65-06a3-4f51-9b2c-cd746d2cb927","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV8","value":"1","uom":25,"timeAdded":1659219972417,"timeModified":1667397581952,"dbVersion":1},{"id":"6aa5bea0-a8ea-442b-81a1-0aba21bd3845","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"ST","value":"1","uom":25,"timeAdded":1659219972430,"timeModified":1667376141908,"dbVersion":1}]},{"id":"09f24158-a0e8-4df1-8876-834ee222fbfc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","name":"Leak Sensor laundry","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200063e2d","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219971048,"timeModified":1659219971048,"dbVersion":1,"drivers":[{"id":"c0ac137c-91dd-4803-b7fb-fbefe08782a5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV0","value":"0","uom":25,"timeAdded":1659219971294,"timeModified":1667397527863,"dbVersion":1},{"id":"a0763505-4d58-4561-a881-161aa3926995","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV1","value":"4","uom":25,"timeAdded":1659219971307,"timeModified":1667397528042,"dbVersion":1},{"id":"44fab85e-1ba7-4937-83ad-825aea509aa1","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV8","value":"1","uom":25,"timeAdded":1659219971319,"timeModified":1667397528136,"dbVersion":1},{"id":"4f145713-2c94-4a40-8b6b-2b19ad489de7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"ST","value":"1","uom":25,"timeAdded":1659219971335,"timeModified":1667376141506,"dbVersion":1}]},{"id":"ff66ae77-aca3-49ea-b433-36ec9abe5cbd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","name":"YoLinkSetup","nodeDefId":"setup","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"setup","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219635531,"timeModified":1659219635531,"dbVersion":1,"drivers":[{"id":"a70e282a-e740-4523-855c-c41a01cbc884","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","driver":"ST","value":"1","uom":25,"timeAdded":1659219635789,"timeModified":1667376140104,"dbVersion":1}]}]}} 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:39:42 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved oauth 11/2/2022, 08:39:42 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1},{"id":"73af4323-2592-49b1-bef8-ee3b5a08e8bf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"oauth","value":"","dbVersion":1}]} 11/2/2022, 08:39:42 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:39:55 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:39:55 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:39:55 [pg3] debug: Sending logfile to frontend :: /var/polyglot/pg3/logs/pg3-current.log 11/2/2022, 08:39:55 [pg3] debug: Client pg3frontend_vBMOo subscribed to udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/main 11/2/2022, 08:39:55 [pg3] debug: Starting log stream for pg3frontend_vBMOo :: /var/polyglot/pg3/logs/pg3-current.log 11/2/2022, 08:40:37 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/main 11/2/2022, 08:40:37 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:40:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:40:37 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:40:37 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:40:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:40:39 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667399946507,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"notices":{},"nodes":[{"id":"813b4952-e08d-4fe0-83c7-88adde7d8266","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","name":"Margie Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f77c","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219974598,"timeModified":1659219974598,"dbVersion":1,"drivers":[{"id":"601a4002-db02-462b-b13f-1e07b548f93e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"GV8","value":"1","uom":25,"timeAdded":1659219974841,"timeModified":1667376142394,"dbVersion":1},{"id":"ae83f913-873b-42cc-9be0-c077c6dd3ac5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f77c","driver":"ST","value":"1","uom":25,"timeAdded":1659219974854,"timeModified":1667376142460,"dbVersion":1}]},{"id":"c52edaf1-0cf2-46af-83ba-c905e55d8615","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","name":"Tom Garage Door","nodeDefId":"yogarage","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003f924","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219980275,"timeModified":1659219980275,"dbVersion":1,"drivers":[{"id":"2d60d34a-cf4b-4907-8a4f-020537fb0405","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"GV8","value":"1","uom":25,"timeAdded":1659219980513,"timeModified":1667376144140,"dbVersion":1},{"id":"ead3fea4-2a4a-4d51-98e6-a57394657850","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003f924","driver":"ST","value":"1","uom":25,"timeAdded":1659219980528,"timeModified":1667376144245,"dbVersion":1}]},{"id":"f059b078-e78e-475b-8efe-0562e4d7e86e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","name":"Tom Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fd0a","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219981905,"timeModified":1659219981905,"dbVersion":1,"drivers":[{"id":"1daac6db-30b4-4aca-b002-72fe09151c72","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV0","value":"0","uom":25,"timeAdded":1659219982156,"timeModified":1667399621568,"dbVersion":1},{"id":"fc13a4c5-dd1a-4305-bac2-4b0c55731a8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV1","value":"4","uom":25,"timeAdded":1659219982168,"timeModified":1667399621763,"dbVersion":1},{"id":"6ef1f2b5-acb5-4bcd-a417-10fd20d66350","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"GV8","value":"1","uom":25,"timeAdded":1659219982180,"timeModified":1667399621861,"dbVersion":1},{"id":"22fc6eaa-2155-4a52-b9de-01d037904601","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fd0a","driver":"ST","value":"1","uom":25,"timeAdded":1659219982193,"timeModified":1667376144642,"dbVersion":1}]},{"id":"c3ab3751-e116-4a92-8c10-bda2bcb7f7b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","name":"Margie Garage Door Sensor","nodeDefId":"yodoorsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010003fdb4","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219975781,"timeModified":1659219975781,"dbVersion":1,"drivers":[{"id":"fc8a3293-30cc-48db-ab5a-a0b6cd299b28","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV0","value":"0","uom":25,"timeAdded":1659219976036,"timeModified":1667397534012,"dbVersion":1},{"id":"83279de0-998a-449e-a145-e54c0348a5b5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV1","value":"4","uom":25,"timeAdded":1659219976048,"timeModified":1667397534160,"dbVersion":1},{"id":"e0d5500f-b840-4627-829e-b1a9adc79ae0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"GV8","value":"1","uom":25,"timeAdded":1659219976062,"timeModified":1667397534240,"dbVersion":1},{"id":"fe877359-d308-41fc-adad-a23bf191370e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010003fdb4","driver":"ST","value":"1","uom":25,"timeAdded":1659219976074,"timeModified":1667376142901,"dbVersion":1}]},{"id":"1b197090-0486-43b6-9075-d5c957952cf0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","name":"Hot water circulate","nodeDefId":"yooutlet","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004424e","private":null,"isPrimary":1,"enabled":1,"timeAdded":1665181551200,"timeModified":1665181551200,"dbVersion":1,"drivers":[{"id":"951c1ea4-a045-4b8f-bfd1-6ab36922424a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV0","value":"1","uom":25,"timeAdded":1665181551466,"timeModified":1667399561462,"dbVersion":1},{"id":"79d2b2e8-bacb-4b5f-a58c-3463b4c5f6d6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV1","value":"0","uom":57,"timeAdded":1665181551481,"timeModified":1667376140591,"dbVersion":1},{"id":"688ad939-7601-46d2-a882-4333d828144b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV2","value":"0","uom":57,"timeAdded":1665181551496,"timeModified":1667376140677,"dbVersion":1},{"id":"cdddf672-7264-4068-9b5a-57039311a69a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV3","value":"0","uom":30,"timeAdded":1665181551509,"timeModified":1667399561684,"dbVersion":1},{"id":"f0ae2242-248e-453f-af1f-7cc15b0494ca","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV4","value":"0","uom":33,"timeAdded":1665181551522,"timeModified":1667399561797,"dbVersion":1},{"id":"eaede574-1d2b-4764-9135-780228d5dc44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"GV8","value":"1","uom":25,"timeAdded":1665181551534,"timeModified":1667399561586,"dbVersion":1},{"id":"5fc65bf9-cd13-4cda-9a27-9e33c9ad13d8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004424e","driver":"ST","value":"1","uom":25,"timeAdded":1665181551545,"timeModified":1667376141268,"dbVersion":1}]},{"id":"50708041-836e-446e-b186-e77f09e32298","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","name":"Cantina heater","nodeDefId":"yomultiout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219969777,"timeModified":1659219969777,"dbVersion":1,"drivers":[{"id":"80039714-76ce-4f95-af07-259d9292385b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"GV8","value":"1","uom":25,"timeAdded":1659219970045,"timeModified":1667376140255,"dbVersion":1},{"id":"aff68dda-aaca-4ddf-99fd-6dd12f34d340","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046020","driver":"ST","value":"1","uom":25,"timeAdded":1659219970063,"timeModified":1667376140386,"dbVersion":1}]},{"id":"b32773ae-4261-4d5d-b907-a706f882dc47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","name":"Outlet-1","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610466136,"timeModified":1661610466136,"dbVersion":1,"drivers":[{"id":"ff95de04-309c-4b49-9333-324702a2959a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV0","value":"0","uom":25,"timeAdded":1661610466465,"timeModified":1667398661282,"dbVersion":1},{"id":"5271dbf3-38ef-4288-b019-358cd131d4e7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV1","value":"0","uom":57,"timeAdded":1661610466479,"timeModified":1667376146838,"dbVersion":1},{"id":"ce32098c-dbb3-4345-96d0-17fe146ec4d0","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV2","value":"0","uom":57,"timeAdded":1661610466494,"timeModified":1667376146944,"dbVersion":1},{"id":"95bbc59b-4bd5-48a6-b6b1-480ef8539624","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"GV4","value":"0","uom":25,"timeAdded":1661610466507,"timeModified":1667376147041,"dbVersion":1},{"id":"a0dd50e0-d8ea-4573-84ca-a219e1f29d47","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o0","driver":"ST","value":"1","uom":25,"timeAdded":1661610466522,"timeModified":1667376147157,"dbVersion":1}]},{"id":"9ece1aee-81c3-4689-a621-9842a5a2bd8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","name":"Outlet-2","nodeDefId":"yosubout","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0100046020","private":null,"isPrimary":0,"enabled":1,"timeAdded":1661610468648,"timeModified":1661610468648,"dbVersion":1,"drivers":[{"id":"7f4417dc-ecd8-4057-8f65-ebc5529f4c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV0","value":"0","uom":25,"timeAdded":1661610468967,"timeModified":1667398661546,"dbVersion":1},{"id":"1c99ee1d-b334-4138-88d4-53210ae0899e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV1","value":"0","uom":57,"timeAdded":1661610468980,"timeModified":1667376147342,"dbVersion":1},{"id":"dafe14ea-587a-4013-a1cd-cc39e7d11c6c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV2","value":"0","uom":57,"timeAdded":1661610468994,"timeModified":1667376147443,"dbVersion":1},{"id":"5614172a-68ee-480f-92cb-c647aeb561aa","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"GV4","value":"1","uom":25,"timeAdded":1661610469006,"timeModified":1667376147544,"dbVersion":1},{"id":"3d3ad022-377a-4c27-a26c-326b3c9c6391","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0100046_o1","driver":"ST","value":"1","uom":25,"timeAdded":1661610469020,"timeModified":1667376147644,"dbVersion":1}]},{"id":"6d2c24c0-54fe-406c-960c-9af185ac102e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","name":"Cistern pump temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9b8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044460744,"timeModified":1666044460744,"dbVersion":1,"drivers":[{"id":"e59a40db-d946-4802-bc27-8ec558c8ed37","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044461244,"timeModified":1667397701830,"dbVersion":1},{"id":"7c000b9e-9df0-4b03-864b-243ce746b4a9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044461204,"timeModified":1667397701531,"dbVersion":1},{"id":"c41c2574-02ac-4f4d-b2e4-08970162b709","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"CLITEMP","value":"43.3","uom":17,"timeAdded":1666044461161,"timeModified":1667397701209,"dbVersion":1},{"id":"e93b7605-c0bd-47df-bb2e-f8eeef41ef46","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044461175,"timeModified":1667397701321,"dbVersion":1},{"id":"baf6fc89-6e74-4322-b806-132344159166","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044461188,"timeModified":1667397701425,"dbVersion":1},{"id":"31d9fd7e-7609-46b7-9d58-ea94bc1522dd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044461217,"timeModified":1667397701631,"dbVersion":1},{"id":"fa5df1f6-f050-4cbf-a670-a62331810eac","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044461231,"timeModified":1667397701726,"dbVersion":1},{"id":"403d579f-158a-40a7-9126-e87cfe4e0d5f","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044461255,"timeModified":1667397701922,"dbVersion":1},{"id":"db83a019-fdf2-4c89-9d2e-b080a4e014f9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044461269,"timeModified":1667397702025,"dbVersion":1},{"id":"f04d3341-5cfb-4bc6-bea9-ccd78551dafc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9b8","driver":"ST","value":"1","uom":25,"timeAdded":1666044461282,"timeModified":1667376145643,"dbVersion":1}]},{"id":"47cf499d-343c-46b9-bb6c-63f9c1e5567e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","name":"Workshop temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004c9d8","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044484166,"timeModified":1666044484166,"dbVersion":1,"drivers":[{"id":"576ebccd-6325-408a-9cce-4e7dd035da8d","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044484504,"timeModified":1667397942078,"dbVersion":1},{"id":"92c738e7-1714-4b18-9e3a-473b90ef2e56","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044484464,"timeModified":1667397941770,"dbVersion":1},{"id":"69a2ff26-72fc-4579-9187-885c2cebede9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"CLITEMP","value":"63.9","uom":17,"timeAdded":1666044484425,"timeModified":1667397941480,"dbVersion":1},{"id":"def96c62-1535-40a1-b8dd-d8be5b661b63","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV1","value":"0","uom":25,"timeAdded":1666044484439,"timeModified":1667397941578,"dbVersion":1},{"id":"b1c1cb55-2699-47d3-a20f-b39477a684de","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV2","value":"0","uom":25,"timeAdded":1666044484452,"timeModified":1667397941678,"dbVersion":1},{"id":"f5603084-7dc8-466f-ab99-986b36fe4425","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV4","value":"0","uom":25,"timeAdded":1666044484478,"timeModified":1667397941866,"dbVersion":1},{"id":"689b0176-c49b-4a20-be56-361b1bc46e78","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV5","value":"0","uom":25,"timeAdded":1666044484491,"timeModified":1667397941981,"dbVersion":1},{"id":"bb49d897-1bcc-4ba5-beb0-1dfda07aebdf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV7","value":"0","uom":25,"timeAdded":1666044484517,"timeModified":1667397942166,"dbVersion":1},{"id":"81d8f982-2122-4ab8-97c4-d9df87f19f82","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"GV8","value":"1","uom":25,"timeAdded":1666044484532,"timeModified":1667397942271,"dbVersion":1},{"id":"811a70d1-5ca7-4fd9-bd6c-c043bb70e980","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004c9d8","driver":"ST","value":"1","uom":25,"timeAdded":1666044484545,"timeModified":1667376149643,"dbVersion":1}]},{"id":"612dc403-b3a7-42d3-b8ae-5f8bf377d0e3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","name":"Fountain input temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004caa9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463004,"timeModified":1666044463004,"dbVersion":1,"drivers":[{"id":"fe90f228-c9e6-441e-a4e2-f0a749787fb4","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463453,"timeModified":1667397522702,"dbVersion":1},{"id":"7f6b61c4-f789-4c03-b39e-2196f9a9abd7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463416,"timeModified":1667397522388,"dbVersion":1},{"id":"1cbff7a0-7dbf-45e8-8d9f-80c01b79d183","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"CLITEMP","value":"49.1","uom":17,"timeAdded":1666044463374,"timeModified":1667397522090,"dbVersion":1},{"id":"b7967d77-2db7-4847-83a9-a1cd0165900b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463389,"timeModified":1667397522200,"dbVersion":1},{"id":"e2fc26b7-c1d5-4e99-8d65-735a0bc11fc6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463403,"timeModified":1667397522293,"dbVersion":1},{"id":"3bcd9776-c11e-4412-b5d0-c37bc3e578f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463429,"timeModified":1667397522486,"dbVersion":1},{"id":"485e1816-133e-41f8-904a-81150bf07c50","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463442,"timeModified":1667397522596,"dbVersion":1},{"id":"181aa642-3113-40ff-8ec1-324347a72d02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463467,"timeModified":1667397522789,"dbVersion":1},{"id":"c285e167-0c43-420e-9944-81a5f4b23a3e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463479,"timeModified":1667397522891,"dbVersion":1},{"id":"92cf14d1-7bf6-4f08-8745-e5ecbe531802","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004caa9","driver":"ST","value":"1","uom":25,"timeAdded":1666044463492,"timeModified":1667376146643,"dbVersion":1}]},{"id":"3de77d62-9fdd-436e-b99c-cdd090dc0de3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","name":"Fountain output temp","nodeDefId":"yothsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c010004cce6","private":null,"isPrimary":1,"enabled":1,"timeAdded":1666044463309,"timeModified":1666044463309,"dbVersion":1,"drivers":[{"id":"b32e2aa0-82c2-44d9-84d8-fa23eafe7da5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"BATLVL","value":"4","uom":25,"timeAdded":1666044463845,"timeModified":1667397524435,"dbVersion":1},{"id":"b8ace59c-8862-4cea-b086-49e4e8f30546","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLIHUM","value":"0","uom":51,"timeAdded":1666044463802,"timeModified":1667397524136,"dbVersion":1},{"id":"541b7da6-b8be-480e-ae79-ce537a4b3e93","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"CLITEMP","value":"49.8","uom":17,"timeAdded":1666044463762,"timeModified":1667397523845,"dbVersion":1},{"id":"541c287a-867d-4f76-989f-9e25426e5908","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV1","value":"0","uom":25,"timeAdded":1666044463775,"timeModified":1667397523941,"dbVersion":1},{"id":"076a03f8-5612-4f1e-9f8e-7262427e3be7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV2","value":"0","uom":25,"timeAdded":1666044463787,"timeModified":1667397524036,"dbVersion":1},{"id":"6196b0f6-a3e6-44a8-9ca8-245b8785794b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV4","value":"0","uom":25,"timeAdded":1666044463816,"timeModified":1667397524247,"dbVersion":1},{"id":"d178aacd-0259-491e-a1d6-0b3ed355d4f8","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV5","value":"0","uom":25,"timeAdded":1666044463831,"timeModified":1667397524342,"dbVersion":1},{"id":"7339d955-73c4-452d-9b2c-f91f493cf418","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV7","value":"0","uom":25,"timeAdded":1666044463858,"timeModified":1667397524539,"dbVersion":1},{"id":"9366bb13-5d8f-4805-a265-f85a80d0cb58","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"GV8","value":"1","uom":25,"timeAdded":1666044463872,"timeModified":1667397524641,"dbVersion":1},{"id":"3ec971a6-b75c-4403-b1bd-bf85181ff873","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c010004cce6","driver":"ST","value":"1","uom":25,"timeAdded":1666044463885,"timeModified":1667376148643,"dbVersion":1}]},{"id":"84765453-a4e9-4b55-a97d-7d2c0419f632","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","name":"Motion Sensor 2","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038bb9","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219978109,"timeModified":1659219978109,"dbVersion":1,"drivers":[{"id":"83be7f03-907e-4c2f-818e-aeb790fa5579","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV0","value":"0","uom":25,"timeAdded":1659219978360,"timeModified":1667399381497,"dbVersion":1},{"id":"cdc38e06-a589-457c-8e42-016558b6d552","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV1","value":"4","uom":25,"timeAdded":1659219978373,"timeModified":1667399381657,"dbVersion":1},{"id":"04e9bf2c-d1ff-44d2-a7e4-e1eea73ddedb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"GV8","value":"1","uom":25,"timeAdded":1659219978386,"timeModified":1667399381768,"dbVersion":1},{"id":"89c54f89-b850-48b3-a539-8083310e9481","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038bb9","driver":"ST","value":"1","uom":25,"timeAdded":1659219978400,"timeModified":1667376143653,"dbVersion":1}]},{"id":"39a2d5cf-47b7-4ad3-b9b3-eb9c54fa0973","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","name":"Motion Sensor 3","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c01","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219979221,"timeModified":1659219979221,"dbVersion":1,"drivers":[{"id":"a3186ee5-5720-4bb9-88a2-6c1b39c60d70","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV0","value":"0","uom":25,"timeAdded":1659219979473,"timeModified":1667397538194,"dbVersion":1},{"id":"d4aa3ce2-0044-4f51-8b0d-6dcd775e814c","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV1","value":"4","uom":25,"timeAdded":1659219979485,"timeModified":1667397538285,"dbVersion":1},{"id":"e500e1b4-fc43-4463-b8f2-33c9a5953edb","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"GV8","value":"1","uom":25,"timeAdded":1659219979498,"timeModified":1667397538389,"dbVersion":1},{"id":"d2a83b20-053f-493d-b2c9-05a85b720809","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c01","driver":"ST","value":"1","uom":25,"timeAdded":1659219979509,"timeModified":1667376144040,"dbVersion":1}]},{"id":"b62973cf-64cb-4b2c-b4e3-38fc77ef3422","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","name":"Motion Sensor 1","nodeDefId":"yomotionsens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200038c02","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219977070,"timeModified":1659219977070,"dbVersion":1,"drivers":[{"id":"9bac53bf-3292-41c6-8fdf-cbf1c771eef6","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV0","value":"0","uom":25,"timeAdded":1659219977320,"timeModified":1667397540208,"dbVersion":1},{"id":"fdb609fe-8fb8-4927-b4d0-d6a0006683dc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV1","value":"3","uom":25,"timeAdded":1659219977333,"timeModified":1667397540350,"dbVersion":1},{"id":"9b343a78-3275-4d4d-8744-b0079214ecce","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"GV8","value":"1","uom":25,"timeAdded":1659219977346,"timeModified":1667397540449,"dbVersion":1},{"id":"e8f5f98f-90e0-4bb1-a106-98ac861f85c3","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200038c02","driver":"ST","value":"1","uom":25,"timeAdded":1659219977359,"timeModified":1667376143268,"dbVersion":1}]},{"id":"eeb02526-c938-4f36-a165-9375aa365c1e","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","name":"Leak Sensor workshop","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c020006096f","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219973217,"timeModified":1659219973217,"dbVersion":1,"drivers":[{"id":"f6e1954a-b11e-44a6-8cbd-ff6b8b958b02","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV0","value":"0","uom":25,"timeAdded":1659219973477,"timeModified":1667399296057,"dbVersion":1},{"id":"15d843b7-4c31-4191-b2f3-07787a378c19","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV1","value":"4","uom":25,"timeAdded":1659219973490,"timeModified":1667399296167,"dbVersion":1},{"id":"1cfe2ec4-98b8-4508-b2ce-2d5aedc91763","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"GV8","value":"1","uom":25,"timeAdded":1659219973503,"timeModified":1667399296254,"dbVersion":1},{"id":"c9ad6248-b2c6-4549-afbb-5fd5dafd0b44","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c020006096f","driver":"ST","value":"1","uom":25,"timeAdded":1659219973515,"timeModified":1667376142269,"dbVersion":1}]},{"id":"7f75a877-cbdf-4757-ac7f-51546d947f7b","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","name":"Leak Sensor mechanical","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200062dc7","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219972135,"timeModified":1659219972135,"dbVersion":1,"drivers":[{"id":"4dab0393-4983-409c-9ea6-88cc7a71c67a","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV0","value":"0","uom":25,"timeAdded":1659219972388,"timeModified":1667397581732,"dbVersion":1},{"id":"1a8e4797-6f40-4d5c-ad1d-3082bb283711","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV1","value":"4","uom":25,"timeAdded":1659219972402,"timeModified":1667397581857,"dbVersion":1},{"id":"f48ade65-06a3-4f51-9b2c-cd746d2cb927","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"GV8","value":"1","uom":25,"timeAdded":1659219972417,"timeModified":1667397581952,"dbVersion":1},{"id":"6aa5bea0-a8ea-442b-81a1-0aba21bd3845","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200062dc7","driver":"ST","value":"1","uom":25,"timeAdded":1659219972430,"timeModified":1667376141908,"dbVersion":1}]},{"id":"09f24158-a0e8-4df1-8876-834ee222fbfc","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","name":"Leak Sensor laundry","nodeDefId":"yoleaksens","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"8b4c0200063e2d","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219971048,"timeModified":1659219971048,"dbVersion":1,"drivers":[{"id":"c0ac137c-91dd-4803-b7fb-fbefe08782a5","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV0","value":"0","uom":25,"timeAdded":1659219971294,"timeModified":1667397527863,"dbVersion":1},{"id":"a0763505-4d58-4561-a881-161aa3926995","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV1","value":"4","uom":25,"timeAdded":1659219971307,"timeModified":1667397528042,"dbVersion":1},{"id":"44fab85e-1ba7-4937-83ad-825aea509aa1","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"GV8","value":"1","uom":25,"timeAdded":1659219971319,"timeModified":1667397528136,"dbVersion":1},{"id":"4f145713-2c94-4a40-8b6b-2b19ad489de7","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"8b4c0200063e2d","driver":"ST","value":"1","uom":25,"timeAdded":1659219971335,"timeModified":1667376141506,"dbVersion":1}]},{"id":"ff66ae77-aca3-49ea-b433-36ec9abe5cbd","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","name":"YoLinkSetup","nodeDefId":"setup","nls":null,"hint":"0x00000000","controller":0,"primaryNode":"setup","private":null,"isPrimary":1,"enabled":1,"timeAdded":1659219635531,"timeModified":1659219635531,"dbVersion":1,"drivers":[{"id":"a70e282a-e740-4523-855c-c41a01cbc884","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"address":"setup","driver":"ST","value":"1","uom":25,"timeAdded":1659219635789,"timeModified":1667376140104,"dbVersion":1}]}]}} 11/2/2022, 08:40:39 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customparams 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved customtypeddata 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved notices 11/2/2022, 08:40:40 [pg3] info: [00:0d:b9:5e:e1:4c_1] Retrieved oauth 11/2/2022, 08:40:40 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getCustom":[{"id":"4e010a30-490c-4045-9987-a23351c1ab77","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customparams","value":"{\"UAID\":\"ua_1A55222386A941E593A7719EF74CF489\",\"SECRET_KEY\":\"sec_v1_9jQCvYVoUFdcrQ5P73Nm8A==\",\"TEMP_UNIT\":\"F\",\"8b4c0100046020\":\"Cantina plug\",\"8b4c0200063e2d\":\"Leak Sensor laundry\",\"8b4c0200062dc7\":\"Leak Sensor mechanical\",\"8b4c020006096f\":\"Leak Sensor workshop\",\"8b4c010003f77c\":\"Margie Garage Door\",\"8b4c010003fdb4\":\"Margie Garage Door Sensor\",\"8b4c0200038c02\":\"MR Motion Sensor\",\"8b4c0200038bb9\":\"Motion Sensor 2\",\"8b4c0200038c01\":\"Motion Sensor 3\",\"8b4c010003f924\":\"Tom Garage Door\",\"8b4c010003fd0a\":\"Tom Garage Door Sensor\",\"8b4c010004424e\":\"Hot water circulate\",\"8b4c010004caa9\":\"Fountain input temp\",\"8b4c010004cce6\":\"Fountain output temp\",\"8b4c010004c9d8\":\"Workshop temp\",\"8b4c010004c9b8\":\"Cistern pump temp\"}","dbVersion":1},{"id":"223dc80c-3645-4d54-a027-230e424ca6d9","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"customtypeddata","value":"{}","dbVersion":1},{"id":"797785a1-2fb5-4ecd-b506-96b7bd176958","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"notices","value":"{}","dbVersion":1},{"id":"73af4323-2592-49b1-bef8-ee3b5a08e8bf","uuid":"00:0d:b9:5e:e1:4c","profileNum":1,"key":"oauth","value":"","dbVersion":1}]} 11/2/2022, 08:40:40 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:40:41 [pg3] info: startNs:: YoLink 11/2/2022, 08:40:41 [pg3] info: startNs:: YoLink is valid 11/2/2022, 08:40:41 [pg3] info: UPGRADE AVAILABLE from 0.5.21 to 0.6.1 11/2/2022, 08:40:41 [pg3] debug: Deploy YoLink in /var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:40:41 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 08:40:41 [pg3] error: YoLink automatic update failed 11/2/2022, 08:40:41 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"startNs":{"success":false,"error":"automatic update failed"}} 11/2/2022, 08:40:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:40:59 [pg3] debug: Client pg3frontend_vBMOo unsubscribed from udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380/log/00:0d:b9:5e:e1:4c_1 11/2/2022, 08:40:59 [pg3] debug: Stopping log stream for pg3frontend_vBMOo 11/2/2022, 08:41:00 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/node servers/admin to broker pg3_broker 11/2/2022, 08:41:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/isy/admin to broker pg3_broker 11/2/2022, 08:41:55 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667400041699,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"udi-YoLink.py","shortPoll":60,"longPoll":3600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":19,"notices":{}}]} 11/2/2022, 08:41:55 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/a1edab06-9f51-4621-86f9-b82390cf5380 to broker pg3_broker 11/2/2022, 08:41:58 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:41:58 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_vBMOo has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 11/2/2022, 08:41:58 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"getNs":{"id":"443d44a2-d6dd-40f1-8f14-4c0ca43c2b50","uuid":"00:0d:b9:5e:e1:4c","token":"Ztw!ymfxmp/Hw8rC","name":"YoLink","nsid":"78312440-23ea-4ed6-9361-9cdc2d5e7c6b","expires":0,"nickname":null,"profileNum":1,"timeAdded":1659219590197,"timeStarted":0,"timeModified":1667400041699,"version":"0.5.21","branch":"null","url":"null","home":"/var/polyglot/pg3/ns/00:0d:b9:5e:e1:4c_1","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"
Version 3.0.63 of PG3 will no longer receive updates to node servers automatically.  You need to update
How do I do that?
I stumbled around and got PG3 updated to 3.1.13 (far from intuitive how!). I still cannot install the NS into slot 1 because it doesn't list it as a choice. Automatic update fails like it did before. Latest PG3 log follows.
11/2/2022, 12:06:53 [pg3] info: startNs:: YoLink 11/2/2022, 12:06:53 [pg3] info: startNs:: YoLink is valid 11/2/2022, 12:06:53 [pg3] info: checkLicense:: YoLink Valid perpetual license found. 11/2/2022, 12:06:53 [pg3] info: UPGRADE AVAILABLE for YoLink from 0.5.21 to 0.6.1 11/2/2022, 12:06:53 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 12:06:53 [pg3] error: YoLink automatic update failed 11/2/2022, 12:07:13 [pg3] info: [YoLink(1)]: Restarting Node server 11/2/2022, 12:07:13 [pg3] warn: [YoLink(1)]: Was not running. Starting... 11/2/2022, 12:07:16 [pg3] info: startNs:: YoLink 11/2/2022, 12:07:16 [pg3] info: startNs:: YoLink is valid 11/2/2022, 12:07:17 [pg3] info: checkLicense:: YoLink Valid perpetual license found. 11/2/2022, 12:07:17 [pg3] info: UPGRADE AVAILABLE for YoLink from 0.5.21 to 0.6.1 11/2/2022, 12:07:17 [pg3] error: Node server update failed YoLink :: TypeError: Cannot read properties of null (reading 'endsWith') 11/2/2022, 12:07:17 [pg3] error: YoLink automatic update failed 11/2/2022, 12:07:47 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_abRDK 11/2/2022, 12:07:47 [pg3] error: MQTTS: clientError: pg3frontend_abRDK keep alive timeout 11/2/2022, 12:07:47 [pg3] info: MQTTS: Client Disconnected: pg3frontend_abRDK 11/2/2022, 12:07:47 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_vBMOo 11/2/2022, 12:07:47 [pg3] error: MQTTS: clientError: pg3frontend_vBMOo keep alive timeout 11/2/2022, 12:07:47 [pg3] info: MQTTS: Client Disconnected: pg3frontend_vBMOo 11/2/2022, 12:07:53 [pg3] info: MQTTS: Client Connected: pg3frontend_abRDK 11/2/2022, 12:07:53 [pg3] info: MQTTS: Client Connected: pg3frontend_vBMOo
did you reboot PG3 after the upgrade?
I am not 100% this will work, but if you do not start AC - could you erase the node in PG3 - that should free up the node slot) and you can reinstall in the slot - I have done it before with success - you may need to refresh the program and save afterwards - but no editing should be needed
The only way I could find to update PG3 was with the PG3-System-Restart PG3. (Like I said, how to update PG3 is far from intuitive.) I would assume that would reboot PG3. Before finding that I had tried IoP-Configuration-Upgrade Packages but that didn't seem to do anything.
I do not understand " if you do not start AC - could you erase the node in PG3" Does AC = Admin Console? I do not see any way to delete "the node" in PG3. I presume you do not mean YO node and must mean NS slot but again I do not see a way to do that.
To add to the confusion, I just encountered an issue I had seen earlier but had gone away. I went to PG3, Node Server Purchases. It shows the YO NS and it has a (Re)install button. When I click that I am told I do not have a valid license and it wants me to purchase it again.
The instructions for upgrading PG3 are posted with every release announcement:
If something isn't clear about that, please let me know what you think would make it better.
We're still trying to figure out why you're having issues upgrading YoLink.  The node server store has been evolving over time as developers have asked for additional options for node server purchases.  This has caused some confusion for both users and developers.
What appears to have happened is that the production version of YoLink was entered as a new node server instead of an update to the beta version.  What that means in this case, is that PG3 thinks you have YoLink(beta) installed in slot 1 so it can't install YoLink(production) there.  It also looks like you have a license for YoLinkI(beta) but not a license for YoLink(production).
I got things working! The reason you saw one thing and I saw another is the way we went about it. You seem to have gone to the production store and clicked on left YoLInk button. I am pretty sure that was not a live button for me. I somehow got into a state where IoP could not communicate with any Insteon devices. I updated Java, cleared the cache, power cycled the Polisy and PLM. IoP could then communicate with the devices, but the NS still didn't work. I went back to the production store and noticed the live YoLInk button, clicked and then saw what you saw. I was then able to install into slot 1 and everything worked. Whatever method I was using, I could no longer find it. It is impossible to tell which of the things I tried were the key. The purchases section still says I don't have a valid license.
Bob,
The following are two snips from the PG3 purchases screen. The first shows I have a license and the second is what I see when I click (Re)install.
image.thumb.png.9e90d7a295698471920463c854f20db7.pngimage.thumb.png.18063f60209d8110c5f2b527b3b4597e.png
I actually mean to remove the yolink node (delete it) and then reinstall it - If you replace 1 to 1 I think the programs will remain unaffected - I have tried with my own nodes but not purchased nodes
Maybe you can contact Michel and see if he can reimburce you if you purchase again - I am sure it should be ok.  Naturally, we should try to get to the bottom of what happened, but it will allow you to move forward
Re: "If something isn't clear about that, please let me know what you think would make it better."
The problem for me is that I only look at the forum when I am trying to solve a problem. In other words, I rarely look at the forum. As a result, I have no way of knowing there is an update or how to install it. Polisy (PG3 and IoP) is the only device or software I own that doesn't have an easy way of being notified of an available update, along with a script-like upgrade procedure. I regularly run Admin Console, so every time I log in, it would be nice to be notified of new system software, along with some sort of "Click here" button to automatically install the update. Taking it a further step, having a configurable option to automatically look for and apply updates would make it even better.
The closest analogy to Polisy is my router in that they do not require regular human interaction, so it is challenging to keep them up to date. With my router, I can manually tell it to look for updates, but it supports a scripting language so every day it automatically looks for updates and applies them if available. That is the type of thing that would really help Polisy, a simple way to manually look for and apply updates, and an automatic way to do it without human intervention.
Edited by tjkintz
I doubt many here would be a fan of automatic updates for the simple fact that a bug can potentially break their system. How many times have you seen phone and other computer updates cause issues for users?  (I tend to apply updates after I've tested them with my backup system).
Polisy does let you know you know if there's a firmware update available for it. PG3 is still in development so they probably do not want to make that as easy since things can go sideways during these early stages.
@tjkintz if you go here - https://forum.universal-devices.com/forum/339-current-release-announcements/
Click on "Follow" and then select "A notification and an email when new content is posted" you'll get an email (and forum notification alert) that something has been updated. This covers PG3, IoP, UD Mobile - any Universal Devices release that gets posted there.
Perhaps future Polyglot development can somehow push a notification within the system that an update is available, but right now the easiest way is to follow the forums and get the alerts.
Polisy is in active development so there are regular updates ongoing.
The current problem with automatic updates is that things might break if the unit updates without the user knowing it. It's completely different than thinking about a Router that might just update some internal security setting. This is a slightly higher complex system.
Thanks for this comment and for the screen shots above.
Polyglot (PG2) did have a mechanism to check if an update was available and the install it if it was.  Because of changes in in PG3, it wasn't possible to use that same mechanism.   I do think about this occasionally and agree that it would be nice for either PG3 or the AC (or both) to notify you when an update is available and provide the option to apply the update.
A lot of effort to date has been spent working on each component to try and make them usable and stable but the integration of the components into a consistent whole is still lacking.  Some of this is happening for the eisy release with the goal to make the overall experience much better.
What helps us a lot is to get clear and detailed feedback (like what you provided above) so thanks again.
  • Thanks 1
3 hours ago, tjkintz said:
Bob,
The (re)install button on that screen is a brand new feature I just added so it may not be behaving as it should. What I think has happened is that you purchased the beta version and have a license for the beta version.  But the production version of the node server was not added as an update to the beta version so it can't use the beta license.
PG3 isn't handling this case very well and in some cases it seems to think it can use the license for the production version and in other cases it thinks it can't.  Thus, confusing us all.   Because of the way the licensing system is implemented, it's very difficult for node server developers (and even me as the PG3 developer) to test code related to licensing.   I don't think this specific case can be recreated without purposely adding some fake node servers into the beta/production stores.
If you do end up re-purchasing the production version, then work with @Panda88and @Michel Kohanimto get a refund on the beta version.
A bit off topic but actually, the two are quite similar in that the router update is a complete software replacement for the router, fixing bugs and adding new features, etc. The change log is frequently pages long. All that is retained is the configuration, firewall rules, scripts, etc. They do have three update trees to choose from: beta, stable and legacy. And yes, things have gone sideways when I updated from the beta tree so now I automatically update from the stable tree. Because they have a scripting language, I have written scripts to make me aware the router was updated.
      37.8k
      377.3k
