Upgrade Packages Installed 5.4.5 and Factory Query Program Not Working
I had not done the upgrade packages in a while so I decided to run it.  Now I have 5.4.5 and the factory query says unrecognized action.  I don't see any threads yet on 5.4.5 so I am wondering why it would upgrade the version.
shhhhhh.... it's a secret upgrade that reports back without your knowledge.
   oooops! Did I say that outloud? :)
I installed it also. I didn't see any of my bugs I have been watching so I was also looking for a "review" thread. I wasn't sure whether I could start one.
I put the Set ISY to Query back in there and ran it and the ISY locked up at about 66% system busy.
I doubt anyone except @Michel Kohanim can answer, you might want to open a ticket for a speedier connection to him.. let us know the outcome!
FYI:Mine installed and initialised without any problems. I haven't found any changes from v5.4.4 yet though.
However is did cause me to spell some words funny.
I have long disabled Query on startup since it seems to lock up the ISY for long period of time and proves troubleshooting difficult. I write my own query app that I maintain manually for only the things I require to query on startup. I set the program to run at startup. Some things don't have query option in program like Zen17 binary sensor so I use a network resource.
I still let Query run at 3am and seems to work, but while it is running makes ISY unusable, especially after an update.
Yes, it does take a long time so I delayed mine 1 hour after reboot for troubleshooting purposes instead of manually querying things I need to.  That said, I have never had it lock up the ISY completely like it is doing now.  Guess I will just disable it and manually query for now.  Thank you for all the replies!
IoP appears to now be IoX - mine upgraded seemingly fine. However, the backup is throwing an error (I documented in another thread)
Just did a "packages update" from ISY (or IoX) menu.  Didn't come back on-line.  Normally do a button push in this state but was in my comfy chair so did a sudo reboot from ssh;  came back fine after that.  Yes, had a 20sec pause for query, but nothing over the top.  Backup of 5.4.4. before update was fine and the 5.4.5 backup after was also fine.  Way back in time the last instance when my backup wouldn't work for me I had to revert then re-upgrade to make everything happy again.  That was in the 994 and was early 5.0's.
So your factory query program is still all good?  Here is what mine looks like after the install and after I added back a set ISY to query to it.
Yup ; no issues or changes with mine.
Just a heads up that in my case the package update to 5.4.5 caused a "System Busy" updating loop that I eventually had to reset my way out of. I waited for 4 consecutive cycles of System Busy that lasted about 10 minutes each before deciding to reset, but everything seems to be working OK now. The only way I noticed anything was up after the update was none of my sunset programs ran and I noticed during the busy cycle that my sunset and sunrise times were both 00:00.
Edited by landolfi
Thank you.  Can someone tell me if what I did is the same as the original factory query?
You've got some strange comments in there and the "Factory Query Program" isn't commented out. I'd remove those lines and if you want/need comments in there add them back.
My query program is just like yours, but no comments:
00-KEEP-ISY_Query -
        Time is  3:00:15AM
        Set 'Polisy' Query
