tazman Posted December 17, 2022 Share Posted December 17, 2022 16 minutes ago, sjenkins said: often thought of that for my Insteon devices; never did; I'm impressed. You can retrieve the list from the AC if you click on the top folder or download from Tools Generate Topology Link to comment
brians Posted December 17, 2022 Share Posted December 17, 2022 Looking at the instructions again, I think I should be fine to revert to Zooz: I just made a new backup from V5.5.0 I will shut down, remove Zooz stick and reboot...then press the Move to ZMatter Z-Wave button Then after reboot I should be able to re-add Z-Wave. If something goes wrong, I can just restore the backup and plug back in the Zooz. The only issue would be any Z-Wave devices I would have experimented, used previous in Zooz in ZMatter, would have to be re-included back in Zooz again (I think there may be some stray original nodes however left in Zooz which can be removed using SiLabs Wave PC controller software - remove failed node to clean up). Link to comment
Chris McKean Posted December 17, 2022 Share Posted December 17, 2022 I am at v5.5.0, but have not clicked the button on the Polisy Pro (IoX) configuration page to move to Zmatter. I was told yesterday by UDI support that there were additional patches that needed to be applied before I should do that. All of my Zwave devices are currently on my ISY994i with integrated Zwave, but would eventually like to migrate everything over to my Polisy Pro or possibly get the eisy when it becomes available. Right now I'll just play with the Zmatter on the Polisy to learn how that works. But don't want to migrate until it is safe to do. Link to comment
brians Posted December 17, 2022 Share Posted December 17, 2022 1 minute ago, tazman said: You can retrieve the list from the AC if you click on the top folder or download from Tools Generate Topology Yes that is how I originally generated mine, but I also like to keep track in a spreadsheet. Regarding Z-Wave S2, looking at other forums there seems to be discussion that if PIN code is lost then cannot use S2 authenticated for that device anymore. Many devices have it on a sticker, but some may include in a piece of paper. I went through some similar frustration on older version of LiFX and homekit pairing codes - I misplaced the boxes but discovered that the code is written in very tiny print on the base of bulb. Newer LiFX could apparently retrieve code from HK so don't have to go up and unscrew bulb. 1 Link to comment
Bumbershoot Posted December 17, 2022 Share Posted December 17, 2022 A couple of gotcha's with GoControl/Linear Garage Door Openers. I have two of these devices and they both operate similarly. They included fine, but the devices never showed up in the device list. They were excluded/included again, and this time with the "S2 Access" box unchecked (only S0 is checked), and the interview completed and devices appeared in the device list. They control the doors just fine, but the "Status" value never appears. I changed batteries a couple of times in the tilt sensors, but to no avail. Link to comment
Techman Posted December 17, 2022 Share Posted December 17, 2022 (edited) @Chris Jahn I sent in a couple of support tickets but they bounced back. Not sure if you received them. Here's the contents: 1. Zwave devices are showing up as ZY rather than ZW 2. Polisy 5.5.0 with current package updates, Zmatter board, Multisensor 6 When the motion sensor node is triggered, its status is correctly shown in the level 3 event log and in the Polisy status window. However, neither the level 3 event log nor the Polisy status window shows the motion off status which occurs 4 minutes after motion detection. The sensor motion display was correctly working with the Zmatter board and the previous Polisy firmware Edited December 17, 2022 by Techman Link to comment
sjenkins Posted December 17, 2022 Share Posted December 17, 2022 51 minutes ago, tazman said: You can retrieve the list from the AC if you click on the top folder or download from Tools Generate Topology Amazing how you know something and then forget it. Thanks for the remind! I'll do that now. 1 Link to comment
zmarty Posted December 17, 2022 Share Posted December 17, 2022 (edited) FYI: I had a Z-Wave network working just fine with the ZMatter board and v5.4.5, but when I upgraded to v5.5.0 through SSH my Z-Wave devices stopped working (nodes visible, but no status update and no action happened for on/off etc). I then went and pressed the move to ZMatter button as per instructions, which then happily went on and nuked my Z-Wave network. Nobody thought of my corner case and I guess the assumption was that everybody had this Zooz dongle. I didn't. Good thing I only had <10 devices moved over. Edited December 17, 2022 by zmarty 1 Link to comment
zmarty Posted December 17, 2022 Share Posted December 17, 2022 9 minutes ago, zmarty said: FYI: I had a Z-Wave network working just fine with the ZMatter board and v5.4.5, but when I upgraded to v5.5.0 through SSH my Z-Wave devices stopped working. I then went and pressed the move to ZMatter button as per instructions, which then happily went on and nuked my Z-Wave network. Nobody thought of my corner case and I guess the assumption was that everybody had this Zooz dongle. I didn't. Good thing I only had <10 devices moved over. I have UD Mobile version 0.177 on Android. Should this fail with ZMater and v5.5.0? Link to comment
Chris Jahn Posted December 17, 2022 Share Posted December 17, 2022 28 minutes ago, Techman said: @Chris Jahn I sent in a couple of support tickets but they bounced back. Not sure if you received them. Here's the contents: 1. Zwave devices are showing up as ZY rather than ZW 2. Polisy 5.5.0 with current package updates, Zmatter board, Multisensor 6 When the motion sensor node is triggered, its status is correctly shown in the level 3 event log and in the Polisy status window. However, neither the level 3 event log nor the Polisy status window shows the motion off status which occurs 4 minutes after motion detection. The sensor motion display was correctly working with the Zmatter board and the previous Polisy firmware For ZMatter there is the ZMatter Board and the new ISY ZMatter implementation of Z-Wave. If you use the "Move to ZMatter Z-Wave" button, the ISY will reboot and you will start using the new implementation. Nodes in the new implementation begin with "ZY", nodes in the original implementation begin with "ZW" The ZMatter Board, Zooz, etc. works with the original implementation Only the ZMatter Board works with the new implementation. Thanks for reporting the motion sensor off issue, we will try to recreate it here 1 Link to comment
brians Posted December 17, 2022 Share Posted December 17, 2022 Seems to be a reoccurring reports with new v5.5.0 and zmatter not recognizing zwave device status updates. Link to comment
zmarty Posted December 17, 2022 Share Posted December 17, 2022 (edited) 38 minutes ago, zmarty said: FYI: I had a Z-Wave network working just fine with the ZMatter board and v5.4.5, but when I upgraded to v5.5.0 through SSH my Z-Wave devices stopped working. I then went and pressed the move to ZMatter button as per instructions, which then happily went on and nuked my Z-Wave network. Nobody thought of my corner case and I guess the assumption was that everybody had this Zooz dongle. I didn't. Good thing I only had <10 devices moved over. I am unhappy to report that now I cannot add my Bali Spring Fashions Autoview mini remotes. They used to work just fine with the previous version through the ZMatter board. Now I can remove them from the network but never add them back. Ok I went and found the log. Removing the remote Sat 12/17/2022 01:41:16 PM : Z-Wave Listening for Z-Wave devices to remove from the network Sat 12/17/2022 01:41:21 PM : Z-Wave Z-Wave device detected, start removing from network Sat 12/17/2022 01:41:21 PM : Z-Wave Z-Wave device removed Sat 12/17/2022 01:41:21 PM : Z-Wave Idle Sat 12/17/2022 01:41:21 PM : Z-Wave Idle Adding the remote Sat 12/17/2022 01:41:28 PM : ---- Start Adding Devices - S2 Standard --- Sat 12/17/2022 01:41:28 PM : [ZWAVE-INCL-S2STD] Start Include S2 Standard highpower=true Sat 12/17/2022 01:41:28 PM : [ZWAVE-INCL-S2STD] Added 'CommandAdded' callback 0x802be7468 Sat 12/17/2022 01:41:28 PM : Z-Wave Listening for Z-Wave devices to add to the network Sat 12/17/2022 01:41:35 PM : Z-Wave Z-Wave device detected, start adding to network Sat 12/17/2022 01:41:35 PM : Z-Wave Z-Wave device detected, retrieving info Sat 12/17/2022 01:41:35 PM : Z-Wave Z-Wave device added Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x20 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x59 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x5A Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x5B Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x5E Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x72 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x73 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x80 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x84 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x85 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x86 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x26 Sat 12/17/2022 01:41:35 PM : Z-Wave Idle Sat 12/17/2022 01:41:35 PM : Z-Wave Idle Sat 12/17/2022 01:41:35 PM : Z-Wave Idle Sat 12/17/2022 01:41:39 PM : [Device 12] Waiting on interview complete (374 ticks remaining) Sat 12/17/2022 01:41:41 PM : [Device 12] All interviews are done Sat 12/17/2022 01:41:41 PM : ZWAVE-WORKQ-34 Queue sync device 12 Sat 12/17/2022 01:41:41 PM : ZWAVE-WORKQ-34 Start sync device 12Sat 12/17/2022 01:41:41 PM : [ZWAVE-SYNC 12] Device mismatch, Removing all existing ISY files/objects for Z-Wave device Sat 12/17/2022 01:41:41 PM : [SYNC-DEVICE 12.0] Set commands will now be accepted by the controller Sat 12/17/2022 01:41:41 PM : [ZWAVE-SYNC 12] Not multichannel Sat 12/17/2022 01:41:41 PM : ZWAVE-WORKQ-34 Finished sync device 12 Edited December 17, 2022 by zmarty Link to comment
Chris Jahn Posted December 17, 2022 Share Posted December 17, 2022 1 hour ago, Bumbershoot said: They control the doors just fine, but the "Status" value never appears. I changed batteries a couple of times in the tilt sensors, but to no avail. Thanks, we will try to recreate that here. 1 Link to comment
brians Posted December 17, 2022 Share Posted December 17, 2022 Good news... I shut down Polisy (eg. pulled power) Removed Zooz stick Plugged back in In AC, clicked move to ZMatter button Added first device which is Yale Assure door lock and shows up as ZY 002. Excluded then Included. Took a while interviewing process but it now shows and I adjusted programs that run based on door user and is working fine. Will add rest of devices later because wife wants me to go shopping with her just as I started this Note: I did a highly detailed audit of my Z-Wave devices prior to doing this... I even added the include/exclude instructions in spreadsheet unique to each device so I don't have to go hunting around manuals while doing this. Link to comment
Javi Posted December 17, 2022 Share Posted December 17, 2022 39 minutes ago, zmarty said: I have UD Mobile version 0.177 on Android. Should this fail with ZMater and v5.5.0? Hi @zmarty, UD Mobile ZMatter integration is not yet completed, but we are working on this now. https://forum.universal-devices.com/topic/39417-issues-creating-widget-for-z-wave-device-added-via-zmatter-board-in-polisy/?do=findComment&comment=353885 2 Link to comment
zmarty Posted December 17, 2022 Share Posted December 17, 2022 I keep seeing this dialog when working with Z-Wave (not Insteon!) devices: Link to comment
Techman Posted December 17, 2022 Share Posted December 17, 2022 36 minutes ago, Chris Jahn said: For ZMatter there is the ZMatter Board and the new ISY ZMatter implementation of Z-Wave. If you use the "Move to ZMatter Z-Wave" button, the ISY will reboot and you will start using the new implementation. Nodes in the new implementation begin with "ZY", nodes in the original implementation begin with "ZW" The ZMatter Board, Zooz, etc. works with the original implementation Only the ZMatter Board works with the new implementation. Thanks for reporting the motion sensor off issue, we will try to recreate it here Chris, I'm now getting a pop up box, when the admin console is open, every time the multisensor 6 motion is triggered. Note: The only device I have installed is the Multisensor 6 for testing purposes prior to a migration. Link to comment
waffles Posted December 17, 2022 Share Posted December 17, 2022 18 hours ago, brians said: I also opened a ticket. No reply yet but is weeekend so don’t expect til next week. Did you ever get yours working ? Looks like you got yours to upgrade. How did you do it? Link to comment
Chris Jahn Posted December 17, 2022 Share Posted December 17, 2022 Just now, Techman said: Chris, I'm now getting a pop up box, when the admin console is open, every time the multisensor 6 motion is triggered. Note: The only device I have installed is the Multisensor 6 for testing purposes prior to a migration. This is the "Detect Button Press" mode that by default is supposed to be Off, but for some people it is On. You can turn it on/off Using Z-Wave | Detect Button Press | [On|Off] Some devices send BASIC SET when a button on the device is pressed or a sensor triggered. For older devices the ISY cannot map them to a node because it is doesn't have enough information. You likely have at least one 'Assoc Only' node for Device 2 that you turn into an On / Off switch based on that event (use the right+click menu on the Assoc Only node) 1 Link to comment
Techman Posted December 17, 2022 Share Posted December 17, 2022 15 minutes ago, Chris Jahn said: This is the "Detect Button Press" mode that by default is supposed to be Off, but for some people it is On. You can turn it on/off Using Z-Wave | Detect Button Press | [On|Off] Some devices send BASIC SET when a button on the device is pressed or a sensor triggered. For older devices the ISY cannot map them to a node because it is doesn't have enough information. You likely have at least one 'Assoc Only' node for Device 2 that you turn into an On / Off switch based on that event (use the right+click menu on the Assoc Only node) Apparently, it defaulted to ON after I rebooted the Polisy. The Multisensor 6 motion is what triggered it. I don't see an "Assoc only" option. Link to comment
Bumbershoot Posted December 17, 2022 Share Posted December 17, 2022 39 minutes ago, Techman said: Chris, I'm now getting a pop up box, when the admin console is open, every time the multisensor 6 motion is triggered. Note: The only device I have installed is the Multisensor 6 for testing purposes prior to a migration. I got that one too, but I turned it off: Z-Wave | Detect Button Presses | Off Link to comment
waffles Posted December 17, 2022 Share Posted December 17, 2022 I tried the 'update package' again and now I have lost Portal access and the Polisy's middle and right LEDs are blinking fast. I can still connect via SSH and and the AC comes up, but throws errors. F/W still shows as 5.4.5. I opened a ticket yesterday and awaiting a response. In the meantime, is there anything I can try myself to get at least to a working state again? TIA! Link to comment
sjenkins Posted December 17, 2022 Share Posted December 17, 2022 5 minutes ago, waffles said: I tried the 'update package' again and now I have lost Portal access and the Polisy's middle and right LEDs are blinking fast. I can still connect via SSH and and the AC comes up, but throws errors. F/W still shows as 5.4.5. I opened a ticket yesterday and awaiting a response. In the meantime, is there anything I can try myself to get at least to a working state again? TIA! I would try to update pkg with sudo pkg update sudo pkg upgrade pkg sudo reboot -r then bring up the AC and hit the update package button Link to comment
asbril Posted December 17, 2022 Share Posted December 17, 2022 I have seen so much information that I am utterly confused. I am exclusively Zwave, plus some wifi devices. I have a Polisy Pro with the Zooz 700 usb stick I have the new ZMatter board installed in my Polisy, but I am waiting for the migration until I receive my eisy and when the tool is deemed to be ready. Polisy is at 5.4.5 and PG3 is at 3.1.16 (1) Should I Upgrade to 5.5. now ? (2) What is proper procedure for the 5.5. upgrade, in the Administrative Console or Pressing the button on Polisy ? I know that there are descriptions of the procedure but there are so many comments (including on problems) that I need a clear & simple explanation. Thanks Link to comment
SJL Posted December 17, 2022 Share Posted December 17, 2022 just wanted to update this thread- I reconfigured the Aeotec Gen 6 range extender for "secure communication" and added another Zwave external switch near the Kwikset 910 and the lock added to the network this time. The distance to the Polisy was only approx 25 ft but the other devices seemed to have made the difference. Link to comment
