5.5.0/ZMatter
I successfully upgraded IoP to 5.5.0 last night by using the "POP" method (paperclip in polisy once), lost contact with ISY then got it bak by re-booting it in portal window.  Then added the Matter successfully in the Configuration panel.  Re-booted IoP and had to delete Java cache. Now have everything back.  But...I am also experiencing problems in "seeing" Z-wave devices that were detected and "interviewed"  I have added 1 Aeotec Gen 7 extender and a GE Zwave dimmer switch, but they do not show up on the list of devices or in devices available for programming.
I factory reset the Z-Wave dongle, and added an Aeotec Gen 7 Extender as well, along with an Embrighten Z-Wave Motion Sensor Switch, and neither show up as devices in the AC device tree.  I had to add the devices twice to get them to include, however, as on the first inclusion, the inclusion times out in the interview process.  The second inclusion was almost instant.
EDIT:  When I attempted to Z-Wave | Synchronize | New & Deleted with Interview the interview would not complete on the two included devices.
Edited by Bumbershoot
Hmmm  I tried your approach but still do not see the Wave nodes in the Network panel
My ZMatter listens, recognizes and interviews 7 of my 8 Z wave devices (4 aeotec range extenders, 3 embrighten dimmer switches), but does not detect my Schlage Z Wave door lock.  None of the devices show in the network devices column.  Attached is the Event Viewer.  Not sure what else to try.
ISY-Events-Log.v5.5.0__Thu 2022.12.15 11.54.46 AM.txt
I was able to update to 5.5.0 with no issues.
However, when I pressed the "Move to Zmatter Z-Wave button" my polisy locked up. The only solution was to do a factory reset on the Polisy.
The Polisy is now up and running but I'm unable to include any Z-wave devices.
Prior to the firmware update I was using the Zmatter board with the Multisensor 6 as my test platform, and all was working normally.
