Can't update devices on ISY after upgrade
I successfully upgraded my ISY 944i to 5.3.4. I can control devices from the UDI admin console but when I change device settings and hit write changes nothing happens. What am I doing wrong?
Solved by MrBill
Did you clear your java cache?
Also you have to hit the tab when you change a setting. ie: change ramp rate>click ramp rate button
Edited by lilyoyo1
Thanks but I have already cleared the Java cache twice. I tried hitting the tab key after making a change but still it doesn't update.
What's the UI of your isy? What setting are you changing and what device are you having issues with
Edited by lilyoyo1
I am trying to change the ramp rate and on level of a LampLinc (B2457D2). See attached clip for UI info.
You must set the ramp rate on the right, then push the button "Ramp Rate" on the left.  Not intuitive at all.
