Can't remove PLM; ISY boots into safe mode on next reboot after deleting and disconnecting PLM
Am I missing something? I use the "Delete Modem (PLM)" option in the admin console. It provides no feedback or errors. The next time I reboot ISY with the PLM physically disconnected, ISY boots into safe mode because it can't communicate with the PLM.
The last Insteon device I had connected was removed over a year ago so there are no more Insteon devices configured with the PLM.
ISY v 5.3.4
Edited by Ted
@Ted You're probably using a firmware on the ISY (994?) that is looking for the PLM. If you're not using a PLM you need to get a version that is noted for "Not having a PLM".
What firmware are you using? Look in the current release area for your release and there should be a link for the z-wave/non-PLM version.
Once you install that Firmware the ISY994 will not look for a PLM and will boot normally.
Is there an Insteon checkbox on the AC Configuration System tab? I'm not sure when that feature came about.
That's likely the answer I need. Thank you!
That only applies to ISY on Polisy and eisy. Since @Ted referenced being on v 5.3.4 that an ISY994 firmware. Those specifically had Insteon or "Non-PLM" based firmware that always had 2 links.
For 5.3.4 it's the second link in step 3:
3.  Download firmware
  -  ISY 994i Series including Z-Wave support
  -  ISY 994i ZW, Z, or ZS Series (Z-Wave/Zigbee and/or if you do NOT have a PLM)
