Power Requirements eISY - Can I use a plugged in Power Bank
My units at home so I couldn't look and I didn't find the power requirements on the UD web site tech notes.
I've had couple of brown outs lately.  Looking at some Plugged in Power banks.  (eg: https://www.anker.com/products/a1621?variant=37437690052758 )  They both charge and provide battery power.
Not knowing the power requirements of the eISY I don't want to underpower the power bank.  I think this would be a smaller option than a full blow Uninterruptable power supply.  A 10 minute option is all I'm looking for.
What wattage on the USB C power cord does eISY require?
 Andy
Solved by AllDigital
33 minutes ago, JTsao said:
Isn't the eISY 12V/2A?  I use this with the Polisy and plan to move it to the eISY but I'll need a DC to USB C cable to do so...
https://a.co/d/hy7RXnr
My eISY has a USB C connector that supplies power.  I don't remember if there is a 12V connector, on it
I think you would be better off picking up a small UPS at a place like Costco. They are still inexpensive and you get the benefit of power filtering.
However, if you're using Insteon, don't plug the PLM in to it.
Yes, a small UPS is less expensive, but its a space issue I'm trying to solve.  So the UPS's I have found are too big for where I want my unit to go.
When using a UPS, is it a good idea to plug the UPS into a Filterlinc? This is presuming that the modem is not plugged into the UPS, but the eISY's power supply is.
The UPS power filtering can absorb the power line commands from a PLM. Many also don't have a true sine wave AC output. That many power supplies don't run with.
No UPS on a PLM is a very good recommendation.
FilterLinc sound like a good way to go. That is how mine is. PLM in the unfiltered outlet on the front. Computer equipment on the filtered outlet.
Edited by Brian H
Add information.
