i3 On/Off outlook support
Hi, I have an existing outlet linc dimmer that I believe is failing as the switch started turning on/off and beeping when set to on.  I was going to replace with a new i3 outlet however, wanted to confirm my 994 would control it.  Thanks in advance!
Pretty sure the answer is no. It may unofficially or partially function.
You'll need an eISY for new products. The last update for the 994 was almost two years ago.
Edited by auger66
It does not work with the 994 the way regular insteon devices do. It will add to it as an unsupported device but you would not get the status of it if manually controlled not can you add it to any scenes
