Support thread for: PG3x v3.1.36 (July 11, 2023)
1 hour ago, Geddy said:
Have you cleared our java cache and downloaded a new start.jnlp to see if it went away?
Yes @Geddy deleted old link icon, cleared cache and downloaded a new start link.
But still have the old launcher with PG2 Dep.
Edited by mmb
1 hour ago, mmb said:
I did remember thanks @Geddy, I wish these changes came with expectation of estimated time.  As noted I may have rebooted before the process wasn't finished.
Does the new EISY have no sounds?
Last question, should I still be seeing PG2 Deprecated?
Literally everyone's time need will vary for one reason or another.  Sometimes there are unforeseen glitches to be worked out.
eisy does not have a speaker.
PG2 never existed on eisy.  PG2 is removed from Polisy when PG3x is installed.  If you've installed PG3x on Polisy and are still seeing PG2 it sounds like you have not rebooted.
@MrBill I never installed PG2 on Polisy, it was running on a VMware server. It also migrated to PG3 on Polisy just fine.
Upgrading to PG3x was quite bumpy.
I have literally rebooted about 10 times at this point.
- from the AC console several times
- from the ssh command line several times
- powered down and up several times
PG3x/MQTT is running fine now.
I’ll submit a ticket for PG2 leftover in the launcher.
Edited by mmb
@Geddy fyi Michel says the leftover "PG2 Deprecated" will be removed in the future.
Edited by mmb
