August 15, 20233 yr On 8/9/2023 at 12:28 PM, brians said: FYI, Those both are not Zigbee, they are WiFi. The older FP1 is Zigbee but only was available direct from China. I have both: two FP2 and an FP1. But regarding the ES1 - I have it. It’s Zigbee. I was able to connect it over Zigbee with the ZMatter dongle (but the only thing it did was print an error log that it’s not compatible yet).
August 18, 20233 yr Installed new Third Reality Zigbee motion on eisy. One node and installed no problem. Works great and cheap too ($16.99 on Amazon) Ordered two more. https://a.co/d/f6I7sMb The Zwave motions are an arm and a leg mainly as they put other features in them like Temp, Lux, etc. These cheap just motion detector zigbee devices are the way to go if you dont need all the other stuff.
August 24, 20233 yr I am trying to add a HIMOSO wireless 4 button scene switch to my EISY zmatter. I am IoX version 5.6.4 HIMOSO wireless 4 button scene switch Model RSH-Zigbee-SC04 At amazon: HIMOJO Wireless Scene Switch,Zigbee Smart Light Switch,Free installation Remote Control Switch,Zigbee Tuya Connection,4Way Sticky Panel, Smart Wall Switch, Wireless Button for Smart Home Devices - Amazon.com EISY sees all 4 buttons but it doesn't finish as it stops on interviewing with no progress. Then times out. Buttons do not work. Edited August 25, 20233 yr by Paulywog57 More Info
August 30, 20233 yr GLEDOPTO 12W & 7W Led Garden Lamp Model No: GL-G-101P Gledopto https://www.amazon.com/dp/B07T96FZBX?ref=ppx_yo2ov_dt_b_product_details&th=1 It was able to add it to the ISY but it says Unavailable. Need Color Hue-Sat device & On / Off Switch device, the usual stuff for a color changing bulb UPDATE: This is working as of update 5.7.0 on 09/11/2023 Edited September 18, 20233 yr by BoydG
September 18, 20233 yr Roller Shades Manufacturer : Graywind Model: Roller Shades with Zigbee Motor Support Page https://www.graywindblinds.com/pages/contact Commands requested "up", "down". "Favorite", Status requested "battery low". Sold on Amazon, Alexa Compliant, Alexa discovered and operated as soon as powered up in programming mode. Amazon shows as yooksmart smart device, manufacturer says same as "IKEA" also. eisy 5.7.0 w USB Zmatter finds them and lists them as "unavailable". https://www.amazon.com/stores/page/FCD06F74-9BD9-470A-B117-07AF4C4218E4?ingress=2&visitId=4356e004-e963-4dfb-a403-c8724130777d&ref_=ast_bln 11/1/24 Update, IoX 5.8.4 sees all of them, and lists them as "Main". but when selected the options are identify and query, and nothing happens. Edited November 2, 20242 yr by CoolToys added yooksmart or IKEA and corrected "down"
October 25, 20233 yr Sinope TH1300ZB, TH1124ZB, TH1123ZB would be a good addon here! https://sinopetech.com/en These are: 1) floor heat thermostat, 2) 4000 and 3000 watt electric baseboard heat thermostats respectively eisy 5.7.0 w USB Zmatter finds them and lists them as "unsupported work queue request 6 ignored" Sinope also offers dimmers, switches, load controllers, water detectors and other elements in either Zigbee or Wi-Fi Edited November 23, 20232 yr by glarsen
November 8, 20233 yr Any Zigbee human presence sensor, preferably Tuya device as there a lots of them available! I've got a HAOZEE Sensor from Ali Express https://www.aliexpress.us/item/3256805765649725.html?spm=a2g0o.order_list.order_list_main.23.19fd1802hrsD37&gatewayAdapt=glo2usa Loginovo sensor https://www.aliexpress.us/item/3256805291297545.html?pdp_npi=4%40pre!!US %2428.74!US %2413.22!US %2413.22!!207.96!102.02!%40210313e916994709671554017e092d!12000033255721585!sh!US!4313580587!&spm=a2g0o.store_pc_aeChoiceSimplified.allitems_choice_2005294756320.0&gatewayAdapt=glo2usa Wenzhi sensor https://www.aliexpress.us/item/3256804518651916.html?spm=a2g0o.order_list.order_list_main.11.19fd1802hrsD37&gatewayAdapt=glo2usa I think a lot of these you can find on Amazon as well. These are available in both wireless and Zigbee. I'd be ok with another brand as long as it is Zigbee and a human presence sensor. I'd like for the Zmatter dongle act as the hub so I can eliminate the cloud connection and another hub running in my house!
November 10, 20233 yr Another power plug device. I bought these in 2022 but I think they're "current," FWIW. I had a couple unused in the drawer and had to replace a failed Z-wave plug today. Brand Name: Seedan Model # YT-m010 (some discussion that this is the same as "eWeLink SA-003-Zigbee" but I'm uncertain). https://www.amazon.com/gp/product/B08LD7Q81J Edited November 11, 20232 yr by Riggins44
November 12, 20232 yr Aqara WSDCGQ11LM https://www.aqara.com/us/product/temperature-humidity-sensor/ temperature, humidity, atmospheric pressure, battery data
November 29, 20232 yr Aeotec SmartThings Multipurpose Sensor - Zigbee - Door and Window Sensor, Temperature Sensor US Model: GP-AEOMPSUS https://aeotec.com/products/aeotec-multipurpose-sensor/ https://aeotec.freshdesk.com/support/solutions/articles/6000242294-aeotec-multipurpose-sensor-technical-specifications Sensors: Open/Close, Temperature, Vibration What can help the @Administrator group? I have it paired, it just doesn't have any updates / data. X-ray details from IoX available if helpful. Edited December 21, 20232 yr by residualimages
December 17, 20232 yr Thirdreality multifunction motion sensor, illumination sensor, and multicolor nightlight. Currently works as multicolor light with on/off, no motion or illumination sensing. Model: 3RSNL02043Z Amazon: https://www.amazon.com/dp/B0C9LNXYLL
January 8, 20242 yr Does anyone know if this thermometer works with Polisy/EISY? SONOFF LCD Zigbee Temperature and Humidity Sensor SNZB-02D, Requires SONOFF ZigBee 3.0 Hub, for Remote Monitoring and Home Automation, Works with Alexa/Google Home @Michel Kohanim is there a supported device list so we can check first before asking? Also if a device isn't supported is there any expectation that it will be? Thanks! http://tinyurl.com/557sdxxa Edited January 8, 20242 yr by mmb Question for Michel
January 10, 20242 yr On 1/8/2024 at 8:56 AM, mmb said: Does anyone know if this thermometer works with Polisy/EISY? I'll answer my own question - No. Going back to Amazon. Edited January 10, 20242 yr by mmb
January 13, 20242 yr MonaLisa Arduino Shield and Battery Powered Standalone for remote/probe-based temperature sensing (among other things) He sells on Ebay; use "MonaLisa Zigbee" as a search term. Arduino Shield-based: https://www.ebay.com/itm/285029073913 Standalone Battery Powered: https://www.ebay.com/itm/284992778034 Google Doc Manual: https://docs.google.com/document/d/1YbGH5Dl3OhkTz4v1ul0Xy4Tzc7oBAwip61Rvk_t6WTA/edit#heading=h.w5x22opo2rza Thread about its creation/drivers here: https://community.hubitat.com/t/battery-powered-monalisa-firmware-for-makers-and-custom-devices/69674 Edited January 13, 20242 yr by chadm Added images
February 8, 20242 yr Working to get the BTF-Lighting Zigbee controller running. It's working for on/off and Hue/Saturation (RGB), but there seems to be no way to get the CCT (CW/WW) white colors working. Maybe an easy addition? https://www.amazon.com/dp/B0B2JR1DXZ (Let me know if this should be posted elsewhere!) -Mike
February 8, 20242 yr @Mike M, Please submit a ticket: https://www.universal-devices.com/my-tickets With kind regards, Michel
February 8, 20242 yr On 1/8/2024 at 10:56 AM, mmb said: Does anyone know if this thermometer works with Polisy/EISY? SONOFF LCD Zigbee Temperature and Humidity Sensor SNZB-02D, Requires SONOFF ZigBee 3.0 Hub, for Remote Monitoring and Home Automation, Works with Alexa/Google Home @Michel Kohanim is there a supported device list so we can check first before asking? Also if a device isn't supported is there any expectation that it will be? Thanks! http://tinyurl.com/557sdxxa Yolink has 1 that works with EISY. You need a Yolink hub and the Yolink PG3 Plugin. I am using the thermometer and 6 water sensors. All work great and have problems with developing programs to interface with the devices. Many other devices are also available.
February 25, 20242 yr MOES ZS-B-US2-WH-MS https://www.amazon.com/gp/product/B0C4XWW87F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 On/Off for each switch. EISY does add but as a single node. Toggling only one of the 2 switches is seen in Admin Console. Nothing for the second switch. Toggling the on and off from the AC causes both switches to toggle. The device is available as 1, 2, 3 or 4 switches.
February 29, 20242 yr SONOFF Zigbee Human Presence Sensor | SNZB-06P https://sonoff.tech/product/gateway-and-sensors/snzb-06p/ Wonderful USB-C powered device
February 29, 20242 yr Should have support for most of these in the upcoming isy release. With kind regards, Michel
March 1, 20242 yr Sengled Zigbee BR30/E26 Bulbs Model: E12-N1E 2700K - 6500K While I can control RGB colors, I haven't been able to figure out how to control the white 2700K - 6500K? Bulbs first turned on with a nice warm white, but since adding into eisy, I haven't been able to duplicate that warm white color? The description indicates temperature of light bulb is changeable 2700K - 6500K. Is there something I'm missing or is the feature not available? Thanks!!! https://www.amazon.com/gp/product/B08R5FWMCW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1 https://us.sengled.com/products/zigbee-color-br30-e26-2-packs-hub-required?_pos=3&_psq=br30&_ss=e&_v=1.0 Edited March 7, 20242 yr by jpoje added model number
March 10, 20242 yr If possible, I'd like to see support for: Manufacturer Name: Inovelli Model #: Blue Series Smart 2-1 Switch (On/Off or Dimmer) Link: https://inovelli.com/products/zigbee-matter-blue-series-smart-2-1-on-off-dimmer-switch Key/desired function support: On/Off and Dimming Functions
March 18, 20242 yr Haozee MmWave Human Presence Sensor,Zigbee Millimeter Wave Radar Detection Sensor,Requires TUYA HUB,Support Zigbee2mqq Home Assistant https://www.amazon.com/dp/B0BZCVHYR8?ref=ppx_yo2ov_dt_b_product_details&th=1
March 18, 20242 yr SONOFF SNZB-03 ZigBee Motion Sensor https://www.amazon.com/dp/B08BFFJ69V?ref=ppx_yo2ov_dt_b_product_details&th=1
