Backup issue
Trying to backup EISY…Gets to about 95% then stops with these messages
Firmware and UI 5.6.4
Tried a few times with same results.
Thx for help!
Try one more thing and if that doesn't work, open a support ticket with UD.
Try 6 presses of the multi function button and wait for the unit to shutdown. After it does, remove power, wait a minute and power it back up. Give it sufficient time to completely restart and then try upgrade packages by either 1 press of multi function button or the button in admin console.
Afterwards you will need to reboot again.
Looks like a corrupt file for insteon device 21.CF.D0. I had a similar problem and I needed to delete and readd the device. Or a restore from backup might work.
Gary
I tried to restore that device but it came back that it couldn't read that same config file....
After migrating to EISY this was the only device that I couldn't write updates to for some reason.
I'm going to delete and add a new device here and see what that does.
Thanks for pointing me in a direction
@drprm1I deleted and readded the same device. That worked for me. I suspect doing that creates a new .REC file to replace the corrupted one. An IoX restore from an old backup might work as well if the file in that backup was nor corupt but I did not try that
