ioX finder finds a device that reports "not found"
nowandthen
Go to solution Solved by Techman,
The IoX finder would only find my isy994i. Now that I have moved on to the eisy, the finder finds 2 items. When loaded, it reports as "not found". This is the first listing "https://eisy.local:8443/desc". I have to hit "OK" to the popup before I select the second listing which brings up the console. I can't delete the first listing. How do I correct or delete this behavior?
Is the address in the IoX Launcher the same address for the Polisy that's reserved in your router?
You can also try deleting the address in the launcher, then recreating it.
@nowandthen see @Techman and  @DennisC posts above.  This should fix the “not found” issue. This was reported fixed in another post.
The “https://eisy.local:8443/desc” is auto found and cannot be removed. It’s normal for how IoX launcher finds the eisy as long as your router supports local addressing this way.
14 hours ago, DennisC said:
You need to download a new copy of start.jnlp, not run a previously downloaded copy. Are downloading a new start.jnlp?
Why?
30 minutes ago, DennisC said:
The fix is in the start.jnlp file. It needs version numbers that are stored there and allows IoX Launcher to match the version of firmware.
I don't believe that is how it works.  The jnlp file is akin to an executable file and it not modified when run.  It does store information that should be deleted by the clearing cache/deleting files exercise; but the start.jnlp file itself appears to be the same as it was when last downloaded.
Edit:  If you're saying UDI made a recent change to the start.jnlp file then I follow you.
Edited by gzahar
@gzahar,  UDI did make changes to start.jnpl to get rid of the error message.
  • Like 3
the updated .jnlp installer stops the error about device not found but it does not stop the 2nd entry from appearing.
This has nothing to do with my router configuration. FYI u are not able to delete anything from the IOX finder
It wasn't supposed to stop that from happening, since it is a normal condition.
There were issues with the discovery process and UD made improvements in how IoX Launcher discovers eisy/Polisy. If it finds the device by local host and IP address, they will both be listed and both will work.
Since this is normal, it shouldn't be of concern.
9 minutes ago, kalman8 said:
k just strange since this just started a few days ago.
been using UD with insteon for over 10 years.
Which is why a new start.jnlp needed to be downloaded.
Edited by DennisC
Added info
      378.7k
