Eisy + AEON Labs Z‐Stick Gen5 USB Controller
Hello.
I'm about ready to upgrade ISY 994i (have it for 11 years) to Eisy. I would like to hold off buying Zmatter board.
I have a couple dozen Zwave devices and bunch of Insteon.
1. Can I use Eisy with Aeon Labs Z-stick?
2. Will I retain current zwave functionality ?
3. Will my ISY back up work with Eisy+Aeon Labs Z-stick?
4.When  eventually I'll upgrade to Zmatter board will Eisy +Z-stick back up work?
4 hours ago, tibbar said:
Hello.
From the UD migration document:
The original implementation on Eisy / Polisy can use generic Z-Wave controllers such as the Zooz stick, or, it can use the ZMatter Z-Wave controller (either board or USB dongle).
The ZMatter Z-Wave implementation can only use the ZMatter Z-Wave controller (either board or USB dongle).
9 hours ago, tibbar said:
Thanks @DennisC.
Any idea if Zwave backups between hubs and controllers would work?
Not sure what you mean:
"between hub and controllers" ?
Zwave back up from ISY restored on EISY + Z-stick then backup from EISY + Z-stick restored on EISY + ZMatter board.
I believe moving from Z-stick to ZMatter is done through a ZWave migration, not a backup. I don't recall seeing the option of doing a ZWave migration on eisy.
However, maybe I don't see it because I am not running a Z-stick on eisy.
Might be best to confirm with UD via a support ticket.
