Support thread for: PG3x v3.2.9 (OUTDATED)
@bmercierJust upgraded and PG3x looks good so far.  However, IoX now has the following popup error at each time launched and I tried it 5 times.  Rebooted a second time and still occurs.
Edited by hart2hart
Hello,
Please open a ticket, reference this post, and also attach the result of https://eisy.local:8443/WEB/sysconfig.txt.
Benoit
Updated from PG3x 3.2.8 to 3.2.9 on a Polisy Pro. All Programs where marked as disabled and had to be manually re-enabled. No other issues noted at this time.
@hart2hart, the SSDP Client issue is on the client side of UPnP discovery (Admin Console). If you are on Linux of FreeBSD, it's normal. If you are on Windows, then something else is using that port. In short, it has nothing to do with eisy.
@kzboray, so very sorry for the trouble. This is fixed in our next release (today). This said, simply restarting IoX from the Admin Console will fix this issue so that you don't have to re-enable all programs manually.
@hart2hart I've seen this error message several times before and I reported.  Got the same response from UD.
It disappears after a period of time in my case so I just ignore it.
@Michel Kohanim, restarting didn't fix the problem for me after updating to 3.2.9. My Eisy is on 5.7.0 / 3.2.9 now, and I've had to manually re-enable all programs for the past 3 or 4 updates.
Edited by Hoosier Daddy
clarify
Thanks. As I should have done to start, I rebooted the PC and the issue resolved.
Just did the upgrade. The disabled programs issue has been fixed at least for me. Thanks!
