Venstar Remote Sensor Capabilities
Hi,
I am looking into buying a new thermostat. The most important feature that I need, is to be able to control from the ISY using programs, when it should use the built-in sensor in the thermostat, and when to use the remote sensor. Does the Venstar nodeserver support this?
Edited by ISYhbsh01
Solved by Goose66
2 hours ago, Goose66 said:
Afraid not. Neither setting nor determining the current controlling sensor is supported by the API. I don't believe you can in the Honeywell Thermostats, either. You may want to ask @Jimbo.Automates about Ecobee.
Thanks.
7 hours ago, ISYhbsh01 said:
Hi,
I have two remote sensors (one of these is called "Office Sensor").  The thermostat is set to average the temperature between the two remotes and the thermostats itself, but I have the ability to select an individual sensor and adjust the temperature based on that sensor.  I don't quite understand what you're asking for, but you have this programmatic ability (the office gets direct sun and warms up quicker than the thermostat or the other sensor):
EDIT: "Living Room" is the name of the Venstar thermostat that the remotes are connected to.
New Program - [ID 0080][Parent 00A7]
        'Devices / dirPolyglot / Venstar / Living Room / Office Sensor' Temperature is 72°F
        Set 'Devices / dirPolyglot / Venstar / Living Room' Mode Off
Edited by Bumbershoot
ecobee has a wireless remote sensor that includes a motion sensor.  You can include or exclude the remote sensor from the operation of the main thermostat.  You can't exclude the main sensor.
I used to have Venstars with remote sensors and lots of programs to control them.  Then I switched to ecobee and ended up deleting most of my programs and letting the thermostat take control.  The thermostat has impressive capabilities and does a great job mostly on it's own.  You should check it out and see if it can work for your situation.
