add Aotec motion sensor to eisy
Michaelv
I bought the Zwave dongle for my Eisy and an Aotec Motion sensor. All it has is a reset button.
I found the "Add a Zwave device" in the admin Console and brought the sensor right next to the PLM.
It wont connect.
What do I have to do?
MV
You need to put the motions sensor into inclusion mode first. The documentation that came with the sensor will tell you how to do that.. Once it is in inclustion mode remove it from the zwave network first then include it into the zwave network.
It is not clear from what you wrote, which ZWave dongle did you buy, have you successfully added the dongle, and enabled ZWave in the Configuration tab?
So this is an Aeotec Motion Sensor M6001-MTP. The instructions do not say how to put it into communication / inclusion mode. There was just the battery tab to be removed and the LED would flash green / red for about 5 minutes. I assume that it is in inclusion mode when doing that. There is a reset button and if I press that for 5 seconds the lights start flashing again, or, I can remove the battery, replace it and the led flashes red / green again. I have been within 2 feet of the dongle when in this state.  I have read the Wiki and whether I try to add or remove it first, the system does not see it.
Quote
Have you toggled the use Zwave switch in Configuration tab and then rebooted? Is Zwave menu at top of the admin console?
I went to the configuration tab and the Z-wave support is selected to on.  I did toggle it. there is a Z-wave menu at the top of the AC.
The Aeotec Motion Sensor M6001-MTP is attempting to connect when it's flashing red and green. If you use UD Mobile you may want to try and connect it by using the QR code on the device.
@Michaelv  Go to AC and click on the ZWAVE tab
Then click on add ZWAVE DEVICE in drop down menu
You should see this:
Put the motion sensor in inclusion mode and the Eisy should then see it and add it. It will take several seconds to get it added.
      376.9k
