Tesla Node Stopped Working
I didn't do an update.  I put it in the same slot as the previous, but completely different Tesla node was.  Then did a fresh install of the new one.
I just drove the car and it currently shows good data.  I will see what happens in a bit and send a log.
Is it acceptable it I only allow update Data (button) on the status page?  It will update data on all pages, but will be a much simpler to implement
  • 1 month later...
link is bad and is: ttps://github.com/Panda88CO/udi-TeslaEV2/blob/main/README.md
yes, missing an h at the beginning
it does not show in the released note but there have been some updates that did not populate so it may be an older version
5 hours ago, Geddy said:
@Panda88 I think it’s the “more info” button on the plugin page. When viewing on a mobile device it asks me if I’m trying to open another app.
Yes.  Thanks for clarifying my comment.  Its the more info button.
I have updated to the latest version and this still is not working.  My car is currently charging and the phone app shows it as charging and currently 75%.  This is what the node says.  I assume "status" should be saying 75%.  And of course the other info should be saying it is charging.  If I click "honk horn", it does honk the horn.  So clearly it is connected in some fashion.
And the climate page shows 0 degrees c in the "node connected" field.  That makes no sense.  My phone app shows exterior temp as 81 and interior temp as 92.
EDIT:  After a bit, not sure how long, it did update to say it was charging, but still reporting 0% status.
Edited by apostolakisl
@apostolakisl:  I had a similar problem recently where none of my data was updating.  I was able to fix it by using the "autheticate" button in PG3x and this fixed the issue.
