If "day of month" = x?
Go to solution Solved by hart2hart,
I have programs that report out daily data for a sensor. They calculate and give monthly highs and lows.
What I need to do is reset the monthly value variables at the end of the first day of the month. It's been a while since I've done this. I found a post that reminded me that I used io_guy's ISY data plugin at my last house.. but I now don't have/want a pi to run nodelink.
From what I can see, I'll have to create program that runs at the start of the day and assign day of the month to a variable from system data
     time = 12:00:01am
then
      day_of_month = system data / day of month from the drop down
I'll have a second program do what I want
       time = 11:59:50pm
and day_of_month = 1
then
       (Reset the variables)
Is there a way to do it directly with an if in one program, I feel like I'm forgetting something?
Link to comment
@paulbates
Hopefully you can find some clues in here. I am not sure if the system variables were here when you were frequent. :)
clock.sync - [ID 0003][Parent 0002][Run At Startup]
        // Run at Startup enabled
        Time is 12:00:10AM
     Or Time is  6:00:10AM
     Or Time is 12:00:10PM
     Or Time is  6:00:10PM
        // update $sSys.MM.DD
        $Clock.scratch  = [Current Day of Month]
        $Clock.scratch /= 100
        $Clock.scratch += [Current Month (Jan=1, Feb=2, etc.)]
        $sSys.MM.DD  = $Clock.scratch
        $sSys.MM.DD Init To $Clock.scratch
        // update $sSys.hh.mm
        Repeat Every  20 seconds
           $Clock.scratch  = [Current Minute]
           $Clock.scratch += [Current Hour]
           $sSys.hh.mm  = $Clock.scratch
        // update $sSys.hh.5mm
           $Clock.scratch.noFrac  = [Current Minute]
           $Clock.scratch.noFrac /= 5
           $Clock.scratch.noFrac *= 5
           $Clock.scratch  = $Clock.scratch.noFrac
           $sSys.hh.5mm  = $Clock.scratch
        Repeat 1 times
        // Run at startup will evaluate False
        Run Program 'clock.sync' (Then Path)
Link to comment
46 minutes ago, hart2hart said:
If I understand, The timedata node server has day of month.
ISY itself also has day of month and month codes. Only trouble is the parameter is not available for triggering programs, and needs to be polled to dump them into program triggering State Variables.
I use them in so many programs for year-free, date based, occasion based programs, it is worth while and only dependent on ISY itself, not on any other cloud, node server, or hardware device connections to function.
Link to comment
42 minutes ago, hart2hart said:
Are there reasons not to use the timedata node server? I use day of month from it as trigger in a few programs.
That's a good suggestion. When I looked in the store, and went to get hub to see an image of what iox would present, it was sunrise and sunset data only.
Sounds like you're saying it also presents month / day info like io_guy's ISY_Data node server used to?
Link to comment
Here's a screenshot of the information presented in the TimeData node.
  • Thanks 1
Link to comment
It does. I adopted use of it when I migrated to eISY with node servers and away from nodelink.
Link to comment
I set up a real simple program using The TimeData node server in PG3x. I do a schedule in IF sometime just after midnight, with an AND IF which asks if (from TimeData) day of the month equals 1st
If it runs,  it ensconces my previous monthly total into a separate variable register, and cleans everything else to zero to start over.
Super clean and easy. I knew TimeData would come in handy.
Edited by glacier991
Typos
Link to comment
My program looks something like this:
IF
           Time is 12:20 AM (I have a bunch of things that happen around midnight so I decided to let things settle down)
  AND  'Time Data Ephemeris is /  Time Data' Day of Month is 1 Day (In other words, the 1st. This is right in the drop downs in the programming tab)
THEN:    Whatever it is you want to accomplish on the wee hours of the 1st of the month. The program will only run at 12:20 on the 1st of any given month.
details.
Link to comment
      36.9k
      370.2k
