Variables not updating in favorites
Hi @Javi, Lately I noticed that variables do not update in my favorites when the value changes. For example I have a variable for each door sensor  that changes from 0 to 1 when the door opens.  If I tap on the favorite icon and open the variable information, the value changes.  Then when I return to the favorite it is now displayed correctly.  Running 1.1.64
Thank you.
Solved by Javi
Please test the following to help narrow the issue.
Is this only favorites or Home Tab also?
If Both:
Does the Admin Console show the variable update if it value is change from UDM?
If it does:
With Favorites open showing the variable(s), does UDM show variable update if value is changed from the Admin Console?
Thanks @Javi, when I went to run your test, it is now working fine on the favorites page.  As far as I know I've made no changes.  Thanks, I'll let you know if I see it again.
