Include door locks in new eisy
Zwave devices are add to eisy same way they were add to Polish and ISY994. If you have the Zwave dongle properly added, you should have the Zwave menu at top of screen.
Search the wiki for specific details.
  • 2 months later...
Just keep in mind that UD Mobile still does not provide support for managing lock users, which the Java console has, and which I consider critical functionality. I submitted a feature request for this a couple of years ago.
Edited by Steve L
I'm using Home Assistant for a lot of this missing functionality.
More and more it's my goto platform.
I decided to give Home Assistant a try - I've been thinking about it for a while and this pushed me over the edge.
My son uses HA for his Aqara door locks, Ikea temp sensors and Zigbee smart plugs.
One Zigbee smart plug is used in an automation to control a 240V contactor which turns on/off a garage heater based on info from the Ikea temp sensors.  He also uses a cheap android tablet for a really nice dashboard.
I use HA with an Insteon modem at our AZ condo. I run Tailscale the HA for remote access.
Finally I use a Polisy/HA combo at our main house.
HA has come a long way and solves lots of smart device integration problems.
  • 4 months later...
Coming back to this. I now have Home Assistant with its UD integration. Unfortunately, all the solutions I can find to manage the lock assume I am using a USB Z-wave stick connected to the HA host (I am using a Home Assistant Green box). I have read that one can install HA on the EISY - if I do, will HA treat the UD Z-wave adapter as a USB adapter? Or do I just move the lock to the HA box (I do have a Zooz USB adapter) and forget about the UD integration?
This is all so complicated when all I really wanted was for UD Mobile to be able to manage the lock codes. I keep reading that there is a plan to replace the Java UD console, but I worry that the replacement won't support managing Z-Wave lock users.
