Disarmed required first before changing from Armed Away to Armed Stay
dbwarner5
Go to solution Solved by Jimbo.Automates,
Have this program below. Running THEN does not change the Elk armed status as expected. When this program runs, the Armed Status is " Armed Away.
        Set 'Elk Main House' Set Armed Status Armed Stay
However, if I add a disarm, it runs correctly.  See next:
        Set 'Elk Main House' Set Armed Status Disarmed
        Wait  2 seconds
Is this a function of the ELK or the Elk plugin?
thanks.
        Wait  2 seconds
thanks.
For clarity, are you saying you can not change the armed status using the Elk plugin once the system is in an armed state, without disarming first?
If so, that is correct. It is a behavior I reported sometimes ago and I believe it is listed in the open issues list.
Yes.  thanks.
      37.8k
      377.4k
